Appearance: How to: Antenna shave!!
Old Jul 17, 2011 | 08:45 AM
Ccadet02's Avatar
Originally Posted by JacBlackSS/TC
this is cool but what if you have on-star has anybody found a way to combine both antennas
there is ways to hide the antenna in the car itself and just have the onstar antenna on the out side. my car doesnt have onstar so i just whent with this.
Old Jul 17, 2011 | 08:47 AM
Ccadet02's Avatar
Originally Posted by Acey
So much work for zero gain. The antenna cut down to a stub is not any worse than a fin on the roof. To each his own.
the gain it you have a cleaner looking car. if u cut down the antenna you loose FM channels. the antenna i have has an amplifier built in so you dont loose channels.
Old Jul 17, 2011 | 08:50 AM
Ccadet02's Avatar
Originally Posted by cobaltsssc760
dude you can totally see the square that you sanded and the hole in the second set, third picture.
id deff leave this to the pros
once the rain stoped i her sanded it back down and redid it. after you us 2000 grit sand paper and use a buffing compond than wax the car you dont see and scratches. the plan blended in. ill post new pix soon.
Old Jul 17, 2011 | 08:53 AM
Ccadet02's Avatar
Originally Posted by tru2nrtt777
One thing, why did you pull the antenna out and cut it? Why didn't you just undo the two bracket bolts in the trunk and pull it down, then you just have the thin rubber surround still in the trunk hole and can pull that from the top by hand... Since you had to custom wire things I guess it doesn't matter but pulling from the top could dent the surface around the hole...
Just a thought.
what bolts?? when i got the car the antenna was loose. lol it wasnt much work getting it out.
Old Jul 17, 2011 | 09:14 AM
startingline05's Avatar
looks like **** in my opinion. you can see where the antenna was
Old Jul 17, 2011 | 06:22 PM
Ccadet02's Avatar
check out the updated pic.
Old Dec 26, 2015 | 05:29 PM
Ben Blonde Rupprecht's Avatar
i have a 2010, and have an antenna on the roof and the long one on the quarter, anyone have an idea why?
Old Dec 26, 2015 | 06:20 PM
One for the radio and I believe the one on the roof is for the on star or xmradio
Old Dec 26, 2015 | 06:44 PM
ATOMbomb's Avatar
Yep, roof antenna is xm and the long goofy one is radio.
Jan 12, 2016 12:01 AM
chefhhr
Oct 26, 2015 10:36 PM
Sep 27, 2015 08:53 PM
dieGone
Sep 23, 2015 10:20 AM
