2.0 LSJ Engine: Airbox modification
Old Mar 3, 2008 | 02:05 PM
  #676
shsballa023's Avatar
Originally Posted by Mr_Slobalt
my gas mileage went to hell too! lol
Did you disconnect the battery? If not do that and let it sit for about 10 min. Then everything should be fine. Also check the fittings just to make sure everything is on right
Old Mar 19, 2008 | 12:19 AM
  #677
06superchargedbalt's Avatar
so after the box and everything is installed...you place all of the splashguards back on right?
Old Mar 19, 2008 | 12:24 AM
  #678
fiftyandsoco's Avatar
good thread. i am considering an airbox mod.
Old Mar 19, 2008 | 08:04 AM
  #679
SS_SC_Cobalt's Avatar
yes!
Old Mar 19, 2008 | 10:44 AM
  #680
suburbanrobot's Avatar
best bang for the buck mod out there
Old Mar 19, 2008 | 02:13 PM
  #681
x2!!!!!
Old Mar 19, 2008 | 02:57 PM
  #682
Originally Posted by shsballa023
x2!!!!!
Old Mar 19, 2008 | 08:20 PM
  #683
Mr_Slobalt's Avatar
yeah, I can't stay out of the gas and can't wipe the smile off of my face whenever I scare someone
Old Mar 21, 2008 | 10:35 PM
  #684
Routs's Avatar
Completed the Airbox Mod today. Had my AEM filter sitting on my shelf for about 10 months, so it's nice to finally have some time to put it on.
First impressions - really like the whine, although you don't hear it much until second gear. Pretty surprising once you roll down the window. It's a lot louder on the outside than what it sounds like inside. Hard to judge if there is any more power at all, but I'm sure it will breathe a little easier now.
Was a bigger pain to complete than I had originally planned on, but in the end the results seem nice.
Thanks, OP! Glad you put this together for all of us so long ago. If you don't mind, I'll take some pics later on that you can add to your write up. It took me a while to find all of the bolts and nuts to take everything off and that would have helped a bit more. All in all a good write up though.
Old Mar 22, 2008 | 12:07 AM
  #685
Mr_Slobalt's Avatar
Taking the driver's headlight out helps a lot!
Old Mar 22, 2008 | 07:33 AM
  #686
sure...AEM did a test and picked up 7-8 WHP I believe it said est with the filter
the mod takes into account that you know how to remove the airbox, but its really not that bad.
Remove screws for the weather shield (wheel housing) 2 bolts in front of the airbox, 1 to rear, remove the clamp for the pipe and disconnect the MAF. Hardest part is gettin the box out, as it is a twist and remove item LOL!
ya, thats a writeup all its own lol!! the HL can be a pain to get out too, but agreed it helps a LOT!
Last edited by SS_SC_Cobalt; Mar 22, 2008 at 07:34 AM. Reason: Automerged Doublepost
Old Mar 22, 2008 | 05:17 PM
  #687
Preowner's Avatar
My attempt
The last about airbox mods I remember seeing was in the intake thread, but they were hacking the box to hell. I don't object to that, but I also didn't realize how easy it would be to fab up a bracket to replace the box bottom. I had a replacement Fram filter for a while, was too lazy to put it in until I saw this howto. So here is what I did....
It doesn't do too much that I can tell. The car is tad more responsive, and it sharpens the edge to it's growl; but overall my exhaust realy overpowers much of the audible "benifits". Atleast it will hold me over until I get an aftermarket intake.
Old Apr 11, 2008 | 01:05 PM
  #688
1BadBlueSS's Avatar
Ok i am doing an different airbox mod but bolting on a peice of gutter guard mesh where the botton stock plastic part is..... So should I disconnect the negative battery terminal now or wait to see if i get a CEL??
Old Apr 11, 2008 | 01:38 PM
  #689
reset the fuel trims, unplug it for a bit
Old Apr 11, 2008 | 06:39 PM
  #690
Mr_Slobalt's Avatar
^ your paper filter will eventually get wet...I wouldn't doubt it
my stock filter enclosed in the housing was dripping when I pulled it out and it hadn't rained for days
I also never went through any puddles or car washes
Old Apr 13, 2008 | 05:59 AM
  #691
cobaltssredtint's Avatar
i did the same mod and im pretty happy with it.....makes the m62 louder
Old Apr 13, 2008 | 08:35 AM
  #692
Old Apr 13, 2008 | 09:17 PM
  #693
venum_us_2002's Avatar
i just got CEL 4 days after i did the airbox mod...im taking it to the dealership on tuesday for them to check out whats going on
Old May 19, 2008 | 03:08 AM
  #694
valentino0214's Avatar
it works awsome... and i can hear my supercharger again
Old Aug 7, 2008 | 09:47 AM
  #695
terry.davis1's Avatar
subscribed for home
Old Aug 7, 2008 | 11:48 PM
  #696
I love the airbox mod. I can't keep my foot off the gas I just love the whine!
Old Aug 9, 2008 | 10:37 PM
  #697
Bad05SS's Avatar
doing the mod tomorrow cant wait! i messed around with it a little bit today not knowing about this mod thread this helps a lot ill be at autozone in the AM!!
Old Aug 17, 2008 | 11:00 PM
  #698
BeradSS's Avatar
just did mine yesterday night and got a CEL today, car seems to be less responsive...gonna try taking it all apart and see if its the oiled filter that is causing the problems.
Old Aug 17, 2008 | 11:03 PM
  #699
make sure to reset the pcm and dont over oil the filter
Old Aug 18, 2008 | 09:34 AM
  #700
BeradSS's Avatar
possibly a nub question, whats the pcm?
