2.2 ecotec turbo build
Plan on boosting my 09 Chevy cobalt LS. Has 211k on the engine however it has been maintained well. Previous owner was on older guy that just used the car for work. My goal is around 350 hp. I know I will need to sink in some money hopefully no more than 5-6k. Believe I will need valves and valve springs, forged internals, clutch, timing chain kit, maybe headstuds, head gasket, 4 bar map sensor, pcm upgrades, axles, coil overs, injectors and fuel pump. If there is stuff I’m missing please let me know.
I would honestly suggest just getting an LNF or LSJ, you can find them in a good shape in the 4-8k price range. A full build with machine work is going to run you an easy 6k and your car will be down for a while even if everything goes perfect. Then you have to find a tuner that can get your car running correctly.
Just want to be sure you understand it's not an easy or straightforward thing to turbo swap the base models (when doing engine work), and from a cost standpoint the factory boost version is about the same price.
Then budget 10k to do the build and hope you don't need it all. But as @chevygirl2006 said it's going to be more than 5-6k to hit your power goals.
klutch814
Aug 10, 2012 11:30 PM
