2.0 LSJ Engine: How to install the "INGALLS Engine Damper" for your Cobalt SS/SC
I only installed the stiffy, wheel hop is gone. Clutch is now slipping bad.
the vibrations are totally fine, nothing as bad as you might think. makes it feel like a race car though.
most noteable vibes are while reversing out of a driveway.
WOW! It's a bit soon for that clutch to be slipping. Have you taken it in to a dealer yet? If so what did they say about it.
I have 2700 miles on the car now
I do feel that the dampener shows the weekness of the stock clutch, I feel that the rocking motion of the factory motor mounts allows the factory clutch enough time to "seat" into position where with the Dampener the clutch needs to engage on it's own and I feel the factory clutch is just garbage, I also would like to know if it;s the same p/n: clutch that goes onto the non-supercharged cobalt ss.
I don't feel the dampener was a bad thing to get as it really tightens up thios car quite nicely. just need to flesh out the weakneeses of the other sub - par factory parts.
Sounds like the product performs as advertised.
Originally Posted by BlackLS
Would the torque dampner have any affect on an automatic because I will probably get one if it'll help at least a little.
^^^ It would benifit the auto in some of the ways it does with the manual. The issue is with an auto it becomes more of a task to get wheel hop or wicked engine movement. But with the power the cobalt puts out I can see this part working on an auto with great results as well.
