07 Cobalt SS/SC Owner
Old Jun 27, 2014 | 08:24 AM
vazquez8's Avatar
My Lsj Has A Misfire In Cylinder 4 , Two Mechanics Told Me A Piston,
Help?
Old Jun 27, 2014 | 08:31 AM
Staged07SS's Avatar
Administrator
Administrator
First of all welcome to the site
Before you panic, try a few things first.
A misfire can be brought on by a bad coil pack. Try swapping the #4 coil pack with say the #3 coil pack.
If you get a misfire on #3, you will then know it's the coil pack. Also, check your plugs.
Old Jun 27, 2014 | 08:34 AM
Old Jun 27, 2014 | 08:46 AM
vazquez8's Avatar
Thanks appreciate it.
And I did that all ready and I got new sparkplugs, it had a little bit of oil in cylinder 4, my car sounds like a subaru still right now.
Old Jun 27, 2014 | 08:47 AM
Staged07SS's Avatar
Administrator
Administrator
That would be #4 then.
Did you do a compression and leak down test?
Old Jun 27, 2014 | 08:50 AM
vazquez8's Avatar
Yes #4
&& no I hasn't,
So it can't be a piston ?
Old Jun 27, 2014 | 08:52 AM
Staged07SS's Avatar
Administrator
Administrator
Yes #4
&& no I hasn't,
I said that would be #4 meaning the #4 piston is prob shot.
The subaru sound is the common sound when a piston goes on these car.
Do a compression and leak down to verify for sure.
Old Jun 27, 2014 | 09:00 AM
vazquez8's Avatar
Dangg it ,
So how do I check the compression and leak down test?
If it's a prob piston is that really bad?
Old Jun 27, 2014 | 09:06 AM
Staged07SS's Avatar
Administrator
Administrator
Dangg it ,
If you can repair it yourself, it's not that bad. If not, it can be pricey.
You will need a compression tester to check.
If you dont have one, ask your mechanic to check it for you. Compression should be in the 190-200 range across the board on a healthy LSJ. It can vary though.
If #4 is obviously lower than the rest, you will know for sure.
Old Jun 27, 2014 | 09:10 AM
vazquez8's Avatar
Well I hope it's not a piston..
Okay I think am gonna do it myself , if the other 3 are around the same , and piston 4th low what dose it mean?
Old Jun 27, 2014 | 09:12 AM
Staged07SS's Avatar
Administrator
Administrator
That means piston #4 has gone by by.
Old Jun 27, 2014 | 11:30 AM
do a compression test
Old Jun 27, 2014 | 12:19 PM
Welcome to the site!
Old Jul 13, 2014 | 08:35 AM
Xmetalhead2003X's Avatar
Welcome
WhineSSbaby
Sep 1, 2020 12:39 PM
satisfied
Oct 19, 2015 12:35 AM
Rayray2781@gmail.com
Sep 20, 2015 01:52 PM
CobaltSS 16
Sep 12, 2015 02:43 PM
Bluelightning
Sep 8, 2015 05:18 PM
