Got screwed, Need help:]
Old Nov 21, 2014 | 08:58 PM
planes747's Avatar
Bought an '09 cobalt SS. Mechanics special turned to mechanics nightmare. Undercarriage damage...axles screwed. Tried getting axle out, cracked oil seal case on tranny. Had to pull the transmission and knock it out from the inside. turns out it was friction welded the inside of the bearing race. Oil starvation most likely the cause. Now cant find the correct size axle to put on. Dealer sends one thing and i need another..back and forth for over a year now...still sitting collecting dust while im searching for freakin axles..thats where im at now... ha
Old Nov 21, 2014 | 10:50 PM
yellowsupercharged06's Avatar
09 lnf ss/tc ?
Old Nov 21, 2014 | 10:51 PM
Crate engine depot has what you need.
Old Nov 21, 2014 | 11:10 PM
user 72239's Avatar
Amazon dude
Old Nov 22, 2014 | 09:49 AM
Here you go
Amazon.com: ACDelco 20778308 GM Original Equipment Passenger Side Front Wheel Drive Half-Shaft Assembly: Automotive Amazon.com: ACDelco 20778308 GM Original Equipment Passenger Side Front Wheel Drive Half-Shaft Assembly: Automotive
Old Nov 24, 2014 | 09:49 AM
planes747's Avatar
Thumbs up
09 tc. Thanks for the feedback. Appreciate the help!
Old Nov 24, 2014 | 09:53 AM
planes747's Avatar
The axle on amazon looks like the one I need, that part no. though. I ordered one from the dealer with that exact part no. and it was the wrong size..?? Their mistake or mine for not double checking...ha
Old Nov 24, 2014 | 10:05 AM
blueLNFftw's Avatar
What do you mean wrong size?
Old Nov 24, 2014 | 10:13 AM
i hope you do know that there are different part num. for each side. are you ordering the correct side ??
are you putting the axle in correctly ? are you 100% sure your car is an LNF and not a "sport" ?
what exactly is not the right size ? the axle to trans, or the axle to hub ? or both ?
Old Nov 24, 2014 | 11:46 AM
planes747's Avatar
I need both axels, driver and passenger side. For starters i started with ordering one, with the 20778308... part# and when i went to put it in, the axle to trans fit just fine, the axle to hub didn't. My hub has a bigger opening, so the axle spline diameter is too small... I've been looking and the LNF looks to be the right fit via pictures and such...I asked the dealer if there were any other axles that go with the SS, they simply said no. They didnt even know what LNF was?!
Old Nov 24, 2014 | 11:50 AM
blueLNFftw's Avatar
That is the LNF CV shaft.
Hmmm. Toss up a picture of your hubs..
Old Nov 24, 2014 | 11:51 AM
user 72239's Avatar
Order the one Ecaulk linked.
I know for a fact that works, cause I helped him install it.
Old Nov 24, 2014 | 11:53 AM
Terminator2's Avatar
I think you got a LSJ axle instead of a LNF one.
Old Nov 24, 2014 | 12:04 PM
blueLNFftw's Avatar
His part number is definitely the LNF CV tho.
Old Nov 24, 2014 | 12:08 PM
Hmm I have no idea unless they put the wrong part in the box.
Old Nov 24, 2014 | 12:20 PM
blueLNFftw's Avatar
That is my thought now.
OP. I would start buying them from NAPA and see if those fit. At least you can walk back in and return them if they are wrong.
Measure the spline up; that will tell you if it is an LSJ part.
Old Nov 24, 2014 | 12:46 PM
Yup it def fit. Both sides are the same.
OP do you have brembos? or did they get swapped for a drag setup?
Old Nov 24, 2014 | 01:36 PM
mongorat427's Avatar
Same spline as a Malibu or G6 and same hub and ABS
Old Nov 25, 2014 | 09:24 AM
planes747's Avatar
Ill throw some up soon as i get some time too. It's just strange because i've ordered multiple times, once from the dealer and a few times from other auto parts stores and it was all the same story..:/
How to Guide
57
Oct 15, 2015 11:56 AM
importkiller
Sep 30, 2015 07:18 PM
Turbo6
Sep 30, 2015 09:14 AM
XStylus
Forced Induction
Sep 16, 2015 06:19 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
