Appearance: V-LEDs V3 Triton Switchbacks Install
Old Jan 4, 2013 | 02:20 AM
serega12's Avatar
Well, right now would be a good time to buy them at that price.
Old Jan 4, 2013 | 02:27 AM
EmperorJJ1's Avatar
it would but im not looking to upgrade my lights until later so it is what it is. well see what happens once i get to that point
Old Feb 1, 2014 | 11:15 PM
Grave's Avatar
I just wanted to bump this thread because there is an updated version that doesn't have ridiculously sized components.
This is the complete setup:
Mounting these shouldn't be a problem at all now.
Old Feb 3, 2014 | 12:31 AM
serega12's Avatar
Yeah, I need to send mine in to get the version 2 setup. My old one started acting up a few months back, so I requested a replacement. They said I can get a brand new set up.
Old Feb 3, 2014 | 02:08 AM
serega12's Avatar
Already ordered replacement system. Should get the defective one mailed out tomorrow.
Old Feb 3, 2014 | 06:20 AM
z062007vette's Avatar
I got the updated one, but never got around to posting it. Heck of a lot easier to mount. I have mine held on the top screw of the wheel well. keeps it up high from water and so far it hasn't died on me.
Old Mar 27, 2014 | 10:10 AM
727's Avatar
727
If you want to order this leds - try to use "CLUBLEXUS" coupon code found & worked today -15%
Yesterday paid for Kit ...
Little help to other - if you have 3157 bulb (dual) - use this link:
5K WHITE AMBER SWITCHBACK V3 TRITON LED SYSTEM 3156 3157 3157CK | 1 PAIR http://www.vleds.com/shop-bulb-numbe...a-5k-3157.html
DONT FORGET TO SELECT BASE ADAPTERS to 3157 for clear bolt-on setup
Also if you want to use it on 3156 - select additional option there
This is only little help NO AD ... because when you select BASE kit - you'll see many options to select ... it brokes my mind at all ))
Have a nice day.
Old Apr 10, 2014 | 08:23 PM
serega12's Avatar
Installed the updated one... Did some driving in VERY wet conditions.. had to have one controller replaced under warranty because it leaked, shorted out, and fried my parking light fuse. When I received the new replacements, which are supposed to be sealed a lot better, I mounted them further back, not right at the grille, and they work just fine.
and yes, gen 2 are a lot easier to mount and then connectors are way better.
Solaris99
28
Mar 15, 2017 01:22 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
