All Engines: How To: Remove Fuse Box
Old Nov 26, 2012 | 09:15 PM
LS6Rally's Avatar
yup. i had to change my calipers after about 120K miles. they were leaking. of course after you've owned a Maxima, you appreciate anything that doesn't need calipers at every pad change
Old Dec 4, 2014 | 11:33 AM
CaptainHook's Avatar
As someone who is not mechanically inclined, thank you very much for this. It's ******* cold as ***** outside and I'm tired of working on it. Thanks again.
Old Apr 22, 2015 | 04:13 PM
breds2k's Avatar
Bump!
I know this may sound dumb but I need a second ear.
I work at Toyota in a Call Center, our employee labor rate is $45 so I paid the guys to install my ky clutch. after the clutch install, the ECM isn't sending pulse width modulation (that's what the tech said and he was a gm tech for years) to the cooling fans to turn them on so the car overheats at idle. They are trying to tell me I need a new ecm but I didn't before the car went in the shop!!! After this retarded battle, they have checked the fan, wires, connections ect with no fix.
I want to personally remove the fuse box and ecm to check to make sure pins are lined up properly. Do I essentially just need to the check the pin underneath the ECM fuse in the back right of the fuse box (I have an HHR SS so my fuse box is a pinch different)
Old Apr 22, 2015 | 04:24 PM
Subd
Old Apr 22, 2015 | 09:23 PM
EXsoccer1921's Avatar
That is well beyond my realm man. Might make a thread about it and see who has what to say.
Old Jan 21, 2019 | 09:21 AM
scottie's Avatar
Perfect, thank you!
ToyotaKarl
May 28, 2020 03:55 PM
nobaltyet
May 26, 2018 12:54 PM
2.2balt
May 13, 2017 08:32 PM
cruisn
Canadian Mid West
Sep 29, 2013 01:03 AM
cruisn
Canadian Mid West
May 25, 2013 08:39 AM
