2.2 L61 Engine: Hunter's How to Install M62 on 2.2l Cobalt
Old Nov 27, 2008 | 01:56 AM
  #151
HunterKiller89's Avatar
Originally Posted by elecblue06
yes you can do that.. like i was doing but the less power you're running on 60s the harder it is to get them to run nicely honeslty i couldn't look at 60s unelss you're going to be pushing over 260 whp
thats not really true. its harder to get 60's to idle correctly, but its very much possible (even 72's are possible, but extremely finnicky). it doesnt matter if your car has 400whp or 140whp, it is just as hard to tune for 60's regardles.
However, i will actually reccomend if you plan on making more power in the future, that you get some 60lbers now.
Old Nov 27, 2008 | 10:51 AM
  #152
Motoxer4life's Avatar
Alright thanks all! But since im running the 2.2 now and vince is the only tune available right now..do you think he can tune for the 60's or no? I think i should just go with the 42/5's for now because wouldnt i need alot more mods to even touch 250?
Old Nov 27, 2008 | 11:30 AM
  #153
yea, he can tune for the 60's easily. really, if you think you might be running more horses in the future, get 60's, but if your positive you wont be going over around 280bhp (230-240whp), then you can stick with 42's
Old Nov 27, 2008 | 11:59 AM
  #154
Alright but you guys were saying the idle will start getting weird if i go with the 60's, i have to keep in mind this will be my daily driver and this is my only car so i need it pretty reliable.
Old Nov 27, 2008 | 03:10 PM
  #155
elecblue06's Avatar
it'll be reliable.. just because of the pencil style injectors you'll have a slight sweep at idle it's not really a big deal
Old Dec 8, 2008 | 10:06 PM
  #156
edaddee's Avatar
drooling, i mean watching
Old Dec 9, 2008 | 12:30 AM
  #157
I bought a camera on black friday
Old Dec 9, 2008 | 08:24 AM
  #158
Viper33884's Avatar
Did you pick up where you left off? LOL start disassembling and then re-assemble.
Old Dec 9, 2008 | 01:44 PM
  #159
IonNinja's Avatar
Black Friday was a long time ago, get those pics up
actually i don't really care since I already asked all my questions but others might wanna know
Old Dec 9, 2008 | 09:00 PM
  #160
made a quick video:
Old Dec 9, 2008 | 09:35 PM
  #161
YzRider452's Avatar
Dude more pics and vids, awesome btw
Old Dec 9, 2008 | 10:05 PM
  #162
gimme a couple days..lol
the blower and TB are getting a nice port job tomorrow, so you can really hear it scream
Old Dec 10, 2008 | 01:01 PM
  #163
MP81's Avatar
Damn! That sucker sounded mean!
Old Dec 10, 2008 | 02:26 PM
  #164
Viper33884's Avatar
Nice man, it sounds good.
Old Dec 10, 2008 | 02:34 PM
  #165
ChevyRockstar's Avatar
awesome and great job
Old Dec 10, 2008 | 03:27 PM
  #166
cobalt_addict's Avatar
So I've got everything i need to supercharge mine just wonderin about the AC.. i know the SC belt has one more rib, I've got an lsj alternator, and a lightweight crank pulley with enough groves, and the idler pullye and tensioner off of an SS, but then there is the AC compressor pulley. what did you do about this?
Old Dec 10, 2008 | 03:38 PM
  #167
scotch89's Avatar
how much was this project???/
Old Dec 11, 2008 | 12:09 PM
  #168
Viper33884's Avatar
I am also asking about this, I hate to loose the strength of the belt by cutting on it. I'm not sure if you have to replace the whole condensor or just the pulley.
Anywhere between $2000-$2800.....
Old Dec 11, 2008 | 12:28 PM
  #169
elecblue06's Avatar
someone find out the length of the belt and I'll find you the belt you SHOULD use for the swap.. or you can look at a different routing of the belt which requires a smooth alternator pulley as well like i'm using
Old Dec 11, 2008 | 04:56 PM
  #170
if you can just swap the pulley, that would be the easiest way to go...but in all honesty, Im using the stock belt on a 3" pulley (most LSJ guys use the STGII belt at that size pulley) with 1 rib cut off and i dont get any belt slip.
as far as price. all the hard parts were $1300 used. figure $300 for a tune/piggyback and a couple hundred for a wideband. Everything else is optional. You can run this setup on stock exhaust even...it just wont perform nearly as well...so i reccomend an upgrade
Old Dec 11, 2008 | 05:44 PM
  #171
umrdyldo's Avatar
So did anyone ever find an adapter or harness that will work with the injectors without splicing in new ones?
Old Dec 11, 2008 | 05:51 PM
  #172
ei3dag3's Avatar
https://www.zzperformance.com/cobalt...=516&catid=144
you need 42s or 60s
correct me if i'm wrong casey, but it says plug in play on their website.
i asked another member on here and he said no other wiring was needed. lemme know
or explain why you took a new harness and and old one haha.
Old Dec 11, 2008 | 08:08 PM
  #173
you need 42s or 60s
the LSJ injector harness, which is what you linked to, has 5 plugs. 4 for each of the injectors and a 5th to connect to the main wiring harness. The L61 however has 6 plugs. 4 for each injector, 1 for the MAP sensor, and 1 for the main wiring harness. There aren't any wiring harnesses out there that have all 6 connectors attached, and additionally, the connector that connects to the main wiring harness is different from the LSJ to the L61 (the LSJ is a single row 5 pin connector whereas the L61 is a double row 8 pin connector)
I can grab pictures of both harnesses if that will help. But regardless, since no one makes a aftermarket wiring harness for the L61, you will have to make your own like I have done.
Old Dec 11, 2008 | 08:30 PM
  #174
ei3dag3's Avatar
dammnn
that sucks.
you need to move to austin to help with this stuff !
i'll try and look at the pics and see if i can figure it out.
i've been really sick again, so nothing makes much sense haha.
Old Dec 11, 2008 | 09:59 PM
  #175
umrdyldo's Avatar
someone mentioned a cavy harness. what do they look like?
