Supercharged SSs are inexpensive
Old Apr 14, 2020 | 04:42 PM
RoelSS's Avatar
Originally Posted by AThomas
I have to look at my time slips but I think that's me. I had been running low 13's for a month and I was frustrated with running at California Speedway. I knew from past experience that Famoso is faster by 3 tenths if not more.
First past was 13.xx@10x, then it ran 12.97@109. I knew that was a good pass so I made the first turn out. But the slicks are ran at a very low air pressure. The right wheel rolled over the rim and damaged the sidewall.
Next past was 13.79@111 on street tires the exact way I drove it everyday.
If I can confirm it, thanks for the grab, I never know who's filming me as I never have anybody with me.
It's a small world out there lol!. Yeah, Fontana is usually 2 or 3 tenths off from Famoso in my experience. Good times
Old Apr 15, 2020 | 10:17 AM
Does it run 11s yet?
Old Apr 15, 2020 | 05:00 PM
AThomas's Avatar
Does what run 11's?
Old Apr 15, 2020 | 05:26 PM
AThomas's Avatar
Originally Posted by steelmesh
Can you show us the timeslip? Have you dyno'd your ST? I am making 400+ whp with a similar weight RWD car, with 275 width tires...I have a 2.2 60ft and can only manage a 13.0 second 1/4 @ 112 mph.
EDITED: Sorry not a 1.2 60ft, it was a 2.2 60ft, here is the time slip
Post #11 - https://www.focusst.org/threads/2016...-enough.67698/
Stock tune = 220 hp
Never had it on the dyno after that with the stock turbo, weight and trap speed say 260 hp. Clearly held back by the stock intercooler.
Had it on the dyno at FocusSport shortly after installing the upgraded turbo. I have to find the graph but it's not great 280 or something on the base tune.
111 mph trap speed is roughly 320 whp and it was very early in the process. The tune was good but the wastegate wasn't tight enough because max duty cycle commanded only resulted in 22-23 psi.
To fix that would require dropping the engine on the subframe.
The ST is gone
Schullz51
Drag Racing
Aug 22, 2012 08:47 PM
Frogstofall
Drag Racing
Oct 20, 2011 07:54 AM
MyOtherSS
Drag Racing
Sep 26, 2010 12:50 PM
firemanfrank
Drag Racing
17
Oct 28, 2007 01:57 AM
blowncobalt
Drag Racing
Jan 7, 2007 04:22 AM
