2.2 L61 Engine: Hunter's How to Install M62 on 2.2l Cobalt
However, i will actually reccomend if you plan on making more power in the future, that you get some 60lbers now.
Alright thanks all! But since im running the 2.2 now and vince is the only tune available right now..do you think he can tune for the 60's or no? I think i should just go with the 42/5's for now because wouldnt i need alot more mods to even touch 250?
yea, he can tune for the 60's easily. really, if you think you might be running more horses in the future, get 60's, but if your positive you wont be going over around 280bhp (230-240whp), then you can stick with 42's
it'll be reliable.. just because of the pencil style injectors you'll have a slight sweep at idle it's not really a big deal
So I've got everything i need to supercharge mine just wonderin about the AC.. i know the SC belt has one more rib, I've got an lsj alternator, and a lightweight crank pulley with enough groves, and the idler pullye and tensioner off of an SS, but then there is the AC compressor pulley. what did you do about this?
Anywhere between $2000-$2800.....
someone find out the length of the belt and I'll find you the belt you SHOULD use for the swap.. or you can look at a different routing of the belt which requires a smooth alternator pulley as well like i'm using
as far as price. all the hard parts were $1300 used. figure $300 for a tune/piggyback and a couple hundred for a wideband. Everything else is optional. You can run this setup on stock exhaust even...it just wont perform nearly as well...so i reccomend an upgrade
you need 42s or 60s
correct me if i'm wrong casey, but it says plug in play on their website.
i asked another member on here and he said no other wiring was needed. lemme know
or explain why you took a new harness and and old one haha.
https://www.zzperformance.com/cobalt...=516&catid=144
you need 42s or 60s
you need 42s or 60s
I can grab pictures of both harnesses if that will help. But regardless, since no one makes a aftermarket wiring harness for the L61, you will have to make your own like I have done.
dammnn
that sucks.
you need to move to austin to help with this stuff !
i'll try and look at the pics and see if i can figure it out.
i've been really sick again, so nothing makes much sense haha.
that sucks.
