Modern Performance Modern Performance is a Supporting Vendor
contacts: Modernceo
DEPO Projector headlights for 05-10 Cobalts LOTS OF PICS !
Old Apr 28, 2011 | 09:26 PM
  #151
DiabeticKripple's Avatar
i might just cut one of the t things off, cause 1 goes in easy, but the other doesnt. also before i do that, ill pull the bumper off on that side so its easier to get at
Old Apr 29, 2011 | 12:22 AM
  #152
007CobaltLS's Avatar
Do not cut one off...just keep working it...it took me a few tries both times I tried. I had to remove it to get to my air filter in the front bumper so I could replace the Injen filter with an AEM dryflow.
It takes time, but just work at it...maybe you know this, but it goes in easier if you put the inside (closer to the center of the car) part in first and then work the outside in after...rather than trying to push it in evenly. Hope you understand what I mean because I don't know how to word it any better.
Old Apr 29, 2011 | 12:24 AM
  #153
ya i was trying that for like 5mins then said **** it. but the t on the inside goes in easy, other one not so much. ill try your method next time.
Old Jun 18, 2011 | 04:57 PM
  #154
ronn's Avatar
Originally Posted by bobbyhill31286
here's an updated pic of mine with the hids and hid fogs (i just put the fogs in yesterday)
Just installed these bulbs in Gen4s
Here's my NON HID (H-7) Osram 65W in Low Beams 3200K:
Non HID H-11 65 W (100% Xenon oversized bulb) 6000K:
NOTE: Turn signals are chrome coated and amber when it
Old Jul 12, 2011 | 05:15 PM
  #155
Modernceo's Avatar
Great pics. Thanks for sharing with us!
Old Jan 20, 2012 | 07:01 PM
  #156
jonnymerk's Avatar
*bump*
I ordered a set and put them on. They look great and where plug and play.
My question is how do you align these. I see the *** on the back is that to adjust the beam up and down?
Also which way should I turn it to raise the beam and about how much turning do u think it takes cus I turned it to the right some and didnt see a difference. Does it need to be turned a good amount you think?
Old Jan 20, 2012 | 07:02 PM
  #157
BPacak's Avatar
Vtec Rep
yeah its that ***, and you have to turn it a good amount, not sure which way. just pull like 20 feet away from a wall/garage door and align them.
Old Jan 20, 2012 | 07:06 PM
  #158
kikal8's Avatar
Originally Posted by jonnymerk
*bump*
ya. these lights are tuff to aim. those knob things with teeth aim the lights up and down. if u park at a garage door or something like that aiming ur headlights at it then turn the knobs ull find it does a good amount actually. i found it took awhile to get mine aimed correct to how i wanted them. i aimed against my garage then drove and looked at how it was aiming and they were slightly high so i pulled over and did it in the middle of the road and got em how i wanted. now they r good. as far as which direction aims which way.. im not sure. ha
Old Jan 20, 2012 | 07:09 PM
  #159
BPacak's Avatar
Vtec Rep
are they a bitch to turn for you guys too? i can barely do it with my fingers
Old Jan 20, 2012 | 07:10 PM
  #160
kikal8's Avatar
haha ya. i didnt do it with my fingers i got a really small flathead screwdriver and put it in the little teeth
Old Jan 20, 2012 | 07:14 PM
  #161
BPacak's Avatar
Vtec Rep
yeah i didnt do it at my house so i just used one of my keys. first time i did it they were way to high now they are pointing at the ground and i cant see **** ive just been to lazy to re aim them.
Old Jan 20, 2012 | 07:21 PM
  #162
kikal8's Avatar
ya. it takes a little while. uve gotta take the time to do it. it isnt just a walk outside and flip a switch and ur good.
Old Jan 20, 2012 | 08:00 PM
  #163
jonnymerk's Avatar
ya I also used a small flat had and pushed on the teeth. got them even with my garage door but will have to drive to see if they are good. First go around they felt low. so I adjust them a tiny bit up.
For me turning to the right as if you are facing the screw adjusted them up.
Old Jan 20, 2012 | 08:25 PM
  #164
i think i have mine up all the way haha. it only comes up halfway on peoples cars so im not blinding them..... except when i hit a bump
Turbo Johnny
Feb 21, 2019 09:41 AM
TedSS
101
Apr 25, 2016 10:46 PM
Pasierbek
Dec 10, 2015 07:22 PM
Bluelightning
Nov 11, 2015 02:41 PM
chefhhr
Oct 26, 2015 10:36 PM
