All Engines: Sea foam (CORRECT HOW TO)
Old Jul 28, 2011 | 04:57 PM
Chevycobaltss3's Avatar
And for lnfs are direct injection which means it dont hit the valves so running e wont do anything but clean the top of the pistons and possibly portion of the valve. the sea foam will actually clean the intak manifold and the valves, and the top of the pistons, and if you put it in the oil it cleans everything.. and i mean everything!!!!
Old Sep 4, 2011 | 07:31 PM
toeknee(ss)'s Avatar
interesting
Old Sep 4, 2011 | 07:47 PM
Omnigear's Avatar
Old Sep 4, 2011 | 08:26 PM
RooTBeeR's Avatar
literally just changed the oil...haven't even driven it yet, maybe i should seafoam it for the first time? 52,2XXmiles
also need to replace the vacuum lines so will have off anyway
Old Sep 4, 2011 | 08:35 PM
Karlen89's Avatar
Don't waste the oil. Do it next oil change. I never seafoamed my car until 104k, you'll be alright.
Old Sep 4, 2011 | 08:41 PM
RooTBeeR's Avatar
maybe just gas/intake then
Old Sep 4, 2011 | 09:01 PM
Karlen89's Avatar
Or just wait.
Old Sep 4, 2011 | 09:20 PM
nhanson's Avatar
nice copy/paste
Old Sep 4, 2011 | 10:09 PM
SSSnoop's Avatar
Bonus points for showing a good vacuum line! I was wondering what to disconnect on my LNF. I've done V8's and I've drawn it through 8 different ways to sunday. Never did a boosted car, tho.
Old Sep 5, 2011 | 12:01 AM
You notice the url is there to the seafoam site.... i didnt make this thread for **** and giggles i did it so people dont have to look..
Originally Posted by nhanson
nice copy/paste
Old Sep 5, 2011 | 02:34 PM
  #36
727's Avatar
727
... i wrote about LSJ:
Hose from boost solenoid to intake doesn't feeds with seafoam all cylinders ... (!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!)
Today I get off sparks after all - putting 1/3 seafoam with this hose ... and turn it off ... but only second (2) spark was wet with seafoam. Others was dry ...
Sooooooo ... WTF? ) Buy seafoam spray?
Old Sep 5, 2011 | 05:33 PM
  #37
i have always put it into the vacuum line from the bypass solonoid on the s.c top hose and sucked it in before thhe sc so it cleaned the intake mani and ect...
Old Sep 6, 2011 | 02:15 AM
  #38
rukkee's Avatar
I always use NUMBER 1 marked on the pic below ..... but there is another spot to use (#2 on pic) But #1 is more centered so it should pull seafoam even to all cylinders.
Old Sep 6, 2011 | 06:39 PM
  #39
SSSnoop's Avatar
do you cap/plug the hose while you do this? I'm assuming you use another hose to pipe it into #1 in your pic, or at least that's how I figger I'm going to do this.
Just bought my seafoam can for my 02 Tacoma - that hog needs a full douche-ing with the stuff as part of my pre-winter overhaul.
Old Sep 6, 2011 | 07:16 PM
  #40
JL-KA's Avatar
Can someone point out the hose to use on the 2.2? Or is it the same as the SS/TC?
Old Sep 6, 2011 | 08:35 PM
  #41
rukkee's Avatar
Your right on about the extra piece of vacuum line..... I have a 1 foot piece that i use to get the seafoam in. You don't have to cap or plug the hose you take off .
Old Sep 7, 2011 | 06:23 AM
  #42
nutty21's Avatar
Sticky?
Old Sep 7, 2011 | 08:18 AM
  #43
rukkee's Avatar
Originally Posted by nutty21
Sticky?
It would prolly be a good Idea ...... with the way Direct injection works I'm sure people are gunna be looking for a how to . Chevycobaltss3 , If you want to copy that pic of the intake manifold with the numbers on it into your 1st post your welcome to it .
Old Sep 7, 2011 | 09:23 AM
  #44
Gremlin85's Avatar
I'm making a detailed "How-To" VIDEO in the coming couple of weeks. It will be LNF specific but give a better idea on the whole process.
Old Sep 7, 2011 | 11:42 AM
  #45
JL-KA's Avatar
You should try to get a 2.2 and a SC there for the vid as well. At least to show which hose to use.
Old Sep 7, 2011 | 11:58 AM
  #46
Staged07SS's Avatar
Administrator
Administrator
Nice write up.
Old Sep 7, 2011 | 12:06 PM
  #47
BYT*SS*TURBO's Avatar
I noticed this fouls the plugs up when doing it thru the vacuum line. So, IMHO, I would change plugs and oil after doing a Seafoam treatment.
Old Sep 7, 2011 | 12:27 PM
  #48
rukkee's Avatar
I've always thought it wouldn't be the best thing for spark plugs ...... I usually change mine every 8-10K miles so maybe thats why I haven't noticed any real effects from fouled plugs . Or maybe because the tune I'm running is so much more conservative than yours BYT?
Old Sep 7, 2011 | 12:34 PM
  #49
I didn't notice anything negative from it but they looked pretty nasty after the Seafoam. So just for good measure, I change both when I do it. I try to do the Seafoam when I would change plugs anyway. I also soak the front O2 in denatured Alcohol when I do all of this (obviously AFTER the seafoam lol).
Old Sep 7, 2011 | 02:18 PM
  #50
rukkee's Avatar
Damn ....... I never even thought about the o2 sensors . I'm sure I'll be do for a front sooner than later lol.
