Nitrous Oxide N20
knocking on n20....
Old Sep 3, 2009 | 08:48 PM
  #101
CobaltLs_14's Avatar
good finally gonna do it rite i'm proud of you guys jason hahaha i just wish i would of done the same i was just to eager...
Old Sep 4, 2009 | 04:32 PM
  #102
ChriSS/SC's Avatar
lol 120 shot on stock LS with no tune ftw
Old Sep 4, 2009 | 05:26 PM
  #103
it was a 150 shot not 120 hahaha
Old Sep 4, 2009 | 09:39 PM
  #104
fwdGTP's Avatar
lmao, probably was running lean and knocking like 15 degrees lol. or even knocking when it was already on max retard. lol.
Old Sep 5, 2009 | 07:20 PM
  #105
ChriSS/SC's Avatar
lol. Richie was retarded.. But unfortunately his timing wasn't
Old Sep 5, 2009 | 08:49 PM
  #106
ItalianJoe1's Avatar
Meh, a 150 shot is where the fun starts.
You should see the LS1 forums. Guys come in and ask "Will I have any problems with a 100 shot?", first reply is "yeah, you won't feel it"
Big shots make it interesting.
Old Sep 5, 2009 | 08:57 PM
  #107
hahaha well i felt mine for abot half a second then nothin... i have pics but i destoryed my #2 piston and cracked 3 and 4 haha
Old Sep 5, 2009 | 11:28 PM
  #108
BillyBboy's Avatar
i am not going to be staying on 75shot very long...
i am going to try a 100shot with very low timing like 12-14 degree's and if i get away with that + like low 11's afr i'll just up it to a 125shot. i think that's one big hit on the engine but for a couple times i wonder how the car will hold to it?
Old Sep 5, 2009 | 11:35 PM
  #109
hungryhip-ccp's Avatar
Originally Posted by ChriSS/SC
lol. Drew I'm gonna try out a bigger fuel jet most likely.
Reason why is that I run fine without nitrous.. So there's no reason why I shouldn't run right with nitrous (with the right amount of fuel).. So 99% sure all I need is more fuel.. And even with 60s I'll almost be what's considered to be "maxed out" at 80%... So I wouldn't be able to compensate for needed fuel with just 60s anyway..
Jason can monitor my AFR on HPT.. So idk why Ethan is calling me retarded for that haha.
We'll see what happens.. I'll most likely try a larger fuel jet soon. Maybe a 26 or 28.
people run 15 16 on a 50 shot, or if its 75 then they live were they get 93 oct fuel
to run a 75 shot on 91 your gonna have to run either really low timing, like 10-12 or add some race gas to the tank and run 15-17 or just put a big ass fuel jet and run the afr in the 10's that will let you run 14 15 degrees with 75 shot... when running nos your not gonna be targeting a afr of 11.8 you will make more trq and it will run more timing if you target a afr of 10.8 on nos... hope this helps
Old Sep 5, 2009 | 11:46 PM
  #110
BillyBboy's Avatar
you can run a 75shot (42nitrous/36fuel) with v-power from shell and 15degree's of timing just fine.
with 60's, 2.8, cx h/e, header/3dp w/cat, airbox mod, 1step colder plugs.
unless maybe it's just my car is lucky? idk lol
Old Sep 6, 2009 | 01:01 AM
  #111
ChriSS/SC's Avatar
Thanks man!
I'm running 91 octane.. With a 75. Running 15 degrees with no knock right now. My jets are 40 / 28 but I'm running pretty rich so I'm going to up the n20 jet to a 42 to balance it out better.
Not positive yet if I should down the fuel jet or up the nitrous one..
As long as my car has no problem taking the power I'd rather go with the 42 nitrous jet...
Any thoughts?
