2.0 LSJ Engine: How to install the "INGALLS Engine Damper" for your Cobalt SS/SC
Old May 23, 2006 | 04:25 PM
  #51
robstamina's Avatar
Originally Posted by ReMz
yeah. i've had mine installed for 24 hours now. I LOVE IT
props on an excellent product Rob. hell, a lot of ppl are failing to mention that it feels like getting a new clutch aswell. the shifts are firmer and more responsive. and that 1-2 "slippage-feel" is greatly lessened.
thanks for helpin us all out
what I like to hear!!!
yeah I agree not to many people have talked about the shifting benefits related to the product...
Old May 26, 2006 | 02:02 PM
  #52
pvirga88's Avatar
If you install this will it void any warranty on the car?
Old May 26, 2006 | 02:07 PM
  #53
BLKSS's Avatar
Cmon guys who else has it? I want more feedback!
Old May 27, 2006 | 04:04 PM
  #54
knatsabooh's Avatar
I have it... wheel hop is gone and shifts are tighter. Makes the car sound a little louder and comes with some minor vibrations, but its way better then stock... worth it imo.
Old May 31, 2006 | 01:56 PM
  #55
dcshoes23's Avatar
Originally Posted by robstamina
advantages:
4. eliminates wheel hop and torque steer
Anyone notice torque steer gone? Comments please...
Old May 31, 2006 | 02:51 PM
  #56
Wu9lf's Avatar
Originally Posted by CobaltSSilver
Any vibration, and how bad is the noise?
depends on how you set the damper, 10mm has more vibration than 15mm. Best thing about the damper is that its easy to remove and adjust for track and daily driving. even if you notice some vibration you will forget when you start driving hard.
Old May 31, 2006 | 02:55 PM
  #57
Wu9lf's Avatar
your car looks really nice without the wing, looks very clean.
Old May 31, 2006 | 04:13 PM
  #58
justfo1d's Avatar
thanks for the excellent how-to!
Old May 31, 2006 | 04:24 PM
  #59
MadFish's Avatar
I got mine installed last night and test drove it today. So, far Im liking it. Only thing is, with it on it seems the car starts harder and shuts off harder. Im guess since the engine isnt allowed very much movement, it makes things a little more brunt. But, I can live with it. Im planning on new engine mounts anyway.
Old Jun 1, 2006 | 03:17 PM
  #60
knatsabooh's Avatar
thanx ! ... i'm debating on selling the wing now, but don't know if i should.... would help pay for trunk cosmetics tho...
Old Jun 2, 2006 | 07:08 PM
  #61
dcshoes23's Avatar
Well, I'm sold, mine is in the mail.
Old Jun 3, 2006 | 02:08 AM
  #62
Wu9lf's Avatar
Really ? See it had the opposite effect on my car. I have the damper set at it's stiffest setting and my car starts and shuts off nice and smooth. I did notice the interior of the car vibrates much harder at idle and when the clutch for the heat/ac kicks on.
Old Jun 8, 2006 | 11:07 AM
  #63
dcshoes23's Avatar
Anyone know what size the wrenches are that you use in this step?
Thanks
Old Jun 20, 2006 | 10:14 AM
  #64
rnjmur's Avatar
Thanks
A 15mm wrench and 17mm wrench.
I just installed my Ingalls yesterday and must say it made a significant improvement over wheel hop and makes the shifts much, much stiffer and responsive.
It took me about 45 minutes to get the Ingalls adjusted correctly. As you adjust the preload you must make sure to adjust the overall length and then getting it as parallel as possible is quit e a task. Using one wrench on the preload locknut, one wrench on the length adjustment knob and a screwdriver through the eye to keep it from moving. Making sure everything is as parallel as possible is very important to making the ETD work correctly.
Having said that, I have noticed a bit more vibration at idle but as you drive the vibration is not noticable. There is also a little bit more noise at idle and when driving, but mostly only noticable at idle as well.
Old Jun 26, 2006 | 11:53 AM
  #65
robstamina's Avatar
If you guys are getting vibrations...
I would suggest using Dynamat extreme on the firewall..it takes out 90% of the vibrations associated with the damper..
Old Jun 26, 2006 | 04:50 PM
  #66
CobaltSSilver's Avatar
That's not a bad idea!
I'm not great at cutting, do they have something that is pre-cut for the firewall of the car?
Old Jun 27, 2006 | 09:51 PM
  #67
A_SS_THING_GT'S_WONT's Avatar
Hey Thanks For The Write Up I Will Be Getting Mine Soon Do U Know How Much The Price Is And Where Exactly Can I Get It Thanks Again.
Old Jun 27, 2006 | 09:56 PM
  #68
denny's Avatar
Contact!! Rob at robs@ingallseng.com
Rob's a great guy, he will hook you up!
Old Jul 5, 2006 | 05:14 PM
  #69
denny's Avatar
No, you have to cut your own sheet.
Old Jul 5, 2006 | 06:59 PM
  #70
robstamina's Avatar
BTW get Dynomat extreme cause it has a higher temp rating than regular dynamat..especially since it is going to be in your engine bay..
Old Jul 10, 2006 | 05:32 PM
  #71
zer0's Avatar
What is the extra bolt and washer for? I didnt use them when I put it on 20min ago...
Old Jul 11, 2006 | 02:53 AM
  #72
ReMz's Avatar
read the instructions for 5 seconds. i wont give u the pleasure of finding out easily
Old Jul 11, 2006 | 10:47 AM
  #73
robstamina's Avatar
That 12mm nut is for the rear motor mount.. the smaller nut allows for more lateral movemnet to ensure the bracket is a straight as possible..You don't have to use it if you installed the old one with the bracket straight..
Old Jul 11, 2006 | 02:36 PM
  #74
zer0's Avatar
I looked it over for more then 5 seconds... Mentions nothing about the 12mm..
http://www.ingallseng.com/Instructions/93040.pdf
Thanks Rob for the quick answer.
Old Jul 11, 2006 | 06:25 PM
  #75
RickZ28's Avatar
I'm sold too' mine is in the mail
