Interior: How to change cluster, HVAC control, window and door lock to LED
Old May 13, 2011 | 07:49 PM
  #201
C_A_D88's Avatar
leds used
Old May 14, 2011 | 03:05 AM
  #202
BlueBalt1113's Avatar
what were the big ones used for the ones shown were the 3mm
Old May 14, 2011 | 08:44 AM
  #203
C_A_D88's Avatar
What? I used 5 mm 3 mm plcc-22 surface mount, and 0805 surfacemount
Old May 14, 2011 | 09:54 AM
  #204
RooTBeeR's Avatar
holy crap thats a lot of lights!!!
howd you get that ring around the centercap on the wheel?
Old May 18, 2011 | 08:36 AM
  #205
Leebs59's Avatar
Originally Posted by C_A_D88
Take the needles off
Yea but how am i supposed to take the needles off? Since they are screwed into the back?
Old May 18, 2011 | 11:59 AM
  #206
kento19's Avatar
i haven't taken it apart before so dont quote me if im wrong, but it seems like you just answered your own question. if they are screwed in, unscrew them. maybe you mean they are screwed in a different way.
Old May 18, 2011 | 02:55 PM
  #207
Leebs59's Avatar
Yea they are screwed in a certain way and it doesn't look like it will come off at all
Old May 20, 2011 | 07:22 AM
  #208
Leebs59's Avatar
Can someone tell me how you change the lights on the driver and passenger side door buttons for the lock switch and windows??
Old May 20, 2011 | 07:42 AM
  #209
NinjaHampster's Avatar
awesome
Old May 20, 2011 | 08:05 AM
  #210
C_A_D88's Avatar
First off, if your gOnna do your gauges, buy a black cat kit, comes with instructions
The needles basically just pull off, then there's some screws on the backside u gotta take off.
Old May 20, 2011 | 08:07 AM
  #211
C_A_D88's Avatar
I have another thread here somewhere, but basically I took out the stock one, replaced it with a black chrome center cap and put LEDs
Behind it
Old May 20, 2011 | 11:59 AM
  #212
RooTBeeR's Avatar
oh i gotya looks pretty nice
Old May 20, 2011 | 02:24 PM
  #213
gooty4life71290's Avatar
leds used
how did you get to the leds for the gear indicators cuz that looks sick!
Old May 20, 2011 | 05:49 PM
  #214
C_A_D88's Avatar
Took apart the shifter, pop the knob, pop the trim piece around it and there's a couple tabs holding on the top half of the shifter plate, I strung up a blue led strip in there as the stock is just one halogen bulb
Old May 23, 2011 | 07:02 PM
  #215
Leebs59's Avatar
Originally Posted by zerosk8ter83
i didnt replace the stock leds in the radio i just took them out and put a series of leds together in a row and place in the radio,power them up to a power source and bam(you pull the volume and power knobs on the radio to full take apart the radio)
What did you decide to use for the LEDs that you put together? Was it strand of lights that you could get at like Radioshack or something? Or did you put them in separately and wired them that way?
Old May 23, 2011 | 08:29 PM
  #216
RooTBeeR's Avatar
remove the original leds and solder in the color of your choice
Old May 28, 2011 | 12:36 AM
  #217
Leebs59's Avatar
What site did you use to buy the 0805 Surfacemounts??
Old May 28, 2011 | 02:17 AM
  #218
zerosk8ter83's Avatar
I use 2 leds for both sides and a led strip in the middle.
Old May 28, 2011 | 10:25 AM
  #219
C_A_D88's Avatar
oznium.com
Old May 28, 2011 | 07:14 PM
  #220
Leebs59's Avatar
I'm really curious to what size light you used for the PNRDIL panel??
Old May 29, 2011 | 12:50 AM
  #221
C_A_D88's Avatar
I had a bunch of 3pm LEDs left so I jerry rigged my own by soldering a bunch of um together and then soldering um to the bulbs wiring, stock bulb is TINY
Old May 29, 2011 | 03:47 AM
  #222
BlindSight's Avatar
HOW TO IT!?!??! lol nah but i really do wanna do that to mine dude looks amazing but sounds kinda complicated no lie
Old May 29, 2011 | 09:55 PM
  #223
kento19's Avatar
i just took a regular blue led and tapped it to the sunroof fuse. secured it next to my burnt out bulb and it glows nicely. not too bright.
Old May 29, 2011 | 09:59 PM
  #224
DiabeticKripple's Avatar
see i would do all this, but soldering something that small must be hard
Old Jun 1, 2011 | 02:16 PM
  #225
BlindSight's Avatar
ok so how do i get my guages back to normal lol after installing the LEDs i mean it turned out great just getting the needles back to their original spots is the problem now is this an easy fix or am i in some deep **** lol
