How-To: Remove Cobalt Front Bumper
For all those removing the rear is just as easy with the right tools.
Remove rear wheels(or jack the car up high enough the suspension droops enoough)
remove clips on the rearmost part of innerfenderwell
you should see a small cutout on the innerfenderwell where the bumper meets the quarter, remove the bolt there
remove all bolts/screws under trunk lid that are attatched to bumper
remove tails
remove clips under bumper(if I remember right there should be 4 or 5 starting at the exhaust cutout you should see them)
remove liscense plate and light
remove parking markers(rectangle reflectors on the side of bumper)
start at front lower corners of rear bumper and gently pull outwards, you will feel the plastic clips on the seam holding, be persistent and kinda wiggle it up and down and they should release after a few minutes once both sides have come undone from the clips grab from the bottom of the inside of the trunk and remove bumper.
remove tails
chilisickle
Feb 20, 2009 11:46 PM
