2.0 LSJ Engine: How to install the "INGALLS Engine Damper" for your Cobalt SS/SC
Old May 10, 2006 | 08:53 AM
3fo893013L's Avatar
Mine's an 05 but I don't have the lines.
Old May 10, 2006 | 02:52 PM
robstamina's Avatar
Bump for a great review and a great product..
BEWARE OF IMITATIONS AND INFERIOR PRODUCTS. Ingalls engineering has been in business for over 25 years and is one of the orginators of engine torque dampers. We solely test, develop, and research our products extensivly to make sure that they are of the highest quality and actually work unlike other companies that are out to make a "quick buck" off the aftermarket.
Not only do we stand behind our products we actually use them on our own cars. I have had my damper installed for over 2 years on a boosted civic and love it! if anyone has any ?'s regarding our damper please feel free to contact me directly..
robs@ingallseng.com
Old May 10, 2006 | 05:07 PM
SS/SCking's Avatar
I just orderd mine today!!! Goodbye wheelhop!!!!
Old May 10, 2006 | 07:54 PM
denny's Avatar
Originally Posted by BLKSS
Denny took the time to meet up with me after work yesterday to show me the dampner. It looked really nice since it was the cleanest part under the hood lol sorry Denny... But the install looks great! Anyone know the life span of these? Im definatley ordering one now.. As soon as I get off my ass and order it that is.
Hey, I always have time for my bro just have a hard time getting a hold of you.
Your right about my engine bay. am going to clean it this weekend.
The life span of the Engine Damper am not sure about. You can e-mail Rob at Ingalls directly : robs@ingallseng.com
Old May 10, 2006 | 11:51 PM
robstamina's Avatar
basically we have had this on over a year on a couple local evos that put down around 400+(crazy cars!!!) we recommend them on cars that are less than 500hp but I have seen them on cars with more...
The honda civics were the first applications produced which one of mine was an r&d vehicle...I have had mine on a boosted civic for over 2 years with no issues and I POUND on the car(scca osp class, and test and tunes at the local drag strip)..there is really no maintence required on the damper itself...
**HOWEVER**
the black o rings that are supplied in the kit do degrade over about a year because they take up the majority of vibrations on the brackets..
.50$ at home depot..make sure you get the same diameter though...
I actually "upgraded" my o rings with harder ones that make the setup perform better BUT it definitly increases the vibrations so I wouldn't recommend that if you are a daily driver...
Ingalls Engine Damper Trick no.1!!
Dynamat used for subwoofer enclosures are great to decrease vibration and noises throughout the car especially when you run the "Stiffy" damper on the hardest setting.. Cobalts actually come from the factory with sound deading material installed around the strut area...use dynamat extreme on the firewall..I would recommend dynamat extreme cause it has higher temp ratings than regular dynamat..you can really go crazy with this stuff depending on how crazy you want to get to decrease vibrations..
feel fee to hit me up with any ?'s about the Ingalls "stiffy" damper..
robs@ingallseng.com
Old May 11, 2006 | 03:15 AM
05OrangeSS's Avatar
I installed mine on the car yesterday, and this "how to" is VERY usefull. Thanks to Denny for taking the time to write this. Also talked to Rob as I had a few questions, very cool guy. Love the product you guys are making over there. O and another quick question. I understand that the in-cabin noise will be more than without it on, but when turning to the right should it be louder than the noise when traveling in a straight path?
Old May 11, 2006 | 03:39 AM
ReMz's Avatar
give yourself some time to adjust to the noise and added 'feel' (dare i say?)
but i would say check to make sure both sides are adjusted properly and evenly
Old May 11, 2006 | 04:33 AM
clint06ss2.4L's Avatar
Will they fit for 2.4L SS as well?
Old May 12, 2006 | 01:54 PM
denny's Avatar
I added a little section on how to make adjustments to the damper.
Old May 12, 2006 | 02:53 PM
robstamina's Avatar
chicken little hehe(inside j/k)
thanks for adding that...
Old May 12, 2006 | 09:29 PM
  #36
robstamina's Avatar
pm'd
Old May 12, 2006 | 10:03 PM
  #37
SSBOOST's Avatar
Question. This will decide if i get this little upgrade or not. Is there any power LOSS at all?
Old May 13, 2006 | 04:04 AM
  #38
ReMz's Avatar
power loss? noooooo
you are putting more power to the wheels due to less engine torque.
think of it this way: when the engine is moving, hp is being wasted due to torque/engine movement. putting that power more directly to the wheels will yeild greater results.
hope that helps bro
Old May 13, 2006 | 04:11 AM
  #39
mi6_'s Avatar
Yeah, LSD won't help much with wheel hop. Mine still hops if I don't ease into a run. Full throttle is a no-no on all but the stickiest patches of road. You need to feather the throttle off the line still, or you will hop-and-skip your way to a 16-sec. quarter mile!
Old May 13, 2006 | 11:14 AM
  #40
robstamina's Avatar
Originally Posted by ReMz
power loss? noooooo
hope that helps bro
there is your answer...
Old May 15, 2006 | 08:03 PM
  #41
Mahadigus's Avatar
Yes, but only if you have an after market intake...I know it fits with the Injen but am not too sure about the AEM.
Old May 15, 2006 | 11:53 PM
  #42
robstamina's Avatar
https://www.cobaltss.net/forums/show...966#post293966
Old May 16, 2006 | 12:35 PM
  #43
Dezod's Avatar
Yes it will but requires an aftermarket intake
We have some in stock fellas!
http://www.dezod.com/pd_ingalls_stif...mpercobalt.cfm
Old May 17, 2006 | 06:33 PM
  #44
SS/SCking's Avatar
I just got back from my first test run with the Ingalls and the wheel hop is GONE!!!!!!!! I get smoke in first, second and a chirp in third!!! This should be your first purschase because why make more power when you cant put it to the ground.
Old May 17, 2006 | 10:20 PM
  #45
ReMz's Avatar
yeah. i've had mine installed for 24 hours now. I LOVE IT
props on an excellent product Rob. hell, a lot of ppl are failing to mention that it feels like getting a new clutch aswell. the shifts are firmer and more responsive. and that 1-2 "slippage-feel" is greatly lessened.
thanks for helpin us all out
Old May 18, 2006 | 09:59 AM
  #46
Dezod's Avatar
Your very welcome guys. We are glad you are all happy with your purchases.
Old May 20, 2006 | 08:21 PM
  #47
RaineMan's Avatar
So... has anyone tried this on a automatic 2.4 yet? Would it help? Should I just bite the bullet and get one?
Old May 21, 2006 | 05:37 AM
  #48
CobaltSSilver's Avatar
Very Nice write up.
Old May 21, 2006 | 02:01 PM
  #49
SS Gordon's Avatar
Wow I just installed mine & it's great, it does install like a dream & stops the wheel hop!!!!!
I just have to get use to the extra small noise but I figure thats what the radio is for huh
Great product Thanks !!!!
Old May 22, 2006 | 05:24 AM
  #50
Any vibration, and how bad is the noise?
