Interior: How to upgrade the stock Pioneer sub to sound awesome and look stock. (With Pics)
Old Oct 21, 2010 | 03:54 AM
  #76
ramrod1337's Avatar
looks kool but im fine with my stock 10
Originally Posted by streetracinazian
I'll be doing this same set-up next week... But with an alpine amp thats 500watts rms
Any thoughts or anything I should expect?
dude thats really ******* kool imo
Last edited by ramrod1337; Oct 21, 2010 at 03:54 AM. Reason: Automerged Doublepost
Old Nov 18, 2010 | 10:55 PM
  #77
padlock's Avatar
Originally Posted by dromano89
Looks Good .. Similar Setup, I Went JL
so JL w3's fit without any clearance issues except for trimming the plastic ring around the enclosure i take it? it also looks like the holes for the screws line up am i right? what would be a good amp to run with this sub?
Old Nov 19, 2010 | 12:33 AM
  #78
streetracinazian's Avatar
no it won't fit. you'll have to expand the box to be bigger, or do what i did and mount it solo-baric style
Old Nov 19, 2010 | 01:15 AM
  #79
padlock's Avatar
^ok thanks for the heads up! does anyone have a measurement of how deep a sub I can get? i should be okay with any shallow mount sub i would imagine correct?
Old Dec 6, 2010 | 01:27 PM
  #80
BlackWidowSS07's Avatar
Dromano......... I just wanna know htf you got a W7 to run efficiently in the stock enclosure? Is that a 10 or an 8? Airspace?? ..... please PM me and fill me in bro
Old Dec 6, 2010 | 01:32 PM
  #81
Can someone tell me what the air space specs are for the factory sub enclosure please?
Old Dec 9, 2010 | 02:10 AM
  #82
CleanCut's Avatar
just what i was looking for..
Old Dec 9, 2010 | 03:16 AM
  #83
=P since my sub was too big
Old Dec 10, 2010 | 11:49 PM
  #84
[QUOTE=streetracinazian;5425932 =P since my sub was too big[/QUOTE]
Azian what sub do you have there?
Old Dec 13, 2010 | 01:47 AM
  #85
Jl audio w3v3 10"
Old Dec 13, 2010 | 09:18 AM
  #86
SS Pyro IV's Avatar
. So it's reverse mounted and the polarities are reverse-wired to make up for the reverse mount
how does mounting a sub solo baric style benefit from reversed polarities?
curious
Old Dec 16, 2010 | 02:11 PM
  #87
curious
Someone correct me if I am wrong but I beleive its mainly just for the ooh and ahh effect. Ive done it before and didnt notice a difference in the sound... just looked cooler/different than normal and the wiring is backwards
Old Dec 16, 2010 | 03:27 PM
  #88
my main purpose cuz the sub was too big to fit in the stock box.
as for the reverse polarities...
you're reversing a sub, so you would have to cross the polarities to reverse the effect of a reverse mounting sub. so at the end it will have the same effect as a regular mounted sub.
failing to do this your sub would be "hitting backwards"
Old Dec 16, 2010 | 03:50 PM
  #89
kingg5's Avatar
Originally Posted by SWmaster
This amp gets pretty hot. It will get hot enough that you cant hold your hand on it but there should be no danger. Make sure that all of the electrical connections are solid and that the polarity for the right and left inputs are correct. Past that I would suggest to leave the bass boost and filters off and set the gain to just under half.
thast wierd man...ive never had an amp get hot enough that I cant touch it lol
Old Jan 28, 2011 | 11:02 AM
  #90
dicecurt's Avatar
Hey, does anyone know if this Sub is any good for this setup? It's the best one i could find for a reasonable price, and i don't really want to buy something that isn't going to be worth my money! Lol thanks!!
PIONEER TS-SW2501S4 1200W 10" CAR SHALLOW SW SUB WOOFER on eBay.ca (item 190491994598 end time 16-Feb-11 16:34:46 EST) <-- that would help LOL
Old Jan 28, 2011 | 12:51 PM
  #91
its specs look good..
as long as you can power it correctly.
try and power it with the optimum 300 watts rms
Old Feb 6, 2011 | 01:12 PM
  #92
OakvilleSS's Avatar
Thanks for the idea!
Ordered a 10" Kicker CVT, and a Kicker ZX400.1 off eBay. I know the Kicker won't fit with out modifying the box a little. I plan to stick a bolt through the rear sub mounting hole, with a nut and washer on the outside, heat it up with a torch and pull the plastic nub down enough to fit the sub. Then seal with silicone. I'm also going to mount the amp under the rear dash. Was thinking a piece of 3/8" plywood, mounted with U bolts, then mount the amp to the plywood. Any suggestions? or pics of how someone else has done the same thing.
Old Feb 6, 2011 | 11:10 PM
  #93
xnigelx's Avatar
Ts-sw2501s4 + gm-d8400m
is the combo i want to run
Old Jun 16, 2011 | 02:52 PM
  #94
sweet write up
Old Jun 16, 2011 | 04:21 PM
  #95
FasterIsBetter's Avatar
Just mount it to the back of your seat. I did that and hid all my wiring up under the spare tire cover. A lot easier and probably neater than mounting it to the read dash/deck. i have an Alpine MRD-M1005 amp which is probably close to the same size physically as your amp.
Old Jun 16, 2011 | 04:29 PM
  #96
Main purpose I have found is you gain more air space because the sub is no longer taking up that space. Ex. I reverse mounted my two mtx 8000 series 15s in a sealed box and they now hit twice as hard. But thats 15s, they take up a lot more air space than a 12 or 10.
Old Jun 16, 2011 | 04:33 PM
  #97
kebbester's Avatar
looks good man!
Old Nov 24, 2011 | 06:52 PM
  #98
toysareforboys's Avatar
Originally Posted by BPacak
a jl w7 will fit in the stock box?
It's not a W7
To the OP or anyone else, I read that if you run the stock sub wires to a LOC or to the high level inputs on your amp, you're not getting the best sound quality possible. The sound is going from the stock HU to the factory amp, then to your aftermarket amp. Double amping it can't be the best way to do it.
Is there any way, instead of connecting to the subwoofer wires, to connect to the source, BEFORE the factory amp??
Let me know please and thanks, picking up my new to me 07 SS/SC tomorrow and planning to get my $149 new sub and $250 brand new amp installed (in the factory sub box!!) right after I pick it up =)
-Jamie M.
*Edit: Found this diagram which looks like it's the unamplified input to the factory amp, so if I tap off those wires I Should be G2G!
Old Dec 2, 2011 | 10:55 PM
  #99
xtremecavy's Avatar
nice installs...im going to mod mine this winter when i down the car a while
Old Dec 5, 2011 | 04:15 PM
  #100
So, I had a super crazy 13W7 install all planned, take up most of the trunk, etc. But the GF said, after having two 12's in the Hyundai Accent and no trunk room "no way are you putting a monster speaker box in the trunk of this car too! You can upgrade the door speakers and anything else you want, but no changing the sub box!!!".
Do you think this is what she meant?
LICK FOR HIGH RES!
My "bump in the trunk" upgrade is gettin close to completion
RE Audio SEX 10D4 ($149 new) and JL 500/1v2 ($250 NIB).
-Jamie M.
(EDIT: A few trunk shots, and hey, I found out my car has a limited slip diff!! WOOT!!!)
LICK FOR HIGH RES!
LICK FOR HIGH RES!
LICK FOR HIGH RES!
LICK FOR HIGH RES!
