JBP Cams Revisited: New Grind for `09!
Old Jul 3, 2009 | 12:13 PM
  #351
im still waiting on the dyno graph
Old Jul 7, 2009 | 02:08 PM
  #352
JBP's Avatar
JBP
BEFORE
AFTER
Sorry for the long delay in posting the before and after dyno's. The engine has more torque top end. With the new cams you lose the linear torque band and bottom end suffers quite a bit. We hooked up the AFR in the tail pipe for the AFTER install run and peg rich up top, but nothing too detrimental. The car chases the commanded idle, it is hard to keep. The sound is extensively rumbly and pleasant to the ears. We sincerely feel with adequate tuning, the LSJ can fetch double the HP numbers with these cams, maybe more. We're going to keep tuning and see if we can do. After market Valve springs are necessary to prevent coil bind. The lift is 0.480", the duration is 262*. At this moment, we'll slap a part number on these cams and throw them up on the website tonight and plan a GB too. Like I said before, we were hoping for more out-of-the box hp, but it looks like tuning will be a real challenge for each and every car since there are so many variables.
Old Jul 7, 2009 | 04:49 PM
  #353
Area47's Avatar
Rent me! per hour
anyone else see the error behind these graphs?
Old Jul 7, 2009 | 04:53 PM
  #354
paul1588's Avatar
do tell
Old Jul 7, 2009 | 04:54 PM
  #355
cruisn's Avatar
time and speed are used??? just a guess
Old Jul 7, 2009 | 05:01 PM
  #356
Area47's Avatar
Rent me! per hour
gear changes.
red is usually the most recent runs on a dyno jet. can be changed though.
no rpms. using speed, or time will increase the power numbers in the calculations.
the average user is going to look at these charts and be confused as to what the real numbers are before and after.
Old Jul 7, 2009 | 05:13 PM
  #357
cruisn's Avatar
gear changes.
I was close. lol
Old Jul 7, 2009 | 05:35 PM
  #358
enlighten us
Old Jul 7, 2009 | 06:33 PM
  #359
JBP's Avatar
JBP
gear changes.
regardless, heading back to the dyno after more tuning. we'll squeeze more than 8.2whp. we'll put up every variable requested if need be.. then switch back to stock and do another base line with every variable requested. There's nothing to hide behind these cams.
also if anyone is concerned, the test car only has a 3.0" exhaust for mods. Everything else is stock.
Old Jul 7, 2009 | 06:42 PM
  #360
drew1991sf's Avatar
is that dp back? or cat-back? and is it catless
Old Jul 7, 2009 | 06:44 PM
  #361
Area47's Avatar
Rent me! per hour
Mev. if you wouldn't have played the game of **** with the numbers via every possible factor. we would not be in this situation.
Old Jul 7, 2009 | 08:30 PM
  #362
06blackg85ss's Avatar
^^^^ exactly.
Again I warn all to stay away from these guys...... Trust me.
Old Jul 7, 2009 | 10:20 PM
  #363
Darkmanx's Avatar
lalallalalla.
Old Jul 7, 2009 | 10:30 PM
  #364
BLAZIN07SS's Avatar
I'm too JDM for you
who in the hell posts dyno graphs referenced by time?
Old Jul 8, 2009 | 07:15 AM
  #365
JBP that's who.
Old Aug 10, 2009 | 05:30 PM
  #366
StevesBlack06's Avatar
sub'd
Old Aug 10, 2009 | 05:49 PM
  #367
for what?
Old Aug 10, 2009 | 05:50 PM
  #368
hatrickstu's Avatar
this must be the same dyno work that provided 31 whp gain with the header.
Old Aug 10, 2009 | 05:52 PM
  #369
Area47's Avatar
Rent me! per hour
oh snaps!
Old Aug 10, 2009 | 05:56 PM
  #370
Deathscythe's Avatar
I gained 52 from the vortex! Uh..., I meant lost 52.
Old Aug 10, 2009 | 08:14 PM
  #371
lol!
Sl0wbaltSS
Nov 21, 2018 11:11 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
Sign_Something
13
Sep 26, 2015 11:44 AM
