Appearance: How To: Paint Brake Calipers
Old 04-17-2010, 10:23 PM
MikeK's Avatar
This is my first attempt at a how to so please bear with me...
Tools Needed-
Jack
Jack Stands (optional but recommended)
High Temperature Paint
Caliper Cleaner (or hot water and a brush)
Wrench (Whatever size your lug nuts are)
Painters Tape And Newspaper
1)
Jack your car and remove the wheels. I did one at a time because I didn't have jack stands. This step is pretty self explanatory.
2)
Clean your calipers throughly with the cleaner, or drench them in hot water and throughly scrub them down. After, cover every surrounding part and adjacent piece of the car with tape and newspaper. Make sure the moving parts and the disc are covered well.
3)
Paint your calipers. I did 3 coats on each, getting heavier with each coat. I waiting around 20min between each coat then waited 30min before putting the wheel back on. Make sure it doesn't drip, unless you don't care if it drips
4)
Gently remove all the newspaper and painters tape. Wait a little while then put your wheels back on.
5)
Enjoy the new look
Old 05-19-2010, 09:21 AM
ChevelleGrl's Avatar
is this way easier than taking them off and painting them??
Old 05-19-2010, 11:17 AM
Smus's Avatar
I would assume. No need for those fancy brake line wrenches. I'd make sure I have jack stands...they're only $20 from Sears. I saw you did get some paint on the rotor, I would assume that would wear off after a time correct?
Old 05-19-2010, 11:20 AM
JPizzle's Avatar
Yes. As you hit your brakes, the paint is no longer there anymore.
Old 05-20-2010, 11:08 PM
cobalt523's Avatar
nice how to! any over spray on your car?? im gonna powder coat mine and my drums
Old 05-20-2010, 11:16 PM
xBuRnTx's Avatar
should clear coat them if you drive in the winter.. Mine weren't and the paint is almost all gone
Old 05-20-2010, 11:48 PM
cobalt523's Avatar
xburntx if you do 25 more posts you wont be a new member anymore! you will upgrade to member
Old 05-28-2010, 11:55 PM
xBuRnTx's Avatar
ohh an upgrade eh.. sounds tempting lol
Old 05-28-2010, 11:57 PM
joeworkstoohard's Avatar
UPGRADDE don't care about no painted rotors.... he jsut wants his money
Old 05-29-2010, 12:03 AM
IdreamofYenko's Avatar
When my friend did hers she used plastic walmart bags to cover the rotors and that worked out pretty well. Just a suggestion so that you don't have to use so much newspaper.
Old 05-29-2010, 12:42 AM
kidcrash603's Avatar
Or just buy a can of brush on caliper paint and dont waste time taping anything off.....
Mkulrey bought 1 1/2pint can and it did 4 cars with 3 coats on each caliper...
By the way, if you read the can of spray paint usually will tell you to do each coat within 1 or 2 minutes, OR do each coat and wait an hour for it to fully dry. Otherwise you will get orange peel or make it more likely to chip off...
Old 05-29-2010, 12:50 AM
I'm thinking about getting this... http://www.r1concepts.com/caliper-paint.aspx
I wanna do purple but the purple they have isn't quite dark enough for me
Old 06-21-2010, 11:08 AM
boomabile6's Avatar
oh wow thanks for the link!
i am DEF doing the green hahaha
Old 06-21-2010, 11:13 AM
1badBlueberrySC's Avatar
VHT Ceramic Caliper Red, with a pearl clearcoat over the top of it.
Old 06-21-2010, 12:52 PM
boomabile6's Avatar
hell yeah those look clean as ****!
Old 06-21-2010, 12:59 PM
JPizzle's Avatar
Damn! Those are sexy!!! What was the process you went through to get them like that?
Old 06-21-2010, 10:28 PM
boomabile6's Avatar
do you think brake caliper paint, since its meant to withstand high heat, would work on rims as well?
Old 07-05-2010, 08:26 PM
jon_k's Avatar
It will get on your brake pads. It will foul the pads and they will seize your brakes in an emergency situation.
Old 07-05-2010, 10:07 PM
08SSTCRD's Avatar
No it won't.
As long as the paint is dry before you drive the car, it will just wear off and turn into dust. Usually the paint will start to wear off within just a few miles. The brake pad material and rotor are much harder than the paint, so the paint is the first thing to wear off.
Old 07-23-2010, 03:40 PM
Chilipado's Avatar
Ok so I was wondering what kind of clearcoat you would need to use. Is there a high temp clearcoat?
I read some member did a pearl clearcoat? Would anyone know which kind you could use? i'd ask the member but they are banned lol
Old 07-24-2010, 07:13 PM
Sikkwidit's Avatar
How did you not spray over the Brembo logo?
Old 07-24-2010, 07:31 PM
I'm sure he did the same thing I did...
Bought a new set of brembo vinyl decals on ebay for $8 shipped...
Old 07-24-2010, 08:28 PM
Sikkwidit's Avatar
Sounds good, i just finished my back ones.
01-12-2016 12:01 AM
biniecki
10-25-2015 02:23 PM
10-20-2015 09:56 PM
10-13-2015 09:32 PM
Trav3480
10-01-2015 08:17 PM
Quick Reply: Appearance: How To: Paint Brake Calipers
