Appearance: How to: HID installation
im trying to sort thru all of the bickering and get wut i need. I got this kit right here...
http://www.ddmtuning.com/products/Ap...it-200-85.html
it shuts off when voltage is low. so i wouldnt have to worry about drl's right? i drive an 06 btw..
also, wut is needed to modify the 3rd gen projectors to take the h1 hid bulb
i didnt drill into my car, i just got some double sided tape and slapped the ballasts somewhere where it would fit.
i recommend that if you aren't handy with a drill lol
just dont put the ballast on a plastic surface because the tape will not stick
so I have a wire with a green tip and I dont know where it goes. I removed it and cant figure out where it goes. It's causing my drivers side headlight not to turn on. Would appreciate it guys thanks.
Okay someone please tell me if I have this wrong, because I want to be right before I do this. I have third gen projectors. I sorted through all the nonsense in here and have this so far. The two wires coming out of the blue plug that normally power the low beam I use to power the ballast. By simply hooking up the negative to the neg and teh pos to the pos on the harness they gave me. Then that gets plugged into the ballast and then the ballast to the lights. Why is everyone saying I have to hook into the battery too? IO am very confused, could someone get me A diagram or a pic by pic of the wiring. I am very paranoid to ruin the wiring on my car. Also is the relay necessary? I keep getting mixed answers and no straight ones.
I'm assuming that if you don't have projectors there is no cut off line with the type of HID's that the OP put on correct? So to avoid blinding other drivers does adjusting the headlight to point down help?
Also does anyone have any pics of what these types of HID's look like when on?
^ That looks great MP81
Thank you very much for your prompt response, you wouldn't happen to have a pic with your lights pointed at a wall or something would you, I wana get an idea of how high and how far they shine.
I was seriously debating on getting this 6000K kit from ZZPerformance http://www.zzperformance.com/cobalt_...=617&catid=144 (I think it will work on my 09 lol)
