Nitrous 101
i have a Q.
according to this pinout...
https://www.cobaltss.net/resources/pcm/05cobalt20.htm
i would assume the pcm c2 connector pin6 is the 5volt TPS wire.
but i get 5V no matter of pedal position.
i also do not see a location for rpm or tach.
can some smarty=pantz enighten me pls?
thx in advance.
thx in advance.
take a voltimeter to it...its not gonna hurt anything by trying anyway. if it doesn't work then it just wont spray, besides u could just hold the nozzle up and have someone step on the gas and that'll be your test.
took mine to the TB and didn't have a pinout just a voltmeter
i see. i just also didnt want to poke holes in the wires or such things. i just thought that the pinout showing the tps voltage would be right, ah well. i tried 2 next and it wasnt right. go figure, its the last possible combo. and where would a guy hook up a rpm wire.
ps, i just installed meth kit, and was splicing into the harness anyway so i thought id hook up a tps wire to make the next install easier. go figure
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
ncstateredline
Sep 10, 2015 07:22 AM
