Appearance: Make a shorty antenna
Old Sep 18, 2007 | 02:16 PM
  #51
kilocobalt's Avatar
Originally Posted by rlinden86
thats ****** retarded i would spend the 20 bucks for it to be done right.
ryna.
I have an '07 and none of the shorty's fit. The antenna looks great. Waste your money on plastic. I'll put the extra $18 in my tank son.
Old Sep 20, 2007 | 11:31 PM
  #52
wdsoccer's Avatar
im doin this tomorrow
Old Sep 21, 2007 | 03:46 PM
  #53
kilocobalt's Avatar
Let us know how it turned out, and out of curiosity, what length you cut it to...
Old Sep 25, 2007 | 07:52 PM
  #54
G3RG's Avatar
very nice, im doin myne this weekend. ill post a pic then..
Old Sep 26, 2007 | 12:49 PM
  #55
weavagra's Avatar
mine
Old Sep 26, 2007 | 04:27 PM
  #56
Black07LS's Avatar
Originally Posted by weavagra
mine
how long is that? It looks shorter than mine and mine's about 8".
Old Sep 26, 2007 | 07:41 PM
  #57
LSCobaltlover05's Avatar
*insert ***** joke here*
Old Sep 27, 2007 | 05:20 PM
  #58
cobeeezy's Avatar
Why pay $20 for an antenna when you can cut yours down to size?
1:Remove antenna from car.
2:Wrap antenna with electricle tape just below were you want to cut.(This helps keep the small wire attached)
3:Cut antenna flush with top of tape with a cut off wheel. A hacksaw should also work.
4:Use 1/8" rubber vacuum cap ($1.49 for 5 at AutoZone) as a tip. Twist cap as you push it on antenna. (this will push the tape down)
5:Remove tape.
6:Reinstall.
7:ENJOY your shorty.
hell yeh man this **** really worked!
Old Nov 4, 2007 | 09:03 PM
  #59
BLACK2007LS's Avatar
great write-up, its easy and it works just as well as the normal length (at least in Indy). i still need to buy a cap for the end, right now i just made my own using electrical tape haha it actually doesnt look bad at all
Old Nov 20, 2007 | 09:41 PM
  #60
LENNY SS's Avatar
Great How To Cut My Antenna To 12" Works Fine Looks Much Better To
Old Nov 23, 2007 | 01:37 PM
  #61
Blue_Balt's Avatar
I'm going to do this today
I'll post a pic of the end result.
Old Nov 25, 2007 | 03:43 PM
  #62
mr.right's Avatar
eh... i will leave mine UNcut.
Old Nov 25, 2007 | 03:44 PM
  #63
CobaltVenomSS's Avatar
mine took 4 minutes
Old Nov 25, 2007 | 04:06 PM
  #64
step n up 09's Avatar
heres mine
Old Dec 8, 2007 | 01:17 PM
  #65
laxguysix's Avatar
nice write up
Old Dec 17, 2007 | 08:28 PM
  #66
YelloEye's Avatar
Did mine the same way as OP, the wire wrap came off so I just sprayed it with black paint. Reception got worse without the wire and shorter antenna but I don't really listen to the radio.
Old Dec 17, 2007 | 09:04 PM
  #67
G3RG's Avatar
I havent had time to do mine yet. I will try this week when I am givin the opportunity. mos likely this weekend
Old Dec 20, 2007 | 07:38 PM
  #68
Codeman35's Avatar
I am DEFINATELY going to do this that stocker just seems soooooooooooo BIG and gaudy. Thanks for the info
Old Dec 29, 2007 | 05:00 PM
  #69
Preston's Avatar
well that was a bitch...haha
Old Feb 27, 2008 | 10:09 PM
  #70
MBMCustoms's Avatar
Originally Posted by shawn672
what is everyone using to cut this? i dont wanna go attempt to cut it and end up just making a big mark on it ;( i got some wire cutters but idk how strong the metal on the antenna is?
if you have access to a Dremel tool you can use that! thats what i did and i had no problems. sparks flew for a second and whalla... SHORT!!!
Old Feb 27, 2008 | 10:15 PM
  #71
Mr_Slobalt's Avatar
I need to do this, this weekend. I tried buying the $5 shorty antenna from Advance Auto Parts and it didn't fit my car. Good thing it didn't cost me a dime to find out. lol
Old Mar 25, 2008 | 10:06 PM
  #72
Routs's Avatar
Just did it. Looks a lot better. Easiest mod I've ever done.
Old Mar 28, 2008 | 01:27 PM
  #73
blackjack hotrods's Avatar
Just a thought: Wouldn't it be a good idea to cut the wire wrap first with a pair of wire cutters just to be sure it doesn't come undone? I'm in the Phoenix Metro area of Az and I'm sure I wouldn't have any reception probs. The first thing I thought when I got my car was "Man that antenna is UG-LY!"
Old Mar 28, 2008 | 03:28 PM
  #74
arkkornkid's Avatar
I used a good set of bolt cutters and it worked perfectly, didn't tear the wire or anything.
Old Mar 28, 2008 | 09:11 PM
  #75
Here is mine without the antenna:
Not sure if I like it gone. I am gonna shorten the mast when I get to work tomorrow. I'll post pics.
