How to requests and questions Please post your requests and questions for How to Guides.
Code PO010
Old Nov 24, 2013 | 05:20 PM
bodi2609's Avatar
Code PO010
I just bought a 2008 Cobalt Sport and it has this code that appears twice. PO010 which is a cam code. I replaced the cam sensor at the advice of my mechanic. The code went out for a few minutes but back again twice. Thinking maybe the crank sensor next but thought I would ask if anyone else has any ideas so I don't waste money changing parts that wont help. Thanks for any thoughts.
Old Nov 24, 2013 | 05:27 PM
chevygirl2006's Avatar
So you changed the solenoid right? The ones on top of the valve cover.
Old Nov 24, 2013 | 06:35 PM
ItalianJoe1's Avatar
Replace the solenoids on top of the engine, in the middle of the valve cover. Change both of them, if one is failing the other is usually close behind.
Dorman makes nice aftermarket ones now, or you can get OEM ones. They aren't terribly expensive and only have one bolt holding them in, just pop them out.
Often on older cars they are stuck in there pretty well, I find taking a larger prybar and using it to catch them under the lip on the plug and lift the solenoid out works really well. Oil the o-ring on the new one before you install, and make sure the area is clean before you remove them (crap tends to settle in there, blow it out with compressed air before removing) and before you install the new ones.
Old Nov 24, 2013 | 06:36 PM
Also, does the engine have good fresh oil in and and the proper amount? Those solenoids are using oil to actuate the cams, sometimes if the oil is very poor or low it can cause issues. Will set a different code than what you have though.
Old Nov 25, 2013 | 09:35 AM
bodi2609's Avatar
Awesome
Ok thanks guys will replace and let you know. Appreciate it.
Old Dec 11, 2013 | 07:20 PM
bodi2609's Avatar
Thanks Very Much
Hey everyone sorry it took so long to get back but the solenoids were on order. Changed them both and it worked. Code is gone so just want to thank you all. You rock.
Old Dec 11, 2013 | 08:12 PM
There ya go, glad we could help.
Old Jan 11, 2014 | 08:00 PM
bodi2609's Avatar
Hey everyone have another issue that im sure you can give me the right info. I keep getting a trunk open message even though the trunk is closed properly. Any ideas?
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
