Drivetrain: HOW TO Fix Linkage Roll Pin on Transmission
Old Mar 11, 2010 | 10:20 AM
  #151
ralliartist's Avatar
Originally Posted by 09blackonblack
reason i asked is my shifter seems really loose and wiggly
could be the same setup, I wouldn't know as I haven't looked at an F23. I know the F35 that's in the saturn L200 has a completely different linkage setup than our cobalts. Crazy that it's even the same trans.
Originally Posted by BNS06Mike
which way did you go about pushing the pin out?
i cant seem to figure out a way where the pin pusher is fitting well enough i can hit it with the hammer.
I pushed towards the driver's wheel. You can't hit the pusher very hard, not much room to work with. It's better to use a smaller hammer to just tap the pusher.
Last edited by ralliartist; Mar 11, 2010 at 10:20 AM. Reason: Automerged Doublepost
Old Mar 19, 2010 | 10:49 AM
  #152
venum_us_2002's Avatar
can someone explain why you need to take off the wheel?
Old Jun 19, 2010 | 01:28 AM
  #153
hatrickstu's Avatar
anyone got the factory part number for this? or a stronger solution than the POS roll pins from o'reilly's? ive gone through 2 of them in 2 weeks
Old Jun 19, 2010 | 08:05 AM
  #154
makes it easier to get to.
I used a grade 8 aircraft bolt shortly after making this how-to and never had a problem again.
Last edited by ralliartist; Jun 19, 2010 at 08:05 AM. Reason: Automerged Doublepost
Old Jun 19, 2010 | 02:38 PM
  #155
hatrickstu's Avatar
what size, and did you put a nut on it?
Old Jun 19, 2010 | 04:42 PM
  #156
yea it has a nut on it. I don't remember the exact size though. I'd go measure it but I'm not exactly within a 1000miles of my car at the moment.
Old Jun 25, 2010 | 11:47 AM
  #157
gpro's Avatar
What about the rollpin goes wrong that causes problems with shifting? Is it simply because it sticks out on the end and isn't flush like the new one is?
I'm trying to diagnose trouble I have with the shifter popping out of first gear and hesitating when shifting into second, and my roll-pin sticks out like the one in his picture. Is this a possible cause of my issue?
Old Jun 29, 2010 | 01:44 AM
  #158
KyFritz06SS's Avatar
Well 88,000 miles and its time for replacement. I will be doing this tomorrow or Wednesday. I love this site and its how too. Saved me time and money. Thanks again.
Old Jun 30, 2010 | 12:39 AM
  #159
Took me about and hour to get it done today. I hade to remove my upper tranny mount tho to tap out the remaning pieces of the stock pin. It broke in three places only reason it held together is because one piece was wedged in there nice and tight. The pin punch worked great and I bought a roll pin for 7 cents from a bolt company by me. My shifter has never felt better now I know why my cobalt shifted to shity could never hit third with the damn thing. This write up helped a ton even for working on my redline. I did not remove the wheel and everything worked just fine. Thanks again
Old Jul 2, 2010 | 09:12 AM
  #160
Killa702's Avatar
im stuck, i dont have a pin pusher so im tryin to use other things to push the pin out but nothings working. i dont know where to place the hammer so i can tap the pin, theres no room or anything, its pissing me off.
Old Jul 2, 2010 | 09:39 AM
  #161
northvibe's Avatar
ohhh more info on that would be nice
Old Jul 2, 2010 | 09:51 AM
  #162
Stiner's Avatar
I have a stronger rollpin that georgian bay Motorsports used on there race cars and they also hacked the weight off there, haven't had a problem since and the feel is barely different without that weight on there
Old Jul 18, 2010 | 04:51 AM
  #163
K2dogg86's Avatar
i love you man!!! NO HOMO. lmao
Old Jul 18, 2010 | 05:41 AM
  #164
I'm Air Force, where do you think I got the bolt from?
Old Jul 25, 2010 | 10:50 PM
  #165
tyler.avis's Avatar
^....lol
Old Aug 5, 2010 | 01:04 AM
  #166
EPro's Avatar
Hey guys could this be why my car might be harder to get into gear sometimes? I drove my buddies SS the other day and his shifter felt like brand new compared to mine.
It it's that cheap of a fix, I'll do it anyway. Or is this not applicable to my G5?
Old Aug 5, 2010 | 02:00 AM
  #167
Omega1x's Avatar
Nice write up. I wonder if this is the reason my car comes out of gear so easily and doesn't like to engage into 2nd and revers sometimes. Or would that be synchro's?
Old Aug 8, 2010 | 07:01 PM
  #168
could be either one.
Old Aug 8, 2010 | 07:19 PM
  #169
rallyracer's Avatar
grade 8 bolts are sold at Fleetfarm
Old Aug 10, 2010 | 12:51 AM
  #170
EPro's Avatar
I'm doing this fix this weekend, even it that's not my problem, it's an extremely cheap fix. That and I like to use any excuse I can to work on my car, lol.
Old Aug 11, 2010 | 11:20 AM
  #171
davidcroft's Avatar
Is this the same for SS/TCs? My car has very recently been very stubborn to go into first gear at dead stops. It doesn't do it all the time....just whenever it feels like.
Old Aug 11, 2010 | 02:21 PM
  #172
Yes, SS/TC's have the same setup for the linkage roll pins.
Old Aug 19, 2010 | 12:51 AM
  #173
EPro's Avatar
Where in the wheel well is the mount for the fuse box? I took the inner fender out and seen nothing. If it's not in there, I don't see why it's a necessary step?
Old Aug 19, 2010 | 01:01 PM
  #174
I don't know how you can miss the bolts. Are you looking on the engine bay side underneath?
Old Aug 22, 2010 | 02:34 PM
  #175
cranemaster's Avatar
My dealership said i "broke a pin/rod, inside the transmission?"
I have no 2nd 4th or reverse.. my dealership is taking 2 weeks to get a whole new tranny...
should I tell them about this issue / fix?
They might be clueless... I just wouldn't mind having my cobalt back... only 1,700km
I signed up on this forum just to bump this and ask what people think.
my backup ride is supposed to be sold.. now im still driving it
