Appearance: How to: Antenna shave!!
the gain it you have a cleaner looking car. if u cut down the antenna you loose FM channels. the antenna i have has an amplifier built in so you dont loose channels.
once the rain stoped i her sanded it back down and redid it. after you us 2000 grit sand paper and use a buffing compond than wax the car you dont see and scratches. the plan blended in. ill post new pix soon.
One thing, why did you pull the antenna out and cut it? Why didn't you just undo the two bracket bolts in the trunk and pull it down, then you just have the thin rubber surround still in the trunk hole and can pull that from the top by hand... Since you had to custom wire things I guess it doesn't matter but pulling from the top could dent the surface around the hole...
Just a thought.
Just a thought.
