2.0 LSJ Engine: Howto remove and replace the drivebelt (EASY WAY)
Old Nov 26, 2006 | 12:57 PM
bdwarr6's Avatar
I learned this and it works everytime
TO remove your belt, remove your air box from supercharger
they plugs under the super and on top
Remove all 4 supercharger mounting bolts
your super will raise up on the end just pull it out and you have your belt off
To install it again just stick your SC snount into the belt and push down the read half of it when lined up on the studs for it
Its so much easier
Old Feb 9, 2007 | 09:24 PM
Codyak Supercharged's Avatar
and whats the torque settings for the bolts mounting the s/c?
Old Feb 9, 2007 | 09:50 PM
ItalianJoe1's Avatar
I think it was 18 ft./lbs, but i will have to double check. Not a whole lot.
Old Feb 9, 2007 | 09:52 PM
Mstumpy06's Avatar
and you do this bc? i just use a massive pry bar and put it on top of where they say to use a 15 mil wrench. much easier. you cant keep taking the charger off its gasket without any negative side effects.
Old Feb 9, 2007 | 10:04 PM
eastcoastz's Avatar
Just use a 15mm box and insert a 1\2 wratchet into the closed end for leverage. No this tensioner is TRICKY. I've been a auto tech for 6 years and this is the only auto tensioner like this. You have to push down and foward or else the box wrench wil just slip off ir you just push foward.
Old Feb 9, 2007 | 10:05 PM
thankyou!!! ^^
Old Feb 9, 2007 | 10:46 PM
Halfcent's Avatar
I'm old school
You are going to break/strip your bolts and damage the gasket and mating surfaces.
Old Oct 11, 2007 | 12:55 PM
coleredrocket's Avatar
It is 18ft lbs of torque for the supercharger bolts, not 36...
Old Oct 11, 2007 | 04:26 PM
beamSS's Avatar
Solaris99
28
Mar 15, 2017 01:22 PM
agentirons
Oct 16, 2015 02:11 AM
justinchinn
Oct 2, 2015 12:18 PM
DANRICKARD
Oct 1, 2015 12:08 AM
importkiller
Sep 30, 2015 07:18 PM
