2.2 LAP Engine: 2.4 Intake Manifold install on 2008 2.2
SO these are the parts we need for this correct.
GM
Part # Category Description Pack Qty Unit Price Quantity Ext.
Price YOU
SAVE Core Charge S&H Approx TOTAL Remove Part
*12587878
Engine Fuel Intake Manifold
MANIFOLD
$108.39
$108.39
$74.48
$0.00
$22.76
$131.15
*12589516
All
SEAL VENT
$8.76
$8.76
$6.01
$0.00
$1.84
$10.60
*12600729
Multiport Fuel Injection Throttle Body Seal
SEAL
$8.42
$8.42
$7.79
$0.00
$1.77
$10.19
Subtotal:
$151.94
GM
Price YOU
*12587878
MANIFOLD
$108.39
$108.39
$74.48
$0.00
$22.76
$131.15
*12589516
All
SEAL VENT
$8.76
$8.76
$6.01
$0.00
$1.84
$10.60
*12600729
SEAL
$8.42
$8.42
$7.79
$0.00
$1.77
$10.19
Subtotal:
$151.94
What's up guys I've run through the post a couple of times but saw a few different opinions as to what parts are needed for a 2007 2.2 so I was just wondering if I could get any clarification as to exactly what I'll need to order from gmpartsdirect for the 2007 2.2 IM to the 2.4..
For example, the first page says I need to make sure the manifold has the extended insert, but reading on, someone said that 07's didnt need it..
Great how to by the way, I'll definitely be using it for installation.. Just don't wanna take off my entire intake manifold and throttle body only to find I'm missing a part and can't go to the store to get it!
Any help is much appreciated thanks
i have on 06 which needs the adapter plate if im not mistaken.. Do i have to order the CED kit because it comes with it or can i get this part somewhere else and just get the zzp kit and save myself some money? Any help is much appreciated!
Will someone please just give me a list of the part numbers that I will need for this install.. I plan to order from gmpartsdirect and all that I know is that I need the intake manifold and a "brake booster hose". There's so much other talk with all these gaskets and seals and mounting plates it's throwing me off.
I have a 2007 2.2L LT.. What (exactly) do I need to order?
Much appreciated thanks to the person who can give me the part numbers from gmpartsdirect of EVERYTHING that I will need. I don't want to take my intake manifold off and realize I'm missing a part then have to wait for that part to ship.
I am installing my 2.4l intake mani now. I am having a hard time removing the brake booster hose. The how-to states to remove the brake booster hose from the "power brake booster". I suppose the power brake booster is when the brake booster hose ends (in the firewall?). I tried pulling the hose in a downward motion after removing the black clip lock but it isn't coming off whatsover. Any suggestions?
any trick to getting the bb hose off?
You need a CAI, yes.
I just did this last night using this How-To. My car is an 08 too. A few things I noticed that weren't said in the how to...
-The 2.4 manifold doesn't have a screw hole for the dipstick tube or the MAP sensor. MAP sensor harness should be plugged into the sensor, then put the sensor in the manifold. Its a pressure fit, so make sure its in there.
-When I removed my stock 2.2 manifold, it was a total pain in the ass. It was catching on the cylinder head on the driver side so I had to play with it for a while and eventually the gold insert on the manifold around the driver side stud came loose so I moved that towards the head and out of the manifold which gave me JUST enough clearance to get it off the stud and out of the car.
-When putting the 2.4 manifold in, I found it easier to remove the injector harnesses to get enough clearance for the brake booster nipple to clear the AC line
-Its easier to cut the stock brake booster hose and extending it than to remove it from the plastic fitting on the brake booster...at least I was more comfortable doing it that way than potentially breaking the plastic fitting lol.
Thats it I think. Overall, definitely worth it. Pulls hard to redline now, sounds deeper and a bit more aggressive too when you really hammer it.
Awesome
Just ordered my 2.2 to 2.4 conversion manifold kit from crateenginedepot.com, gonna install mine with my K&N in a few weeks! The kit seemed kinda pricey though, it was like 580 shipped from crateenginedepot... should give good gains with the trifecta tune though!
The reason that info isnt in the how-to is because its not true if you got the proper early style 06-07 intake. There most definitely is a location to secure the dipstick and the MAP sensor is held in place by a plastic lock on the manifold........
By the way....been on the manifold for over 3years now....runs great, never a single DTC, great mod
