2.0 LSJ Engine: Airbox modification
Old May 26, 2007 | 06:11 PM
  #476
thought's Avatar
Originally Posted by donjuaniii
Do you have the AEM part # .... Was it 21-2110DK ?
Yes, the 3.25" inlet
Old May 29, 2007 | 06:35 PM
  #477
PolishPauL's Avatar
So the AEM filter fits the best? Whats the easiest way to hold the filter in place?
Old May 29, 2007 | 09:16 PM
  #478
Royal Racing Cobalt's Avatar
Air Box Mod Problem
I did the Air box mod in Feb of this year. Some mornings the car won't start all that well. No CEL. I tried injector cleaner and fuel sytem cleaner but that didn't do. Could that filter be clogged up already or is the filter not big enough because I can only run 10lb of boost. Let me know. Changing that filter is a pain the ****.
Old May 29, 2007 | 09:38 PM
  #479
SS_SC_Cobalt's Avatar
sounds like you have other problems which are not the air filter.......
Old May 29, 2007 | 10:34 PM
  #480
thought's Avatar
Yes, a clogged air filter will lower boost and cause tonnes of other problems including MAF codes if it sucks crap in and gets on there. COuld def be something else too...
Old May 29, 2007 | 11:44 PM
  #481
donjuaniii's Avatar
Thanks!
Old May 30, 2007 | 09:15 AM
  #482
take it out ck the air filter and clean and lightly reoil if necessary and clean the maf while its out....
then reinstall if problem persists then like I said you have other issues...
Old May 30, 2007 | 10:00 AM
  #483
RaineMan's Avatar
I would say you have non air-filter related issues.
I took out my pep-boys cheap-o air filter (same kind used in the original mod) after 10,000 miles and it looked like it could easily go another 10,000 without having any problems.
I replaced it anyways b/c I had bought a new one just incase. But I'm pretty confident that these filters can handle 20,000 miles easily.
You didn't actually read the how-to (first pages of this thread) did you?
Old May 30, 2007 | 11:13 AM
  #484
supercharged414's Avatar
I did the airbox mod and love the whine. Use a K&N E-1009 universal filter, its bigger and better performing, then just leave off the bottom of the airbox. Thanks for the write-up
Old May 30, 2007 | 11:28 AM
  #485
PolishPauL's Avatar
I actually did but i dont wanna do it that way. I jus wanna know if theres a filter that fits perfectly and you dont have to use a screw to hold it?
Old May 30, 2007 | 11:35 AM
  #486
you need to clamp the filter on like any other CAI so it doesnt fall off, fitting perfectly is not the problem, making sure it doesnt fall off is
Old May 30, 2007 | 12:41 PM
  #487
thought's Avatar
Like he said. The AEM fits perfectly like the stock one, but to leave the bottom cover off (for more airflow) you need a clamp for safety
Old May 30, 2007 | 01:39 PM
  #488
PolishPauL's Avatar
Is there gonna be room to easily do that and does the filter come with a clamp that you can use? Can I do it without removing the airbox? Also, can a K&N filter fit as easily as the AEM (like the universal one mentioned a couple posts back)? Can anyone recommend me the best K&N filter?
Thanks for all the help so far ++rep
Old May 30, 2007 | 02:00 PM
  #489
RaineMan's Avatar
You have to use a clamp to hold the filter on. There's nothing else to hold it on with.
Any short cone filter with the correct opening size will fit as well as any others. The brand is up to you.
As far as reccomendations... I used the $25 Spectre (pep-boys) one and have had no problems.
Old May 30, 2007 | 02:06 PM
  #490
thought's Avatar
The AEM comes with a clamp that even says AEM on it, lol. Any 3.25" opening filter is fine. And there is NO "easily" with this mod, you have to remove the wheel, splash guard and at LEAST the filter bottom cover, if not more to drill a hole for the clamp access...
Old May 30, 2007 | 02:21 PM
  #491
RaineMan's Avatar
You don't have to drill a hole for the clamp... but it's definately not easy.
Pull the headlight and bracket on that side and go ahead and remove the whole airbox... with the filter in place you should be able to get a small ratchet up there to tighten the screw on the clamp.
Old Jun 1, 2007 | 12:08 AM
  #492
PolishPauL's Avatar
So i can go to any store and get any K&N filter with a 3.25" opening or can I find the best one on the internet? Anyone know the best store?
Old Jun 2, 2007 | 04:38 AM
  #493
iso's Avatar
iso
that's the filter i used, and the oil sucked right through the filter. screwed up my maf and covered the inside of the intake tube and throttle body. it was not a fun experience to fix and clean. for anyone else, i would recommend a dryflow filter.
Old Jun 2, 2007 | 09:41 AM
  #494
PolishPauL's Avatar
Whats the point of an oiled filter? What does the oil help with?
Old Jun 2, 2007 | 12:02 PM
  #495
thought's Avatar
Particulates stick to the oil, allowing the filter material to have wider gaps and fewer layers resulting in higher flow, lesser restriction.
Old Jun 3, 2007 | 09:35 AM
  #496
ridemlow03's Avatar
I just did mine a couple days ago. i got an apc filter(3", 3.5", 4") with the oil in the bottle on the side of the filter. i just didnt put the oil on and its working just fine. i love it. j/w i have an 07. i simply unscrewed the bottom of the air box and put the filter in. i then drilled a whole on the top of the box so i could tighten the filter down and kept the bottom part of the airbox off. when i was doing it, i thought about something, not sure if anybody else has thought about it but couldnt you just keep the stock filter and screw a mesh grille in where the removable plastic piece to cover the bottom so that the filter doesnt fall out and your still pulling in good air?? it sounds stupid but just an idea, i was just wondering if anybody did this? damn i know you guys are going to flame me for this. lol
Old Jun 3, 2007 | 10:23 AM
  #497
guys keep in mind if the filter is an oil type you must use some oil to help with cleaning otherwise you will get particles that pass thru the media
Old Jun 3, 2007 | 01:00 PM
  #498
thought's Avatar
That's an interesting idea. But I think that might be more useful with a KandN drop-in filter. The stock one is suck a heavy and restrictive media.
Old Jun 3, 2007 | 06:16 PM
  #499
iso's Avatar
iso
yea, if you buy an oiled filter and don't oil it the filter is almost completely useless. you might as well just use no filter whatsoever.
Old Jun 3, 2007 | 06:19 PM
  #500
Super_SS's Avatar
i bought the Spectre Mesh Filter...Sounds loud and honda's get scarred and break down