Old Sep 6, 2009 | 01:34 AM
  #112
SlowBalt_06's Avatar
why do you have it in your head that your fine tuning for n02 off of a narrow band..he's guessing your a/f off of the narrow band..everyone in this thread has told you to get a wideband..that makes you a retard
Old Sep 6, 2009 | 01:37 AM
  #113
ChriSS/SC's Avatar
I might get one in the near future. Thanks.
Old Sep 6, 2009 | 01:38 AM
  #114
you think i'm being mean or an ******* i'm just telling you what you should do to be safe...you post up asking for advice but then you dont wanna listen
Old Sep 6, 2009 | 02:10 AM
  #115
ChriSS/SC's Avatar
I was listening. And I take all serious advice to my advantage. That's why I will consider buying one or at least borrowing one to tune. I don't know who sells them for cheap nor do I know how much they cost. I'd need a 2 guage pillar too.
Old Sep 6, 2009 | 02:27 AM
  #116
drew1991sf's Avatar
next time jasons down we can just do a scan of my car and judge off wat the afr is for narrowband ur at.
Old Sep 6, 2009 | 11:49 AM
  #117
Wideband is gonna be around $200, but if it keeps you from cracking a piston, it's worth it.
Old Sep 6, 2009 | 12:57 PM
  #118
sorry but i WB should have been purchased before the nos...
The most important thing to monitor next to knock is AFR...
its just a well worth it investment, it will also follow you from car to car if you choose. so the 200.00 goes a long way in this case.
you keep saying your running rich, but you dont even know? and who ever is tuning you should know better than to be even touching your car without a WB unless he is simply loading a stage tune....
also has he touched your cot settings? or your adders? it probably still has some timing adders that are ******* with you since when you spray the iat adder senses cold ass air and adds timing although you really need it to pull timing...
i just think you should slow down a little on the NOS and speed up a little on the research, it will keep you from a 2000.00 rebuild if you ask me... not to mention melted cat, cracked sleeve, lift the head...
FI+NOS=extreme cyl pressures, you throw in a lean cond and a few degrees of knock here and ther and next thing you know you have traded in your coby for a suby...lol
just be careful man, dont be so anxious to up the shot. Honestly on a N/A engine last time i talked to NOS a 36/22 was a fifty shot a 46/28 was a hundred.
When you inject NOS on a F/I engine it actually provides more HP/TRQ than advertised. Again hope this helped some.
no one is hating on you running NOS its just you have to do it right or it is like holding a ticking time bomb, eventually its gonna blow
Old Sep 6, 2009 | 01:49 PM
  #119
elecblue06's Avatar
^^^ exactly...
Old Sep 6, 2009 | 06:08 PM
  #120
ChriSS/SC's Avatar
Thanks for the advice. Honestly. I will look into getting one pretty soon.
Thing is.. People like you actually say things in a way to help another person. And the fact that I've never used nitrous before makes it important to take serious advice seriously.
The thing that I hate is when I'm in here asking for advice and someone just comes in here and straight up calls me a retard for not doing something right and blah blah blah. lol I could care less about the insults but if you intend for me to take you seriously and you just come in here calling me retarded that is some straight BS if you ask me
You're yet another person who I can say has given me some good advice without being a dick. Gotta love it. Thanks dawg
Old Sep 6, 2009 | 06:12 PM
  #121
damien's Avatar
Yea man, if I keep my car one of the first things i'm buying is a wideband.
Old Sep 6, 2009 | 06:13 PM
  #122
drew1991sf's Avatar
who puts n20 on a rental car?
Old Sep 6, 2009 | 06:17 PM
  #123
ChriSS/SC's Avatar
I know.. That's ******* retarded
Old Sep 6, 2009 | 06:19 PM
  #124
BLAZIN07SS's Avatar
I'm too JDM for you
i must have had a voodoo magic stock motor. ran 22* of timing on a 60 shot for a year(about 17 bottles?) lol
Old Sep 6, 2009 | 06:30 PM
  #125
drew1991sf's Avatar
no ur just gay thats y <3
