Appearance: How to: HID installation
Old Mar 2, 2009 | 02:15 PM
  #101
I agree with you Mp, love the sig btw
Old Mar 2, 2009 | 02:33 PM
  #102
MP81's Avatar
Thanks - that was taken at my work, believe it or not, haha.
Old Mar 3, 2009 | 05:44 AM
  #103
where do you work?!
Old Mar 3, 2009 | 07:09 AM
  #104
MP81's Avatar
In Michigan.
I'm on top of a hill, on some clear days, from the right direction, you can see Detroit (and I'm like 30-40 miles from Detroit).
Old Mar 3, 2009 | 10:42 AM
  #105
damn thats sweet!
Old Mar 4, 2009 | 07:29 PM
  #106
Zdeuce4's Avatar
im trying to sort thru all of the bickering and get wut i need. I got this kit right here...
http://www.ddmtuning.com/products/Ap...it-200-85.html
it shuts off when voltage is low. so i wouldnt have to worry about drl's right? i drive an 06 btw..
also, wut is needed to modify the 3rd gen projectors to take the h1 hid bulb
Old Mar 4, 2009 | 11:34 PM
  #107
hope you had your boots on and made it ok. just pull the drl fuse and youll be fine, 3rd gens someone else will have to answer
Old Mar 4, 2009 | 11:38 PM
  #108
Zdeuce4's Avatar
i got an answer in my thread so im good now
Old Mar 11, 2009 | 08:46 PM
  #109
ilovecars's Avatar
how the hell did you mount the ballasts? do you have holes there cuz i sure as hell dont
Old Mar 11, 2009 | 08:49 PM
  #110
MP81's Avatar
Just use self-tapping sheetmetal screws...
Old Mar 11, 2009 | 08:50 PM
  #111
ilovecars's Avatar
huh......i feel like an idiot. would i have to pre drill the hole?
Old Mar 12, 2009 | 12:28 AM
  #112
hossdeuce's Avatar
i didnt drill into my car, i just got some double sided tape and slapped the ballasts somewhere where it would fit.
i recommend that if you aren't handy with a drill lol
just dont put the ballast on a plastic surface because the tape will not stick
Old Mar 13, 2009 | 09:07 PM
  #113
Nighthawk243's Avatar
I put the bracket on mine and just held them in by putting the headlight housing brackets over top of them and tightening them down
Old Mar 13, 2009 | 10:36 PM
  #114
mine were under my headlights theres a flat piece of body there, i used double sided tape and self tapping screws for added protection
Old Jul 29, 2009 | 08:23 AM
  #115
Sweetsandman's Avatar
bump cuz I'm going to need this today.
Old Sep 2, 2009 | 02:02 AM
  #116
Maccoy316's Avatar
so I have a wire with a green tip and I dont know where it goes. I removed it and cant figure out where it goes. It's causing my drivers side headlight not to turn on. Would appreciate it guys thanks.
Old Sep 2, 2009 | 02:14 AM
  #117
stoon_cobalt_colby's Avatar
anyone car to make a how to on how to install hid kit in 2nd gen projectors?????
Old Sep 2, 2009 | 02:16 AM
  #118
Maccoy316's Avatar
Old Jan 10, 2010 | 12:56 PM
  #119
Fallout's Avatar
Okay someone please tell me if I have this wrong, because I want to be right before I do this. I have third gen projectors. I sorted through all the nonsense in here and have this so far. The two wires coming out of the blue plug that normally power the low beam I use to power the ballast. By simply hooking up the negative to the neg and teh pos to the pos on the harness they gave me. Then that gets plugged into the ballast and then the ballast to the lights. Why is everyone saying I have to hook into the battery too? IO am very confused, could someone get me A diagram or a pic by pic of the wiring. I am very paranoid to ruin the wiring on my car. Also is the relay necessary? I keep getting mixed answers and no straight ones.
Old Jan 10, 2010 | 09:22 PM
  #120
MP81's Avatar
I have an HID kit in my stock housings and it was simple plug and play. No relay, and no outside tap into the battery.
Old Jan 27, 2010 | 10:25 PM
  #121
tom.g's Avatar
I'm assuming that if you don't have projectors there is no cut off line with the type of HID's that the OP put on correct? So to avoid blinding other drivers does adjusting the headlight to point down help?
Also does anyone have any pics of what these types of HID's look like when on?
Old Jan 27, 2010 | 10:27 PM
  #122
kissrocker52's Avatar
sub'd for when i order my lights
Old Jan 27, 2010 | 10:28 PM
  #123
MP81's Avatar
Mine aren't really aimed up into people's eyes, it seems.
My car, Stock housings, 8K Lows:
Old Jan 27, 2010 | 10:38 PM
  #124
tom.g's Avatar
^ That looks great MP81
Thank you very much for your prompt response, you wouldn't happen to have a pic with your lights pointed at a wall or something would you, I wana get an idea of how high and how far they shine.
I was seriously debating on getting this 6000K kit from ZZPerformance http://www.zzperformance.com/cobalt_...=617&catid=144 (I think it will work on my 09 lol)
Old Jan 27, 2010 | 10:41 PM
  #125
MP81's Avatar
That ZZP kit should work.
