How-To: Remove Cobalt Front Bumper
Old Jun 30, 2009 | 04:06 PM
CobaltSSilver's Avatar
Let us know how it goes for ya!
Old Jul 5, 2009 | 10:47 PM
CTcar's Avatar
Bumper change went pretty smooth. Biggest pain was changing the grille and fog lights over from one bumper to the other.
The results:
Old Dec 8, 2009 | 02:27 PM
n323er's Avatar
subed for later great how to thanks fo doing it
Old Dec 8, 2009 | 02:37 PM
68Vette's Avatar
This is a good "How-To" !!!
Old Jan 12, 2010 | 04:24 PM
SSam2.4's Avatar
Anyone know if this is the same for the 09 ss ?
Old Jan 12, 2010 | 04:30 PM
wilson79's Avatar
Should be the same.
Old Jan 16, 2010 | 05:01 PM
tru2nrtt777's Avatar
For all those removing the rear is just as easy with the right tools.
Remove rear wheels(or jack the car up high enough the suspension droops enoough)
remove clips on the rearmost part of innerfenderwell
you should see a small cutout on the innerfenderwell where the bumper meets the quarter, remove the bolt there
remove all bolts/screws under trunk lid that are attatched to bumper
remove tails
remove clips under bumper(if I remember right there should be 4 or 5 starting at the exhaust cutout you should see them)
remove liscense plate and light
remove parking markers(rectangle reflectors on the side of bumper)
start at front lower corners of rear bumper and gently pull outwards, you will feel the plastic clips on the seam holding, be persistent and kinda wiggle it up and down and they should release after a few minutes once both sides have come undone from the clips grab from the bottom of the inside of the trunk and remove bumper.
Old Jan 22, 2010 | 01:44 PM
jerseypilot's Avatar
Where does the bumper absorber belong? I dont see it in the pictures
Old Jan 23, 2010 | 09:14 PM
The foam part? it goes on the black bumper directly infront of his radiator.
Old Jan 24, 2010 | 03:24 PM
SS Pyro IV's Avatar
dude thanks to this how to it was so much easier to get my heat exchanger on. amazing write up. and these cars are damn hideous without the front bumper
Old May 13, 2011 | 03:44 AM
  #36
dtowngreg's Avatar
is it possible to install the headlights then put the bumper back on? cause im running out of ideas to install my gen4s, i cant get them to fit for ****
Old May 13, 2011 | 03:47 AM
  #37
heathkidder's Avatar
i dont see why u have an issue alot of ppl have gen 4s
Old May 13, 2011 | 03:50 AM
  #38
dtowngreg's Avatar
i had these lights before and the passenger light did not fit good. it stuck out. now this time a brand new light wont even go in. maybe i should contact depo
Old May 13, 2011 | 05:30 AM
  #39
mkulrey13's Avatar
Remove your grill clips before installing headlights.
Old Nov 17, 2011 | 10:05 PM
  #40
apicia's Avatar
Found it, everything is unbolted except the three underneath on both sides (6 total). Started raining on my head. I finish in the morning.
Old Jan 6, 2021 | 08:41 PM
  #41
Zo6balt's Avatar
Originally Posted by SteveORyan
How long does it take to take off and put back on?
Removal took me 20min with sockets and a drill. I also had some rusted bolts. I'm sure it will take me 10 min longer reinstalling.
tanelk
Feb 7, 2011 08:29 AM
DavidLaMattina
Nov 15, 2010 10:25 PM
coopercharge
May 25, 2010 08:41 AM
chilisickle
Feb 20, 2009 11:46 PM
GSoccer24
Jan 13, 2006 01:14 PM
