CNC Ported Head, OTTP part info
you'ld be surprised how well our heads like to be ported
but since you already have the ottp stage1, 2.7, intake, and catback(guessing) it won't be THAT much. but it will definitely be worth the money. get retuned as well. get all you can out of that 2.7 and intake
Last edited by EXsoccer1921; Jan 14, 2009 at 01:11 AM. Reason: Automerged Doublepost
but i havent installed anythign yet, i was thinking i should install my intake, then exhaust, then headers, everythign else should come after right?
clutch is not necessary to change. but recomended if you ever plan on going to the track. valvesprings/valves are going to be able to hold a higher rev limit. cams will alow a higher lift/duration of those valves to allow more clean are to enter the cylinder, and more "dirty" air to leave the cylinder after combustion
i wouldn't get the stage1 if youre gonna go right to a 2.7, i mean their tune is for the 2.8. and especially if youre getting an intake and ported head, youre gonna need another tune right away.
and btw, when i said "upgraded everything pretty much" i was refering to that as being a fully built head
well its not much really. its just the fact that the stage1 from ottp is tuned for a 2.8 and really no other mods. youre going to have a 2.7, intake, exhaust, and ported head.
