2.0 LSJ Engine: how to change your S/C oil (pics)
Old Nov 16, 2010 | 03:49 PM
  #76
CleanCut's Avatar
THANK YOU EBRISTOL! now im off to order the parts...
Old Nov 16, 2010 | 04:10 PM
  #77
sternerG85SC's Avatar
Originally Posted by ebristol
exactly what i was looking for, thanks alot!
Old Nov 21, 2010 | 05:56 PM
  #78
xxxxsh4d0wxxxx's Avatar
I've always been told take the blower off, lay it on a table, fill until it dribbles out, as you would the trans.
This is how I will be doing it when I change my coupler in a few days.
Old Nov 21, 2010 | 06:11 PM
  #79
chris88z24's Avatar
Horray for useless maintenance.
Old Nov 21, 2010 | 06:13 PM
  #80
When you do the coupler, you've got no choice.
Old Nov 21, 2010 | 06:16 PM
  #81
chris88z24's Avatar
Obviously. Stupid to drain and refill like it's motor oil, though.
Old Nov 21, 2010 | 06:25 PM
  #82
Not nessecarily, smaller pulley = gears/bearings/rotors, as well as high RPM's = Blower, (And blower internals/components), getting worked harder.
The fluid is going to break down faster than if it was stock with a smaller pulley, or than that if it wasn't driven in extremely high RPM applications, such as racing.
It's cheap any way you look at it, though.. $10 every 100,000 miles.. I think my wallet will be just fine.
Old Nov 21, 2010 | 06:27 PM
  #83
chris88z24's Avatar
Drive a little over 300,000 miles and you could buy a share of GM stock with all of that money you saved.
Old Nov 21, 2010 | 06:58 PM
  #84
megaman311's Avatar
Originally Posted by xxxxsh4d0wxxxx
i've always been told take the blower off, lay it on a table, fill until it dribbles out, as you would the trans.
This is how i will be doing it when i change my coupler in a few days.
epic fail!
Old Nov 21, 2010 | 07:32 PM
  #85
Originally Posted by megaman311
epic fail!
Not at all. This method puts 3.4oz in there, which is exactly what Eaton says. This is the correct way. There are even pictures in a different thread to prove this.
Old Nov 22, 2010 | 03:36 PM
  #86
i just got the zzp coupler kit for next spring. im going to replace the coupler and add the entire 6fl oz of ZZP S/C oil like it says on their site.
Old Nov 22, 2010 | 07:33 PM
  #87
megaman311's Avatar
6 oz is toooo much
I was not sure about this. But the amount is correct. I have always just measured it.
Last edited by megaman311; Nov 22, 2010 at 07:33 PM. Reason: Automerged Doublepost
Old Nov 28, 2010 | 04:40 PM
  #88
Shanedude's Avatar
11-21-2010 06:27 PM chris88z24 Drive a little over 300,000 miles and you could buy a share of GM stock with all of that money you saved.
How many people hit 300,000 miles+?
Supercharger oil change is good, cheap, peice of mind maintenance.
Old Dec 2, 2010 | 05:22 PM
  #89
CleanCut's Avatar
just changed my coupler/oil yesterday.. the old oil smelled pretty bad, kinda like burnt popcorn... checked the blower blades and they were kinda dirty and missing a bit of teflon and the housing was dirty as hell inside too.. cleaned everything up really good, greased the shafts, put new gaskets and the car seems to boost more/faster.. before the change, the most i would see was 10 psi and now its getting to 12 like when it was new
Old Dec 2, 2010 | 06:04 PM
  #90
dam that hasnt happend to me lol. my coupler is worn and rattling sometimes but im still boostin the norm 12psi.
Old Dec 2, 2010 | 07:18 PM
  #91
CleanCut's Avatar
maybe the altitude difference is going into play.. i live 400 feet below sea level
Old Jun 12, 2012 | 11:46 PM
  #92
jrmotosports 88's Avatar
click
Old Jun 13, 2012 | 06:35 AM
  #93
klotzy_550's Avatar
All the information for the supercharger oil is located in here.
FAQ for Superchargers
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
importkiller
Sep 30, 2015 07:18 PM
