Appearance: How to: HID installation
Old Jan 27, 2010 | 10:42 PM
  #126
Brenticus's Avatar
looks easy enough, but sub'd just in case.
Old Jan 27, 2010 | 11:32 PM
  #127
tom.g's Avatar
Originally Posted by MP81
That ZZP kit should work.
That looks awesome, actually doesn't seem like the light is too scattered at all. Thanks alot for the pic
I think I will be getting the ZZP kit very shortly.
Old Jan 27, 2010 | 11:51 PM
  #128
MP81's Avatar
No problem! Glad to help.
Old Jan 28, 2010 | 07:54 PM
  #129
trey ss's Avatar
so u just replace the low beam, wich is the projector on the the 1st gen. and the high beams stay the same? or do they the lows stay on when u turn on the high with thes kit???
Old Jan 28, 2010 | 09:34 PM
  #130
Tazmanian_Dvl's Avatar
Seriously check out www.ddmtuning.com. Slim ballasts, life time warranty, best prices I've been able to find anywhere, FAST shipping, easy installation and they look awesome!
9007 hi/low full kit are like $69.95 and H11 fogs are like $49.95. Here's the link...
http://www.ddmtuning.com/index.php?p...=101&parent=85
Old Jan 28, 2010 | 09:55 PM
  #131
i been sayin ddmtuning is good stuff for a while. i run them in my bike
Old Jan 29, 2010 | 12:38 AM
  #132
tom.g's Avatar
Do you know for a fact that the DDM 9007 hi/low full kit will work in our cars in specific my car an 09 lol?
Also is the HID wiring harness (http://www.ddmtuning.com/index.php?p...=133&parent=94) necessary? This how-to (https://www.cobaltss.net/forums/showthread.php?t=92078) makes it seem like it is.
Old Jan 29, 2010 | 01:04 AM
  #133
kissrocker52's Avatar
i have the same question im looking to by HIDs soon and dont want to order the wrong thing
Old Jan 30, 2010 | 11:11 AM
  #134
I know for a fact the 9007 hi/lows work in our cars. I have an 06 and I had no problems. However I don't know if the newer models have warning lights for if lights burn out. DDM does have something to help with that problem too.
The Hi/low lights come with their own wiring harness so there is no need to purchase one.
Old Feb 1, 2010 | 08:13 PM
  #135
efactor's Avatar
Thanks for the post buddy. I gotten my DDM 9007 Hi/low in was confused with it, but that was really helpful. Thumbs up!
Old Feb 1, 2010 | 10:59 PM
  #136
NP. Lemme know if you have any questions. I'm happy to help...
Old Feb 1, 2010 | 11:36 PM
  #137
tom.g's Avatar
How complex is the install? Is it just like in the how-to (https://www.cobaltss.net/forums/show....php?t=92078)?
Old Feb 2, 2010 | 09:47 AM
  #138
Took me about 10 minutes to install and about 10 minutes to make sure everything was tucked away to my liking...
Old Feb 2, 2010 | 10:44 AM
  #139
efactor's Avatar
how did you install the foglights? did you remove the front bumper off or did you remove the headlight bracket to have easy access to the fog lights?
Old Feb 2, 2010 | 12:10 PM
  #140
you don't need to remove the headlight bracket to reach in there for the fogs unless you have chubby arms. the other way you could do it is to take the screws out of the splash guard underneath the bumper and they are right there
Old Feb 2, 2010 | 02:04 PM
  #141
efactor's Avatar
did you leave both ground wires on both ends with the stock and the aftermarket?
Old Feb 3, 2010 | 06:34 PM
  #142
I have no idea what you're talking about. You hook up the wiring harness provided with the high low kit to the positive battery post under the hood. The you hook up the ground wire to a solid ground. Then you push the pins into the connector provided (looks like the plug on the back of the 9007 headlights) and plug that into the factory plug for you headlight on the drivers side (this is just so it can tell when the lights are on and off and when you have the high beams on it draws the power for the system from the auxiliary harness that comes with the kit). Then you install the HID bulbs in the housing and plug in the ballasts (one end goes to the harness that came with the kit and the other goes into the bulb). Then hide all the wires and you're done.
edit: This is for the DDM kit. I can't comment on kits from any other manufacturer...
Old Feb 4, 2010 | 10:25 AM
  #143
efactor's Avatar
Got my DDM HID kit done. I grounded both the wires under the headlight brackets where the screw holds it in place for the headlights to sit properly, hooked the positive to the circuit breaker where the rod is. The ballasts are really concealed along with the box and tucked the wire harness under the grill. The only thing you can see is the red wire and I'll have that covered up soon. Just got to get my hi beams to work right because it looks backwards when I turn them on. Just going to take the blue connector and switch the two wires around and that should solve the problem other than that those are some good HID's from DDM Tuning. I'll post some pics soon.
Old Feb 4, 2010 | 10:27 AM
  #144
swazzees's Avatar
thanks for the info
Old Feb 5, 2010 | 04:56 PM
  #145
Yea when you look at the bulb the high beam is when the glass part of the bulb is sucked into the base. If you turn them on with one bulb outside of the housing you can watch it move up and down. Switching the two outside wires on the plug should do the trick. I had to call them and ask them about this...
Old Feb 6, 2010 | 01:16 PM
  #146
jrsur13's Avatar
the kit that i have u don't have to ground nothing it is really plug and play
Old Mar 5, 2010 | 05:36 PM
  #147
ayellaone's Avatar
i have an 06 ls coupe, and i bought plug and play 12000s for the 9007. the hid blue comes on only the brights and normal are yellow. how do i fix this. anyone help?
Old Mar 15, 2010 | 02:10 AM
  #148
Owen S's Avatar
So I recently bought HIDs at a car show. Turns out they sold me 9004's instead of 9007. I repinned them, and they work great now. Anyone know anything about reliability and longevity of the lights if I'm using them differently. Everything is stock.
Old Mar 20, 2010 | 01:56 AM
  #149
chadnky's Avatar
So I put a set of HID's in for a buddy of mine today on a 2006 chevy cobalt lt. He claims he bought the bi xenon bulbs for his headlights, however, his brights don't work when you turn them on, but his low beams work fine. The set came with a relay harness which I hooked up with the extra plug on the passenger side that doesn't plug into anything. Can anybody help me with this?
Old Mar 23, 2010 | 09:03 PM
  #150
pickin my brother up's Avatar
i have this same kit and my passenger side headlight comes on at first but then turns off. itll come back on for a second if i turn the lights on and off, but can anyone tell me why this is happening? its like im not getting enough power to the passenger side bulb i guess
