2.0 LSJ Engine: "How to" Install COMP/ZZP S1 Cams, Supertech 75# Valve Springs, & GMR Cylinder Head
Old Mar 8, 2013 | 07:27 AM
Staged07SS's Avatar
Administrator
Administrator
Originally Posted by LJD07SS
glad to see all the hard work jeff..can not wait to see your car in person...hopefully i can do this mod soon
Thanks buddy!
Old Mar 13, 2013 | 02:51 PM
RoelSS's Avatar
Very nice & clean job Jeff! Any sound clips?
Old Mar 13, 2013 | 04:46 PM
Staged07SS's Avatar
Administrator
Administrator
Thanks Roel! Long time no talk.
I have a clip, but it isn't the best quality. I will get a better clip soon, and post it in here.
Old Mar 13, 2013 | 07:13 PM
RoelSS's Avatar
Yes it's been a while. My wife and daughter have pretty much taken over the cobalt lol! Rest assured it's still modded and still kicks ass when needed
Throw the vid on you tube and send me the link... this I have to hear...Must sound real nice!
Old Mar 14, 2013 | 07:15 AM
Staged07SS's Avatar
Administrator
Administrator
Will do buddy, and good to hear the Cobalt is still modded.
Yeah, it has a nice mild lope to it.
You can feel it in the car idling at a stop light. I love it.... Not to mention the added power
Old Mar 14, 2013 | 02:27 PM
Staged07SS's Avatar
Administrator
Administrator
Spoke to Andrew @ Complete Street Performance (performance shop about 2 hours from me), and I should be getting the car dyno'd in April or May....
Old Mar 19, 2013 | 06:21 PM
RoelSS's Avatar
Nice! Can't wait to see your results
Old Mar 20, 2013 | 07:07 AM
Staged07SS's Avatar
Administrator
Administrator
I'm going to do a pull in 93 octane mode, and a pull in H.O.M.
Old Mar 20, 2013 | 10:05 PM
zrated89's Avatar
we can compare dyno sheetz!!
Old Mar 21, 2013 | 07:08 AM
Staged07SS's Avatar
Administrator
Administrator
I bet my peak horsepower is as much as your horsepower at 2000 rpm, hah!!
Old May 14, 2013 | 11:51 PM
  #36
supercharged steve's Avatar
Ive got the s2 cams. it lopes like crazy man. im still getting the p0315 code tho. I know everything is timed right. ive done it 4 different times. it used to drive fine, but this morning it would not start. I changed the crank position sensor and it fired up. but once I give it any throttle it dies on me everytime.
Old May 15, 2013 | 12:24 AM
  #37
c130aviator's Avatar
crank relearn?
Old May 15, 2013 | 07:19 AM
  #38
Staged07SS's Avatar
Administrator
Administrator
When did you purchase your S2 cams?
If you check out the TVS thread, there is talk in there about some S2 cams being out of spec (base circle is too large). You might be having the same issue as those guys.
Old May 15, 2013 | 07:35 AM
  #39
Omnigear's Avatar
how much time did you save by not taking the head out of the bottom?
Old May 15, 2013 | 07:58 AM
  #40
Staged07SS's Avatar
Administrator
Administrator
I couldn't tell ya.
I never removed the head before, but I would imagine the way I did it would be quicker.
With my install, I wasn't really trying to save time, but wanted to limit how much I needed to remove.
Old May 15, 2013 | 12:49 PM
  #41
DarkChild's Avatar
^ I am in the process of putting my head back on my car so I think I can answer this question nicely. I had my head ported and what not. I also bought the supertech springs. Anyway, here is a list of what I bought through Tom @ CED:
1 12601810 Cylinder Head Gasket Kit Saturn Ion 2.0 LSJ 2004 - 2007 12601810
$140.51
1 24435052 Ecotec Front Cover Gasket 24435052
$19.86
1 90537687 Ecotec LSJ 2.0 Valve Cover Gasket 90537687
$42.52
32 90354648 Ecotec Valve Keepers (Key) 90354648 I was a little careless when removing the keepers so I advise to keep a keen eye out for these small things to avoid racking up the bill.
$107.84
1 12578146 SEAL 12578146
$10.55
1 12600009 SEAL, CM/SHF POSN SEN HSG OIL (O RING) 12600009
Can't wait to see a video and dyno of this setup.
Old May 15, 2013 | 10:29 PM
  #42
Omnigear's Avatar
I couldn't tell ya.
i would have cracked open the head, since its a few bolts away, and look how the engine is looking ^_^ specially since its not your DD.
Old May 15, 2013 | 10:42 PM
  #43
Cobalt_SSTuner's Avatar
Thank you for this!
Old May 16, 2013 | 07:19 AM
  #44
Staged07SS's Avatar
Administrator
Administrator
I only have 48k miles on the car, never been to the track, and I'm the original owner. Trust me the engine is mint.
No need to do extra work in my case.
If you only knew how meticulous I am with my car.
$140.51
$19.86
$42.52
$107.84
$10.55
Good stuff. Thanks for adding your info man.
My car looks like she will be hitting the rollers in the fall. I have too much going on with wedding planning and such.
Originally Posted by Cobalt_SSTuner
Thank you for this!
You're welcome. PM me anytime with questions you may have.
Old Jun 28, 2013 | 12:40 AM
  #45
1BadBowtie's Avatar
Sweet
I have the same cams. Easy to install. Not over aggressive with noticeable mid to top in power gains.
Old Jun 28, 2013 | 07:08 AM
  #46
Staged07SS's Avatar
Administrator
Administrator
Agreed!
Thanks for posting.
Old Jun 29, 2013 | 08:44 AM
  #47
DarkChild's Avatar
I'm currently still waiting for my intake manifold to be welded up. I'm getting frustrated now. I just want to drive my car. I think the cams will more than likely happen. I would like to hit 300 whp with an M62 and pump gas.
Old Jul 19, 2013 | 01:43 AM
  #48
DFZ24's Avatar
question,
by any chance, like a remotely chance... would this apply for the LE5? the procedure?
Old Jul 19, 2013 | 07:09 AM
  #49
Staged07SS's Avatar
Administrator
Administrator
Originally Posted by DFZ24
question,
The LE5 will be similar, but it is more along the lines like the LNF due to the variable valve timing.
Installing the valve springs will be exactly the same though.
Old Jul 19, 2013 | 08:36 AM
  #50
JapEatr's Avatar
South Central *********
Exactly, the vvt cam gears require a different bracket to hold timing. If you find the jtool number for those, let me know
