Interior: How To: Install a Double-DIN Aftermarket Headunit in your 05-06 Cobalt SS
Old Dec 10, 2012 | 09:12 AM
  #101
subd
Old Dec 10, 2012 | 09:32 AM
  #102
tomj77's Avatar
only the rear speakers not the fronts?
Yes, just rears, that's what's so weird about it. Or it's my sub, maybe I should take a closer look. Either way I want the noise gone. I ordered a PAC harness, instead of the one suggested by op, which I have installed now, see if that helps, if not, I'm just gonna loose my chimes is all
Old Dec 10, 2012 | 09:40 AM
  #103
i wouldn't mind losing my chimes i hate chimes lol
Old Dec 10, 2012 | 01:21 PM
  #104
tomj77's Avatar
I don't care bout the chimes, but I like the turn signals and warnings when people don't wear seat belt
Old Dec 10, 2012 | 02:06 PM
  #105
EmperorJJ1's Avatar
ya im glad i have an 06 with the factory chimes. i hate all of the chimes the modules make
Old Dec 10, 2012 | 10:56 PM
  #106
tomj77's Avatar
i wish they didnt play through the speakers
Old Dec 11, 2012 | 02:36 AM
  #107
EmperorJJ1's Avatar
they shouldnt it should only be the drivers side front like OEM
Old Dec 11, 2012 | 10:12 AM
  #108
tomj77's Avatar
I mean oem, so u don't have to buy a module
Old Dec 28, 2012 | 02:07 AM
  #109
EmperorJJ1's Avatar
oh ya that sucks
Old Apr 20, 2013 | 08:58 PM
  #110
eutechnyx's Avatar
I know this is old BUT to avoid cutting the metal bracket behind the radio,theres two screws on the left side and one on the right side,take those out and you are good to go.
Old Apr 20, 2013 | 09:02 PM
  #111
Derke's Avatar
Yes agreed. I just couldn't reach them handily with a wrench and got pissed off. I cut first then unscrewed them. Either way that metal piece is no longer needed.
Old Apr 21, 2013 | 04:28 AM
  #112
EmperorJJ1's Avatar
7mm is the bolt size. a 1/4 socket and ratchet will fit but its tight
Old Apr 23, 2013 | 08:57 PM
  #113
tylerman683's Avatar
So I bought everything you did n mine doesn't have any sound idk what's going on. The only difference is I have the app2 radio. I have an 06 cobalt ss n that harness only fits the 24 pin plug...what does the other plug do?? Help meeeeee!!!!!!
Old Apr 24, 2013 | 06:50 AM
  #114
EmperorJJ1's Avatar
other plug is for XM not used for an aftermarket radio.
you need to give "remote" to the stock amp. its generally the pink wire in the cobalt harness
Old May 8, 2015 | 05:03 PM
  #115
Sammy211210's Avatar
Originally Posted by Derke
Feel free to message me with any questions.. already helped someone on here. Also good for sub/amp install questions, as well.
Hey Derek, nice write up. I have a problem I was wondering if I can send you pictures I'm not sure how to send pictures here and it's hard to explain. I have pioneer avh-4000dvd I took it out from other car. I have 2006 cobalt SS and I bought harness from eBay not the one you have I bought a cheap one. I don't care about steering control. I just want indash to be working. I connected wires whatever matched up but there are still few wires left and I'm not sure how to connect those. If you can provide me with your email so I can send pictures. I would highly appricate it. I don't want to spend tons of money getting it done from outside. From indash it self I have two yellow wires one is (12v) so I connected that. The other yellow wire is (Mute) wire I'm not sure where that's gonna go. Then I have red (Acc) wire I'm not sure where that's going to go. Then I have green (wire) people are saying is parking brake. Where do I put that? Then I have blue/white wire. What do I do with that? then I have two black wires, I'm not sure why two, could it be both ground wire? I tried everything the screen hardly shows, display is flickering very bad, and no sound either. Any help would be appricate it. It would be better if I could send pictures.
Old May 8, 2015 | 09:22 PM
  #116
EmperorJJ1's Avatar
im surprised it even works at all. The 2 black wires are both ground. pioneer normally has these terminated together with a ring on the end but if it was already installed that would have been cut off giving you 2 separate wires. mute leave unused. ACC will need to go to the fuse box with an add a fuse to an ignition fuse (sunroof normally works good) Green needs to go to the parking brake. this will make it so you can watch video. If its unconnected the until will work but you wont ever be able to watch video on the screen
Old Mar 18, 2018 | 11:47 AM
  #117
Ben Djscram Horgan's Avatar
Hey there how are you? I am new here and new owner of a 07 SS/SC. im swapping out the stereo to put in my kenwood Double Din and just wanted to know if all the stuff above will also retain the factory sub and amp? it has the pioneer system no onstar
Old Mar 19, 2018 | 05:38 AM
  #118
EmperorJJ1's Avatar
should. just check part compatibility
Old Mar 19, 2018 | 07:22 AM
  #119
Thanks
chefhhr
Oct 26, 2015 10:36 PM
Turbo6
Sep 24, 2015 04:15 PM
budah93
Sep 15, 2015 07:23 AM
Gugi96
Sep 15, 2015 12:24 AM
CobaltSS 16
Sep 6, 2015 02:04 PM
