Drivetrain: How to Install Axles and CAB's (56k time to upgrade)
Old Mar 8, 2007 | 09:05 AM
  #51
SS33's Avatar
Italian Joe,,, I had another suggestion for ya. A friend of mine (SSpartan on here) wants to do the trans mounts too, but is pretty concerned about the vibes. So we are looking into drilling some holes in the bushings for his to soften them up a bit.
(These are how the RK trans mounts on my cavy are made, sorry for the blurry pic)
I can't think of any reason that this wouldn't work, on our cars as well. So long as the holes are cut cleanly, not too big, and don't have any jagged edges to lead to failure later on. I've never drilled into Poly before so I don't know how difficult this will be or if any special tools would be required. But I imagine anyone with the right tools and patience would be able to pull it off with a drill press and a carbide bit. Might be an option. Any one else have any opinions on this?
I'm happy with mine as is, but people wanting to minimize vibrations this could be a solution,,, anyone wanna be a guinea pig? I'm not sure when SSpartan plans on doing his,,, I know he already has the bushings, and we'll be doing the install in my garage, but I have no drill press, so I left that part on him.
Old Oct 11, 2007 | 09:40 AM
  #52
R&C_rallySS's Avatar
This is a great write up. I did my clutch/flywheel and pressure plate and thought why not swap out the axles since I'll be right there. Everything went well with the axles, the clutch/flywheel was another story. Have a few questions:
1.) The axles are installed correctly if you put eveything back together and it all fit well. Rolled the car out of the garage because the clutch is not bled yet. If the axles were not installed correctly tranny and mainshaft would not of connected right? Also would of had problems pushing the car? I'm such a newbie to this kind of mods. I just don't want to start the car and be rolling down the road and my axle come out or something lol.
2.) Some people seem to use 75w-90 Max Gear Oil (Royal Purple) for the tranny fluid, is that a correct fluid for the LSJ tranny?
Old Oct 11, 2007 | 09:54 AM
  #53
SS33's Avatar
I haven't done my clutch/flywheel yet, so my LSJ/F35 knowledge there is rather limited. But it's pretty easy to tell if the axles were properly installed or not. Visually you can tell if they are fully seated at the trans housing, (or intermediate shaft on the Pass side.) If they are fully seated on the inner side, than there really isn't any way to mess them up if everything went back together proper.
The outers are controlled by the hubs and front componenets, so if you got everything to bolt back up you should be good. If those things are right than there is no way for the axle to come out while you are driving down the road.
I'm not sure if that is the right Royal Purple fluid or not. I just used the GM/Saturn stuff when I did mine.
Old Oct 11, 2007 | 09:59 AM
  #54
Thanks alot. Something just did not look right on the one side (forget which side) It looked like the axle was not all the way in however everything did bolt up no problems. When I tried to pull the axle back out (to see if it was in all the way) it would not come out. There was a ever so slight of gap between the axle and where it went into the transmission. I guess since it all bolts up fine it must be ok. Anyways, +rep and thanks for the info. Now all I need to do is buy some break fluid DOT3 Hydrolic fluid, find out if I can use the Royal Purple stuff I mentioned before. Where is the best place to buy CABS?
Old Oct 11, 2007 | 10:03 AM
  #55
SS33's Avatar
Hard to say without seeing a pic of the gap you're talking about. But it sounds like you'll be ok.
As for CABs I'd suggest INTENSE. But I have a set of the JBP CABs lying around, PM me if you're interested.
Mine are in good shape, but I saw a thread where a guys fell apart, so I ordered the new style from INTENSE. But I have a guy that can getthese refilled if they ever do go bad.
Anywho, if you want em lemme know and I'll make you a good deal.
Old Oct 11, 2007 | 02:38 PM
  #56
ItalianJoe1's Avatar
Yeah, that was me. I had JBP ones, the ones I took pics of installing for this thread. They lasted about 4 months and both were shot. I bought the Intense ones and they seem to be good so far, but i really haven't checked them.
Old Oct 11, 2007 | 04:20 PM
  #57
SS33's Avatar
^Yeah I've been happy with my Intense mounts so far.
My JBP ones were in good shape when I pulled them off, but I didn't wanna risk it.
But the owner of Cobaltperformance parts said he can get them refilled with better poly for really cheap, so if anyone wants them it's def. a cheaper way to get some CAB's
I'll let mine go for $100 shipped. And you can use them as is,,, but check them regularly, just to be safe. Or send them to him and get them re-filled for a few bucks.
Old Oct 11, 2007 | 04:23 PM
  #58
I have to check, I had a local SRT-4 shop looking into spherical ball mounts, I gave them my blasted JBP ones as templates. Gotta swing by there and check soon.
Old Oct 12, 2007 | 02:37 AM
  #59
Pjherring's Avatar
Will these work on a 2003 saturn ion 2.2l l61
Old Oct 17, 2007 | 01:18 AM
  #60
Beck's Avatar
pm sent regarding CAB's
Old Oct 17, 2007 | 01:21 AM
  #61
an0malous's Avatar
oooooo nice howto!
my S2 axles arrived today so ill be getting good use out of this!
Old Oct 17, 2007 | 07:01 PM
  #62
SS33's Avatar
replied
Originally Posted by an0malous
oooooo nice howto!
Thanks man, good luck with the install
Old Oct 18, 2007 | 07:13 PM
  #63
Pjherring's Avatar
ANYONNEE???
Old Oct 18, 2007 | 07:15 PM
  #64
hatrickstu's Avatar
this is a very very good howto, but now than im an axle changing expert (i can do one side in about 15 minutes), there are a few short cuts
Old Oct 18, 2007 | 07:17 PM
  #65
Blown 4-banger's Avatar
Hmmm, where'd you get your latest axles? A real bad ass musta sold em to ya
Old Oct 21, 2007 | 08:45 PM
  #66
SS33's Avatar
YEah It can be done alot quicker for sure, but I did my CAB's at the same time so I just went through a much more thorough tear down.
I upgraded to the DSS right away, didn't wanna hafta do it again, lol
Old Oct 24, 2007 | 11:35 PM
  #67
BigTizzle903's Avatar
where did you get your axles and CABS from?? and how much they run ya?
and can the axles/CAB/rest of the stuff down there for an SS be used on a 2.2??
Old Jan 26, 2008 | 10:50 PM
  #68
an0malous's Avatar
Id like to say a big thanks.
this howto was invaluable for me today during my axle install.
cheers mate.
Old Jan 26, 2008 | 10:56 PM
  #69
SS33's Avatar
cheers mate.
Thanks man, Glad to be of assistance,
enjoy your new axles :two thumbs
Old Jan 26, 2008 | 11:24 PM
  #70
Mr_Slobalt's Avatar
Do they make black inserts for the control arms? I hate that everything has to be a different color than stock. To me it throws a red flag at the dealer.
Old Jan 27, 2008 | 05:35 PM
  #71
SS33's Avatar
Yeah they do,, I've actually since swapped mine out for the INTENSE CABs, they are black poly
Old Feb 22, 2008 | 11:05 AM
  #72
RS75GT 1SS's Avatar
Anyone know where I can find beefier axles for my LE5/F23?
Old Oct 20, 2008 | 12:16 PM
  #73
arkkornkid's Avatar
sub'd for necessity
Old Oct 29, 2008 | 08:15 AM
  #74
FrankTheTank's Avatar
click
Old Nov 6, 2008 | 06:12 PM
  #75
SS33's Avatar
Originally Posted by FrankTheTank
click
click, boom
