2.0 LSJ Engine: How to install the "INGALLS Engine Damper" for your Cobalt SS/SC
Old Oct 3, 2007 | 08:19 PM
  #151
g5mike's Avatar
where do I place the floorjack?is that all i need or do I need jackstands?Also they sent me no instructions,how do I know where the ingilis is set at
Old Jan 5, 2008 | 06:44 PM
  #152
Billig ss/sc's Avatar
Hey guys, sorry to once again revive an old post, but I really want to get this for my 'balt, and I have a few questions...
1. How do you know what setting it's at and how to adjust it?
2. How do you know if it's tightened to the right amount of tourque?
3. I assume it works on '07s, but just figured I'd check.
Thanks guys!
Old Jan 24, 2008 | 06:10 PM
  #153
rico's Avatar
great write up will be reffering to it once i get my damper
Old Jan 25, 2008 | 03:23 PM
  #154
speed_demon05's Avatar
subscribed for later use
Old Mar 10, 2008 | 06:08 PM
  #155
valentino0214's Avatar
did u use a jack to keep the engine up from messing up the other motor mounts
Old Mar 12, 2008 | 11:03 AM
  #156
AmericanSS's Avatar
Read the how to on page one. the reason why you only take out two bolts at a time, is so that you dont have to use and supports. if you take all four out then yes the engine will drop and your screwed. Its really simple if you can follow the instructions On page 1.
Old Mar 17, 2008 | 03:18 PM
  #157
galeblanc's Avatar
Torque Wrench ?
Hi,
Does anyone know where the best place is to get an affordable torque wrench that can do 74 ft-lbs as required to install the Ingalls ? I don't want to pay much cause I'll only be using it to put the ingalls on and remove when I bring my car to the garage.
Let me know of where and a specific model ? (Online only please) Unless I can get it in a Canadian store.
Thanks
Gabriel
Old Mar 17, 2008 | 03:38 PM
  #158
invisible's Avatar
Should be at your local auto parts store. But a torque wrench is not needed for the install, just get it tight and you will be good.
Old Apr 16, 2008 | 04:46 AM
  #159
stg2ss's Avatar
subscribed
Old Apr 16, 2008 | 10:16 PM
  #160
rico's Avatar
okay i got my damper today from a guy that i know that didnt need it no more now i have 1 question since i have no instructions or anything for it what do i move to adjust it?/ the right one or left one? because right now i cant move any anyhelp will great
Old Apr 17, 2008 | 11:13 PM
  #161
cobalt ss/sc's Avatar
Thumbs up
Awesome write up, just installed mine tonight using this "how to"
Old Apr 29, 2008 | 06:42 PM
  #162
Dayta's Avatar
ok, i dont have the ingalls, i got a Wepon R damper from someone off the forums
i just installed it and its quite loud and it shakes the whole car. and my wheel hop seems to be more than before....
i tried to adjust it, but its still loud, like my engine is gonna blowup loud....
or is that how its supossed to sound...
thanks
Old Apr 29, 2008 | 08:09 PM
  #163
rico's Avatar
umm i got my ingals no problem with it. no wheel hop so far yet i tried to get it to jump and nothing. as far as engine sound none. only a LIL vibration when like going in reverse outta a lil hill or just letting go off the clutch slowly in 1st other than that works GREAT
Old May 12, 2008 | 12:57 PM
  #164
CobaltSSilver's Avatar
I just installed mine over the weekend, this write up made it incredibly easy to install. I just left it at the factory setting of 14mm. Wheel hop is gone and I have very little vibration.
Old Jun 17, 2008 | 09:44 PM
  #165
scampbell's Avatar
Thanks for this write up man the pics that came with the kit were pretty shitty and this made it alot easier. This thing is probably the best buy i have made so far I left it at the factory setting of 14mm also and i have no more wheel hop and just a little tire spin when i get on it real hard.
Old Jun 17, 2008 | 09:56 PM
  #166
ViSiONZ's Avatar
Nice write up Subscribed for later.
Old Nov 10, 2008 | 09:54 PM
  #167
jareds064drSS's Avatar
great write up
Old Mar 3, 2009 | 12:30 AM
  #168
BEASTmode632's Avatar
do you have to have the rubber washers?
Old Mar 3, 2009 | 10:25 AM
  #169
rnjmur's Avatar
No. They are there to reduce vibrations.
Old Mar 18, 2009 | 12:51 AM
  #170
hawkesb3's Avatar
i want one...
where can i get one ?!
Old Mar 18, 2009 | 01:16 AM
  #171
rico's Avatar
no you dont. if u want no wheel hop and u are into racing or going to the track your better off getting the ottp rotated mounts
Old Apr 14, 2009 | 10:05 PM
  #172
how do i set the damper to its stiffest position? well not how but which was is the stiffest?
Old Jun 18, 2009 | 06:16 PM
  #173
06SIBLT's Avatar
installing tomorow
Old Jun 18, 2009 | 06:34 PM
  #174
TurboTechRacing's Avatar
www.TurboTechRacing.com
Old Jun 18, 2009 | 06:41 PM
  #175
CobaltSS 16's Avatar
wow people still use these
