Drivetrain: Intense TransAxle Mount HoW-to (56k get a beer)
Old May 7, 2008 | 08:06 AM
  #51
Renesis's Avatar
okay thanks for the help guys
Old May 8, 2008 | 09:10 AM
  #52
Renesis's Avatar
DAMMIT! finally went to a shop to have 'em installed today and they didn't have the exact size of tool for the press in their universal box so they couldn't take the old bushing out since our crappy mounts are made of PLASTIC!
****, I woke up early for no reason. the guy was really cool though and didn't charge me for the hour they wasted on this. Now I wonder where I'll take it to get it done. They said it would be too hard and way too long with a knife so it's better with the hydraulic press but uh.. I guess most shops will have the same sized tools..
Old May 8, 2008 | 06:10 PM
  #53
arkkornkid's Avatar
I don't know....guess I was just lucky. I took off my mounts, put them in a vise, wedged a big flat-head screwdriver between the plastic and housing and pried it out with no problem. I replaced them with prothane bushings and I just greased them up with synthetic grease, wedged at an angle as well as I could by hand and took a good heavy hammer (maybe a 5 lb. small sledge) and popped it right in...again no problems. Just made sure the bolt sleeve wasn't in at the time so it could flex.
Old May 8, 2008 | 10:33 PM
  #54
Renesis's Avatar
might be because on the 2.4 our motor mounts are NOT made of metal, unlike on the 2.0!
Old May 9, 2008 | 08:19 AM
  #55
I just went with cobalt addictions that has a new mount and poly all in one. Just undo the bolts out of the old one and pull the mount out, insert new mount with bolts and done. bam 10 mins. Hardest part was my big ass layin on the ground and not falling asleep under the car. lol done it before
Old May 9, 2008 | 08:30 AM
  #56
USMCFieldMP's Avatar
Rattlesnake Race Shop
IF I keep this car... I'm probably just going to upgrade to the BWoody SOLID mounts.
Old May 16, 2008 | 05:46 PM
  #57
Brandon97Z's Avatar
****** weaksauce. Was going to install mine tonight and never knew it was plastic till now.
Old May 16, 2008 | 06:17 PM
  #58
Mr_Slobalt's Avatar
I just pressed my old mounts out tonight and discovered that the outside of the rubber is plastic. : /
I'll have them in tomorrow after work!
Old May 18, 2008 | 11:26 AM
  #59
Code5's Avatar
Torque values for trans mounts: From p7-5 & p7-42 Helm manual
Front Mount - (2) 37 lb ft.
Rear Mount -
Frame Bolts (3) 44lb. ft.
Bracket to Trans Axle - (3) 44 lb ft
Thru bolts are the ones thru the center of the bushings. This prcedure is done after the mounts are torqued.
The thru bolts are torqued after allowing them to settle as follows- both front & rear thru bolts loose, shake powertrain front to rear direction vigoroulsy, then tighten the thru bolts to 74 lb ft
Old May 20, 2008 | 07:48 PM
  #60
bigworm's Avatar
an easier way to do this:
things needed:
- one fat friend
- screwdriver
- lighter
- block of wood or similar flat surface
- a curb
- wall
1. drive your car up onto a curb so that only your front passenger side wheel is on it. This should give you enough clearance to get under the car to remove the mounts.
2. you can get a screw driver in between the rubber of the mount and the metal surface, apply a little heat directly to the rubber with a lighter until the rubber has warpped. At this point the rubber will slide out with minimal force.
3. Call up your fattest friend, the bigger the better. While you wait for him to get done eating his taco bell, remove the metal middle piece supplied with the new poly mount.
5. Goto your wall. place and hold a block of wood on the poly material over the hole of the mount and have your fat friend step up onto it while balancing on the wall. Have them hop or jump til its fitted in smoothly. Depending on size of fat friend, this should take 2-3 hops.
STAY TUNED... MORE OAKLAND MODS TO COME...
Old May 20, 2008 | 11:18 PM
  #61
Brandon97Z's Avatar
^^^lol i actually did just that. Didn't know if it would work but my 220lb ass did it then a vice to finish it off. Pretty easy install.
Old Aug 13, 2008 | 10:55 AM
  #62
Opi's Avatar
Opi
bumping this up to subscribe. will be doing this this weekend.
also, i plan on just burning the old mounts out. anything wrong with that?
Old Nov 3, 2008 | 03:41 PM
  #63
RecklessL61's Avatar
hey man this really helped with mine thanks oh and buy the way you dont have to take off that bracket on the rear one if you have a 2.2 with stock down pipe you can lift the mount up and over the downpipe and out the over side of it
Old Nov 3, 2008 | 04:22 PM
  #64
WickedSS2005's Avatar
Hmm, tagged cuz I'm lazy and don't wanna figure it out myself
Old Nov 3, 2008 | 05:20 PM
  #65
I'll trade you my Mounts for Your Mounts...
...I'll PM you this as well.
Old Nov 16, 2008 | 05:09 AM
  #66
NWAE Cobalt's Avatar
will be using this tomorrow....will update with some more pics maybe
Jan 12, 2016 12:01 AM
OrangeCoba
Oct 1, 2015 10:00 PM
n20saturn
Sep 30, 2015 12:26 AM
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
