New and need help
Old Mar 14, 2019 | 04:57 PM
Little/Nobody's Avatar
New and need help
Hey guys, im new to cobalt ss life (4 days actually).
I have to put a nee clutch on it but bits also has a p00030 code. I tried clearing it, but the car would have an erratic idle. It came back after i restarted the car, and the car ran smooth again. What, if any, is the harm in letting this code remain?
Old Mar 14, 2019 | 05:04 PM
ProfDNS's Avatar
P0030 is your heater core connection/oxygen sensor. I would get that serviced as soon as possible. Here's a great video on how to change it out:
Spoiler
Old Mar 14, 2019 | 05:10 PM
😯😯 o2 sensor thats all woooooooww $40 and 5 min
Old Mar 15, 2019 | 07:45 AM
jdbaugh1's Avatar
The video Prof posted is pretty comprehensive on properly diagnosing this issue. I have had this code before from when my o2 sensor wire got tangled up in my steering shaft. It was my fault as sometime when working on it I somehow routed that wire closer to the steering shaft than it was originally. I don't know if you know the history of the car but if the trans was ever dropped or it has had work on the exhaust wiring/connector damage could cause your issue. If nothing has been touched then I would say the next most likely culprit is a burned up sensor.
If you do not fix this issue the car will not have the ability to detect and adjust your fueling mixture away from the predefined tables which could cause bad gas mileage rich or lean conditions. I would definitely get the issue diagnosed and fixed.
Old Mar 15, 2019 | 10:40 AM
ProfDNS's Avatar
It is stupid how close it is. I zip tied mine off to the side as much as I could when I replaced my intermediate shaft. Still need to straighten out that dam boot inside the firewall.
Old Mar 16, 2019 | 07:04 PM
I havnt had the chance to chexk the wire as my car is getting a new clutch at a shop. I will be moving the wire and checking the o2 sensor. Rumor has it that it could be caused by swapping to a cold air intake. Any truth to that?
Old Mar 17, 2019 | 12:03 PM
jdbaugh1's Avatar
I wouldn't think so because it is a code related to the function of the sensor and not the reading of the sensor. Cold air intake has absolutely no affect on the function of the o2 sensor unless you somehow nicked the wire or damaged the o2 sensor while installing the intake.
Old Mar 17, 2019 | 12:23 PM
not sure as i wasn't rhebone to do it but i doubt it because they seem a fair distance away
bahoodle
Sep 23, 2019 05:05 PM
LamboW9
Mar 1, 2014 12:01 PM
stealthbomber87
Jul 3, 2013 08:51 PM
redman2357
Apr 10, 2012 12:50 AM
aidenblue
Apr 9, 2008 01:57 PM
