Other/Misc: How-To: Install a rear tow hook
well red is usually the color you have to have on a track..so if you arent tracking then make it whatever color you want
I ordered the moroso quick pins, they fit and are much easier than the bolts.
why cant you?
the quick pins...holy crapolie are awesome, takes like 2 seconds with no tools, vs 35239542305 minutes with 2 tools. soooo worth it.
deffinitly worth the extra money in my opinion. would be a thing to maybe even consider for john to sell at an added price with these...
I'm working on figuring out a solution to that problem.
So long as the welds are good (which they are) im good, I refer you to the bolt chart
http://dodgeram.org/tech/specs/bolts..._strength.html
The 3 at the base are grade5 7/16" and the hinge is a grade8 1/4".
Pretty sure the bumper will permanently deform before this thing does
I wonder...not sure if John could get a deal, but he is shipping from canada, so it is probably cheaper for us US ppl to just buy them off summit racing. John isnt in this to make tons of money...man he is a straight up guy
HB - ohh wonder if he is making a new batch so he is test fitting the new pieces OR he changed something to make it easier to install or fitment.. worth the wait, getting both is cheaper than 1 from another place.
Only did front hook so far...Install take a while since the largest bit I have is 7/16 and each hole then requires me to file them to fit the larger bolt bases on these 2" bolts.
Front hook fits nice behind Lic place, to use hooks I just need to take out the 2 screws holding the place on
does the hahn intercooler hang below the crash bar? I need to make sure when I IC shop the tow hook is going to fit!
EDIT: oh even the stock one does...but theres room for the tow hook...ah well this shall be interesting... we shall see how mpx's mounts...
