All Engines: Sea foam (CORRECT HOW TO)
Old Oct 19, 2011 | 10:29 AM
  #76
brtnsnw4's Avatar
Which end of the #1 hose do i remove to pour in the sea foam? And does sea foaming do anything to void warranty?
Old Oct 19, 2011 | 02:48 PM
  #77
nhanson's Avatar
It shouldnt if you do it right
Old Oct 20, 2011 | 04:38 PM
  #78
jonnymerk's Avatar
Any pics yet of the hose LSJ guys use. I converted to turbo and didn't do my vacuum lines so Im not 100 sure.
Old Oct 20, 2011 | 05:42 PM
  #79
Chevycobaltss3's Avatar
if you are using a after market intake use the brake booster line, if still stock intake mani id use a vacuum source on the mani but no the one in the middle of the mani.... somehow make it work..!!
Old Oct 20, 2011 | 07:47 PM
  #80
xxxxsh4d0wxxxx's Avatar
Originally Posted by 727
... i wrote about LSJ:
Hose from boost solenoid to intake doesn't feeds with seafoam all cylinders ... (!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!)
Today I get off sparks after all - putting 1/3 seafoam with this hose ... and turn it off ... but only second (2) spark was wet with seafoam. Others was dry ...
Sooooooo ... WTF? ) Buy seafoam spray?
x2
Old Oct 21, 2011 | 12:22 PM
  #81
user 72239's Avatar
So i got some seafoam from Pep boys and read this how to, but it says you do NOT need to change your Oil after doing this. but you guys are? am i missing something?
Old Oct 21, 2011 | 08:33 PM
  #82
rukkee's Avatar
I ....as well as a bunch of others..... do a seafoam treatment at every oil change ...... maybe that's why it's confusing . Personally..... I like doing a seafoam treatment right before changing the oil so then there is no way the oil could be contaminated .
But if you feel you need to seafoam with a lot of life left in your oil .....it shouldn't be a problem according to seafoams manufacturer. The only time it's a must is if you add it to the crankcase.
Old Oct 24, 2011 | 09:46 AM
  #83
Getaway_Driver's Avatar
How the hell did you guys remove that damn vaccuum line? That **** is hurting my fingers!
Seriously, guys. I've been messing with the ******* clip attached to it, but it's not really doing **** for me. Please help!
Old Oct 24, 2011 | 09:49 AM
  #84
user 72239's Avatar
im hoping seafoam will fix a sticky lifter I have, so i guess ill have to wait a bit to put it in the crankcase. I just changed my oil last week lol
Old Oct 24, 2011 | 12:09 PM
  #85
Nvm. I figured it out, but now I have a different question:
Is the green clip really necessary? Can't I just put the line back on without it to make it easier? In fact, maybe zip ties could work just as well & be easier to remove/reinstall, right?
Old Oct 24, 2011 | 12:11 PM
  #86
umrdyldo's Avatar
Just use pliers. It's super easy.
Yes it's necessary.
Old Oct 24, 2011 | 07:47 PM
  #87
Green clip?
Old Jan 12, 2012 | 12:50 AM
  #88
cobalt_sport08's Avatar
very nice how-to, so would this be a good thing to try if we dont know if our engines have every been cleaned?? im about to roll up on 57K miles
Old Jan 12, 2012 | 12:57 AM
  #89
Yes. it is a good start ..
Old Jan 13, 2012 | 12:02 AM
  #90
gotcha, whats a good can size for the 2.4?? a 12oz or 16oz
Old Jan 13, 2012 | 12:05 AM
  #91
Larger 16oz.
Old Jan 13, 2012 | 12:11 AM
  #92
ok thanks
Old Feb 3, 2012 | 12:32 PM
  #93
Fen52690's Avatar
i just used this stuff yesterday i swear i can tell a huge diff in performance cause my car was feeling sluggish great stuff
Old Mar 13, 2012 | 12:20 AM
  #94
baraklee263's Avatar
I have a 2.0 lsj redline.. Im not sure what hose to use to put into the intake? I saw the other how to on this, but i still dont get where exactly it goes..?
Old Mar 13, 2012 | 12:38 PM
  #95
The hose I mainly use on lsjs is the bypass valve line. So it can truly clean the laminovas and intake runners....... The hose on the s.c, use it. You'll need to take stockers off and add a larger enough line.
Old Mar 13, 2012 | 04:25 PM
  #96
Yeah, i saw in the other topic about the bypass line, but it doesnt really point to which one.. I heard some people put it into their brakes by accident.. I dont wanna do that!
Old Mar 15, 2012 | 06:58 AM
  #97
cobythecobalt's Avatar
OK I have a 2.2L Lap Tech. I can't get to the brake booster hose cuz it's under a bunch of stuff, and I read that I can use one of the hoses on the intake. The hose I thought it was had no suction, so my question is, what hose do I use? I'm getting so frustrated! Could someone show me in a picture or something?
Old May 23, 2012 | 08:14 PM
  #98
rchiwawa's Avatar
I just seafoamed through the central vacuum line (#1 as illustrated) for my LNF's 2nd anniversary and just after the 61,000 mile mark and man did it change the personality of the car. I guess I simply didn't notice the effects of build up on my intake valves because of the gradual nature of the contamination. The car was occasionally running out of steam at 5,000-5,500 rpm and figured this had to be the culprit... the cold idle was also very noticeably affected for the better. Thanks for the specific write up.
Old May 25, 2012 | 10:20 AM
  #99
ROB517's Avatar
ok i want to do this but i feel like im going to f up using the vacum line. So i can just put a 1/3 a can into the oil and some into the gas tank. Drive around for a while then change the oil?
Old May 27, 2012 | 07:21 PM
  #100
Frogstofall's Avatar
Yes but you won't clean the valves that way. That's the whole reason to do this on the LNF.
Extreme Dimensions
Sep 24, 2015 05:24 PM
dennis69
Sep 22, 2015 08:33 PM
Jeffwills14
Sep 6, 2015 06:52 PM
