2.0 LSJ Engine: Airbox modification
Old Apr 14, 2007 | 05:09 PM
  #426
ElChialeux's Avatar
thought: Is this the one you got?
http://cgi.ebay.ca/AEM-Dryflow-Repla...QQcmdZViewItem
Just want to be sure before ordering...
Thanks!
Old Apr 14, 2007 | 05:23 PM
  #427
stealthy1ss's Avatar
Thanks!
That is the correct one. I bought mine from the same people and they are pretty fast with shipping. That filter fits so well that you almost don't need a clamp.
Old Apr 14, 2007 | 06:06 PM
  #428
ElChialeux's Avatar
Thank you! Will be ordering soon, can't wait to hear that supercharger whine!!
Old Apr 14, 2007 | 08:01 PM
  #429
Just completed the air box mod and all I can say after a test drive is, WWWWHHHAAAAAAA........WWWWWHHHHHAAAA!
Old Apr 14, 2007 | 08:22 PM
  #430
thought's Avatar
Thanks!
That is the one! Enjoy the AEM branded hose clamp, lol
Old Apr 27, 2007 | 04:10 AM
  #431
mIkeyG312's Avatar
i just did the airbox mod today im lovinn it the whine is amazing my frends say it sounds like a rc car lol
Old Apr 27, 2007 | 11:07 AM
  #432
Pyros777's Avatar
Little update:
GM finally shipped out some 2.2/2.4 GMPP intake filters to crateenginedepot. I placed my order and should have one by next week. Hope it fits!!
Old Apr 27, 2007 | 11:47 AM
  #433
suburbanrobot's Avatar
latest victim is ME
well all this talk of blower whine sent me down to PEP BOYS this morning... I p/u'ed the Spectre filter #8132 in red!!! a whopping $26 w/ tax
all I can say is "HOLY CRAP BATMAN".... on my test run, I laid the ole lead foot and instantly .... damn that sound sweet
everyone I drove past had to look when they heard the whine...I guess some peeps heard me coming cause when I came around the corner they were all looking at the BALT with that WTF look
best bang for the buck mod
Old Apr 27, 2007 | 10:07 PM
  #434
COBALT SS LOVER's Avatar
Bought Cheap Air Filter Kit
Originally Posted by SS_SC_Cobalt
Recently I spent time adapting a conical air filter to the stock box, left the bottom off and BAM cold air for $35, well here are some pix and DAMN is the S/C loud now, love it!
Talk about turning peoples heads, the car sounds like a mini from Italian Job
Butt dyno says def more power, car is chiping and screetching everywhere now
Enjoy:
Now the fun starts, Basically you need to get your stock airbox our of the car, it is located DS in front of the wheel, you have to remove 2 push pins, and 7-8 7mm screws and then you can bend back the splash guard. Now this must be done after removing the DS front wheel.
Once the splash guard is moved then you go in and remove 3 nuts holding the airbox on and loosen the upper clamp in the engine bay where the intake mates to the TB adaptor pipe.
Disconnect the MAF line(1 electricl connector) and then you take your time removing the box(will take some twists and contortions) you also have to pop 1 harness grommet retainer but this is simple)
Installing and measuring, once it is out and you have the air filter(BTW the filter is a spectre Universal pt number 8138) this filter has adaptor rings to mate it to 3", 3.5" or 4", you will use all adaptors to mate it to the 3.15"stock opening, here is the only real tricky part, you need to put the 3" adaptor on the stock box(the pic below shows the 3" adaptor already on), trim the outer lip off a little since the stock lip is slightly larger than 3" with an xacto knife then the rest of the filter adaptors slide on no problem
Filter with adaptor rings
Installed Filter, you drill one small hole even with the location of the clamp I used a 1/4" bit and a slim flathead to get in there, and with a flash light in the snorkel for light the clamp shows up fine, once tight it is reversal of removal! Enjoy!
(HOLE LOCATION)
Installed Filter 2
Finished and installed back in the car
Installed ! Now the fun can start! Great thing is only mod to the air box was 1 small hole drilled in the funnel for screwdriver access
I have a video with sound but have not had a chance to upload it, tomorrow.. it is loud
EDIT:Aww heck here it is
right click and save as
SS INTAKE VIDEO AVI
I DONT KNOW GUYS I BOUGHT A AIR INTAKE ON EBAY IT HAS THE SAME FILTER AND NEW TUBES AND STUFF MY CHECK ENGINE LITE IS ON SOLID AND IT GETS WORSE GAS MILAGE AND IT SPITS AND SPUDDERS NOW!!! SO BEWARE
Old Apr 27, 2007 | 11:07 PM
  #435
thought's Avatar
this is TOTALLY different than ebay intakes man. There is NO CEL with this mod EVER
UNLESS you use an OILED filter.
