DEPO Projector headlights for 05-10 Cobalts LOTS OF PICS !
i might just cut one of the t things off, cause 1 goes in easy, but the other doesnt. also before i do that, ill pull the bumper off on that side so its easier to get at
It takes time, but just work at it...maybe you know this, but it goes in easier if you put the inside (closer to the center of the car) part in first and then work the outside in after...rather than trying to push it in evenly. Hope you understand what I mean because I don't know how to word it any better.
Here's my NON HID (H-7) Osram 65W in Low Beams 3200K:
Non HID H-11 65 W (100% Xenon oversized bulb) 6000K:
NOTE: Turn signals are chrome coated and amber when it
*bump*
I ordered a set and put them on. They look great and where plug and play.
My question is how do you align these. I see the *** on the back is that to adjust the beam up and down?
Also which way should I turn it to raise the beam and about how much turning do u think it takes cus I turned it to the right some and didnt see a difference. Does it need to be turned a good amount you think?
*bump*
yeah i didnt do it at my house so i just used one of my keys. first time i did it they were way to high now they are pointing at the ground and i cant see **** ive just been to lazy to re aim them.
ya. it takes a little while. uve gotta take the time to do it. it isnt just a walk outside and flip a switch and ur good.
For me turning to the right as if you are facing the screw adjusted them up.
Turbo Johnny
Feb 21, 2019 09:41 AM
