Interior: How to upgrade the stock Pioneer sub to sound awesome and look stock. (With Pics)
Old Mar 31, 2010 | 11:12 PM
  #51
ufnwish's Avatar
Quote:
Originally Posted by E-Dubb
is there a way to just add another sub and amp? while keeping the stock system?
yes.
Line out converter
new aftermarket amp
new aftermarket sub and box
Amp wiring kit. And your done.
this is the setup im tring to hook up need to know what to hook into remote and l/r for line out i would like to keep it all in the trunk
Old Apr 22, 2010 | 05:04 PM
  #52
bbrewbaker's Avatar
I just ordered a Memphis shallow sub for the stock sub box that i got off ebay.
For the Memphis sub i will need to notch the box a little to fit it in.
I was able to test fit the display one at a local shop.
I'll post pics of the install.
Old Jul 22, 2010 | 08:34 AM
  #53
xnigelx's Avatar
anyone know what the max depth for the sub can be?
Old Jul 22, 2010 | 06:32 PM
  #54
ttypecamaro's Avatar
my 10" kicker shallow mount was 3/8" too deep. look up the specs and subtract 3/8"
Old Jul 23, 2010 | 08:48 AM
  #55
xnigelx's Avatar
u got a compvt? so i think thats 4 3/8 for those so basically 4 inches.. what did u do to resolve that? or did u just return it. I get an awsome discount on kicker and like to use them if i can
Old Jul 23, 2010 | 06:49 PM
  #56
I just put a ring of foam around and drew up the plastic with the screws.
Old Jul 29, 2010 | 09:33 AM
  #57
jmdubose202's Avatar
This is for the person wo put the jl 10w7 in the stock enclosure
What all do you need to do t get it to fit?
What sub will go in with little to no mods to the stock enclosure
Last edited by jmdubose202; Jul 29, 2010 at 09:34 AM. Reason: Automerged Doublepost
Old Jul 29, 2010 | 12:00 PM
  #58
kasper_17's Avatar
really wanna do this one...
Old Aug 23, 2010 | 11:46 PM
  #59
leviticus88's Avatar
Originally Posted by ss2.4lvvt
just done this to my car.. had a custom fiberglass box that took up half my trunk in my 06 ss and wanted my trunk back when i got my 2010
luckily i bought 2 kenwood exelon shallow enclosure subs.. fit directly in the stock enclosure no cutting or anything and looks like the jl one the guy done on this thread
.. have a m500 alpine amp running at 4 ohms(sub is svc 4ohm ) and its double the loudness as the stock sub and am noticing alot more frequencies that i didnt hear from the stock sub.. AND I HAVE MY TRUNK BACK with no extra weight.. maybe gonna make a replica enclosure for the right side of the trunk so i can run both at 2 ohms.. but we'll see how spring goes..
Is this the sub you used?
http://www.amazon.com/Kenwood-KFC-XW...2621437&sr=8-1
And was it really no cutting to install?
Did the screw holes line up?
Any pictures?
Thanks
Old Sep 6, 2010 | 12:45 AM
  #60
chrisjaldin's Avatar
I have a doubt. There when creating a adapter cable for speaker high level input to amp. How did you connect the cables of the subwoofer to the amp if it was removed from the beginning? Not sure if you connect it again to the connector of the oem amplifier or not? more pictures would be great, man.. And the output connection to the subfoower from where did you get the cable? Could you explain a little bit more the input and outspeaker speaker/subwoofer procedure. Thanks a lot
Old Sep 6, 2010 | 12:58 AM
  #61
b00sted06ss's Avatar
Nice write up ill have to try this soon
Old Sep 7, 2010 | 02:25 PM
  #62
Tomtwtwtw's Avatar
I've read that some who didn't want as much kick just bought a 300w Pioneer amp and wired it to the stock sub - would that process be the same as this write-up, minus the sub work?
Old Sep 17, 2010 | 11:51 PM
  #63
My AGU 60 amp fuse burned! ...I need help, can't power up my amp.
Old Sep 19, 2010 | 03:02 AM
  #64
Skunk's Avatar
Ok so I recognize the stock black/red harness, but where does the harness with the white/black wires come from? That's the only question that I can see isn't really clearly answered.
Old Sep 19, 2010 | 02:01 PM
  #65
FasterIsBetter's Avatar
You can get some splice connectors so you don't cut your wires and hook a line out converter to the rear deck speakers. This is for installing an aftermarket amp. For a remote wire, I ran mine to the fuse box on the A/C fuse. That way unless you turn your key completely on your amp won't kick on so you can listen to the stereo without running your battery down quickly with the amp. Plus it kicks off with everything else when the car is being started. You can also reverse mount a full size 10 in the stock box. You just need to reverse the polarity in which your sub is hooked up. Negative to positive, positive to negative.
Old Oct 6, 2010 | 04:33 AM
  #66
streetracinazian's Avatar
Originally Posted by dromano89
Looks Good .. Similar Setup, I Went JL
I'll be doing this same set-up next week... But with an alpine amp thats 500watts rms
Any thoughts or anything I should expect?
Old Oct 9, 2010 | 03:37 AM
  #67
Originally Posted by streetracinazian
I'll be doing this same set-up next week... But with an alpine amp thats 600 rms(i'm goign to bump it down alot so as not to over power it)
and how do i "build the box out"
Old Oct 9, 2010 | 06:13 AM
  #68
gotboost?17's Avatar
Nothin Stock
nice write up must try
Old Oct 9, 2010 | 02:35 PM
  #69
gut it out..build it out and seal it .. it wasnt that bad
Fml.. Just seen this post. I was going to mount my w3 and saw it was too big.. How did you build it out?
Old Oct 18, 2010 | 04:11 PM
  #70
pbass's Avatar
Could I mount the amp on the other fender across from the sub?
Old Oct 18, 2010 | 09:48 PM
  #71
Yes..if you build or buy some brackets to place the amp on a flat surface.
Old Oct 18, 2010 | 09:55 PM
  #72
mysweetSS's Avatar
Very Nice
Old Oct 21, 2010 | 03:33 AM
  #73
Uploaded with ImageShack.us
Old Oct 21, 2010 | 03:42 AM
  #74
slobalt08's Avatar
lol j/k but seriously why is the sub backwards?
Old Oct 21, 2010 | 03:50 AM
  #75
Lmao....
Subs too big for the box. So it's reverse mounted and the polarities are reverse-wired to make up for the reverse mount