If you use a dry filter, you will NOT get a CEL
Old May 2, 2007 | 02:09 AM
  #436
Routs's Avatar
So, how much whine do you guys hear when you are driving on the highway (not getting on it, just driving at speed)? I don't mind a little more sound but I really am not a big fan of hearing a constant droning sound on longer trips.
Old May 2, 2007 | 02:15 AM
  #437
thought's Avatar
It only whines at high boost / high engine load
None on the highway unless I downshift and punch it hard
Old May 2, 2007 | 02:54 PM
  #438
Routs's Avatar
So, nothing noticeable at all?
Man, I must be getting old when I'm actually worried about excess noise on long drives... When I had my '88 Mustang 5.0L you couldn't hear yourself think most of the time and now I'm worried about a little blower whine.
Oh well, this makes me happy none the less.
Thanks, man.
Old May 2, 2007 | 03:04 PM
  #439
RaineMan's Avatar
I've got an oiled filter on there and haven't had any problems.
Old May 2, 2007 | 06:05 PM
  #440
Thanks, man.
barely noticeable in 3rd gear and up w/ the radio on! It is only really noticeable in 1st and 2nd on boost only
great low buck mod
Old May 3, 2007 | 01:24 AM
  #441
thought's Avatar
Good to hear - that means you know how to oil it properly - those who dont and get oil on the MAF will get a CEL
Old May 4, 2007 | 09:17 AM
  #442
I didn't oil my filter what-so-ever.... apparently it had too much oil on it from the factory
CED said when I do clean the filter... don't oil it and it will be just fine
Old May 7, 2007 | 07:53 PM
  #443
Pyros777's Avatar
I JUST received my 2.2/2.4 filter from CED (GM just started shipping them out mid-april) as I was walking to the house from my car. Thanks UPS.
This is a non-oiled filter.
I will be test fitting it this weekend and hopefully pulling a couple dyno runs to record the difference. Hopefully the answer to the "does GM offer a CAI for the SS S/C?" question will change soon.
I know it wont be a 100% real CAI, but it will be the stock GM intake with a filter that says GM Performance Parts on it. thats good enough for me)
edit: first things first. lets hope it fits. :\
edit x2: I just measured the filter against the specs for the AEM Dryflow (5" long, 3.25" opening), and it matches those specs perfectly if I've measured it accurately.
Old May 7, 2007 | 08:14 PM
  #444
tombomb's Avatar
i did this mod a few months ago, i just got the AEM dryflow and it fit perfect, no cels, every once in a blue moon the CEL will come on but it goes away by the end of the same day (happens once every 3 months for one day) and when i did this it was a HUGE difference in whine, 2 and 3 and it starts fading in 4 due to wind, so i dont know what crap you guys got but was running with a buds eclipse and he said all he could hear was this massive whine when i passed him and he had all his windows closed, plus i get alot of looks when i punch it
Old May 9, 2007 | 12:21 AM
  #445
bojan's Avatar
here is another one,,,not the way u guys do it..i dont want to cut my box out in case somthing happens i can just put the lid back on and it will look like it wasent touched
BEFORE air box video
http://videos.streetfire.net/video/a...1f0188e378.htm
AFTER
New Vid
http://videos.streetfire.net/video/b...2900fb11b5.htm
vid
http://videos.streetfire.net/video/1...2801579041.htm
pic
Old May 9, 2007 | 12:40 AM
  #446
Routs's Avatar
bojan,
Looks pretty cool, but what size of filter are you using (i.e. what is the diameter of the inlet attachment)? The only concern that I would have with not having a complete seal at the top of the filter is that you could still get crap in there.
By crap, I just mean fine dust.
Old May 9, 2007 | 12:49 AM
  #447
bojan's Avatar
bojan,
K&N Filter....the one that they sell for this car E-0777
and the filter is all the way up so its sealed .... the metal thats under the filter is extreamly tight so the filter should not be moving no where i hope
On the highway u cant hear it......just crusing
if u have ur foot all the way down ....than u can hear it....usualy over 3,000rpms
Old May 9, 2007 | 01:17 AM
  #448
thought's Avatar
I just drilled a hole and hole clamped it - but whatever works!
Old May 9, 2007 | 09:58 AM
  #449
SS_SC_Cobalt's Avatar
this mod doesnt require cutting, just one small hole for the screwdriver...but whatever works for you
Old May 9, 2007 | 12:32 PM
  #450
SmOKe JeNsOn's Avatar
Hell I just took off the cover and used a couple of zipties to keep it from falling off doesnt look all that great but u can't see it anyway unless its on a rack.
