Interior: How To: Install a Double-DIN Aftermarket Headunit in your 05-06 Cobalt SS
Old Jul 1, 2012 | 03:38 AM
  #76
EmperorJJ1's Avatar
Originally Posted by Vinjpal561
well i just bought a Pioneer AVH-P3300BT and putting it in my ss but the guys at my local audio shop said that if i dont get the PAC witch i just ordered last night, that if i ever needed to bring it to GM for what ever reason that some of the computer **** is all linked up with on star and the head unit witch i think is bs but i also didnt want to loose all my door chimes and stuff like that. so now i have the head unit and the PAC thing for the onstar and the mounting kit. what else do i need????????
what yr is ur car
Old Jul 3, 2012 | 07:59 PM
  #77
Vinjpal561's Avatar
2006
Old Jul 4, 2012 | 12:47 AM
  #78
EmperorJJ1's Avatar
door chimes are in the speedo so if the pac has additional chimes then you will have 2 chimes
Old Jul 4, 2012 | 08:39 PM
  #79
Derke's Avatar
I bought the thing with the extra chime.. ended up desoldering the wires inside the module .Hahaha. Whoops.
I hate the GM chimes. So much hate. I wish I could remove them completely.
BONG BONG BONG BONG BONG BONG BONG
Old Jul 5, 2012 | 12:32 AM
  #80
EmperorJJ1's Avatar
trade your car in for an 07 remove the radio and there u go
Old Jul 6, 2012 | 05:25 AM
  #81
Derke's Avatar
How about an aftermarket spedometer? Or something..
Old Jul 11, 2012 | 12:01 AM
  #82
Cobalt08LS's Avatar
got my double din wired up. gotta cut that rear beam out tomorrow because it doesnt fully fit. its held for now with just 2 bolts. cant put the dash trim back on. but after i cut the beam out it should be good.
going to try wire cutters i dont have a saw or dremel
Old Jul 11, 2012 | 12:40 AM
  #83
Derke's Avatar
The metal piece, or the plastic? The plastic should be easy for any sharp edge. The metal, you know, you can just unbolt. You don't need to cut it. I just couldnt fit a wrench in there and didn't want to bother.
Old Jul 11, 2012 | 04:42 AM
  #84
wRcKLes's Avatar
sub'd sub'd sub'd seriously going to need this thank you I having the same no sound issue everything powers up just no sound
Old Jul 11, 2012 | 05:23 AM
  #85
EmperorJJ1's Avatar
if u have the pioneer system u have to give the amp remote. there should be a blue remote or antenna wire in the harness u bought. if not the pink wire on the car end "should" be the remote for the stock amp
Old Jul 11, 2012 | 06:19 AM
  #86
Cobalt08LS's Avatar
looked briefly and i think its the metal piece.
i dont remember seeing a plastic piece. im going to look at it today. all i know is i couldnt put it straight back because the back of the double din was hittin the back metal piece.
after i unbolt the metal piece the double din will be able to go further back and the holes for the install kit will sit flush with the car right
Old Jul 11, 2012 | 06:54 AM
  #87
EmperorJJ1's Avatar
right. but there should be plastic in the way before the metal. If not then this was already cut out so no worries
Old Jul 11, 2012 | 08:41 AM
  #88
Cobalt08LS's Avatar
yeah i already had a single din. Bestbuy did the original install in 2009 on my sony. I bought the upgraded model of that 2009 model in 2011 (same thing just upgraded design and interface)and i changed it myself. I just took that 2011 Sony model out for a JVC KW-AV60BT.I got a GREAT price on ebay BRAND NEW. Too good to believe seeing how much it is on Crutchfield Best Buy AND Sonicelectronix. Lets just say for the double din, JVC iphone/ipod interface cable, install kit AND an adapter that fits my Lifeproof Iphone case( obv not needed if you dont have a Lifeproof case for iphone), I got everything for cheaper than the Double Din alone if one was to buy it at one of those 3 places i listed above. I didnt see this plastic. Best Buy probally got rid of that when they installed my single sony din in 09. i did see the metal that was connected to the everything back there. on the sides and everything. so you just have to unbolt it? or just cut the left side and right side and remove the bolt on the right.
Old Jul 11, 2012 | 09:43 AM
  #89
EmperorJJ1's Avatar
u can remove it however u see fit but if you have a 1/4 ratchet a 7mm socket and some determination then it will unbolt with no cutting required at all.
Old Jul 11, 2012 | 10:11 AM
  #90
Gelladuga69's Avatar
What do you guys have connected to the back of your Double DINs?
Mine fits fine with no modification and I have a huge HD Radio tuner box under mine as well.
Old Jul 11, 2012 | 10:25 AM
  #91
Cobalt08LS's Avatar
yeah i have that! well i may not have the small ratchet my friend probally does. because i was using a small ratchet yesterday because thats what my friend had but im sure thats EXACTLY what ineed to remove that back bar.
after its out just line the install kit up and bolt it in right.?
Old Jul 11, 2012 | 10:28 AM
  #92
Cobalt08LS's Avatar
the harness that came with it that is wired to the PAC harness. i have 3 video cables too for my iphone/ipod interface. and the back of the din hits that bar. each double din dimensions are diff.
Old Jul 11, 2012 | 10:29 AM
  #93
I have an AVH-4300DVD.
I have an Axxeses harness with one of those small black boxes. I dunno, everything fits in fine with my iPhone video cable, video bypass, aux, and HD tuner.
Old Jul 11, 2012 | 11:26 AM
  #94
Cobalt08LS's Avatar
yeah maby your measurements are smaller than mine. im just going to unbolt the metal bar and slide the din back and it should be good to go
Old Jul 11, 2012 | 05:03 PM
  #95
Cobalt08LS's Avatar
turns out i did have the plastic! went to town with wire snips at the corners. broke it in half. than snipped the other side.
gettin to the bolts was cake. used a normal size ratchett but this is a twisty one that turns 365 degrees. worked like a charm.
Old Sep 3, 2012 | 04:04 PM
  #96
06SS ALL DAY's Avatar
12 hours for a radio? Stop eating zannies n smokin blunts bro
Old Sep 3, 2012 | 04:20 PM
  #97
Derke's Avatar
lolll
Most of it was phonecalls and such, dont forget. I had to figure out how to do all the wiring, and have never installed a headunit before in my life.
Wrote this up so it doesn't take everyone else 12 hours.
Also I had a few beers, dont judge
Old Sep 3, 2012 | 04:48 PM
  #98
EmperorJJ1's Avatar
lol that came from out of no where
Old Dec 5, 2012 | 08:04 PM
  #99
tomj77's Avatar
i got an issue. with the C2R-GM24 harness installed, my newly installed viper smart start system is causing rear speaker noise whenever the car gets a signal from my cell phone. very annoying. i can exactly unplug it cause then my deck doesnt work, but when i do, noise goes away. so is there any other harness i can use to maintain factory chimes and such? wanna try a diff one, and if i have to i guess ill just get rid of it alltogether
Old Dec 10, 2012 | 04:31 AM
  #100
EmperorJJ1's Avatar
only the rear speakers not the fronts?
