For Sale GMR cams and Bates solid lifters
Old Jun 5, 2012 | 02:45 PM
Staged07SS's Avatar
Administrator
Administrator
Originally Posted by zrated89
the stock duration @ 1mm is, intake 196.5 and exh is 191.7
the gmr cams intake i believe is 216 @ 1mm and exh is 218 @ 1mm
That's identical to the ZZP/Comp Cam S2 cam specs.
If you are correct that is great info.
I'll just purchase those one day
No need for solid lash adjusters with those cams (unlike the GMR's).
Old Jun 5, 2012 | 02:53 PM
BLue NoTe's Avatar
No wonder you need to rev these out with all that exhaust duration
Old Jun 5, 2012 | 02:58 PM
EXsoccer1921's Avatar
staged i bet you would love some cams to go with that h62. you ever had it on the dyno?
Old Jun 5, 2012 | 05:58 PM
zrated89's Avatar
sorry man i think the gmrs are intake 218 and exh 220 they were a tad bit more aggresive than the zzp stage twos but not as aggressive as their 3s
Old Jun 6, 2012 | 12:22 AM
mrbelvedere's Avatar
gm dosent measure cams like the rest of the industry dose which is @.050 gm uses 1mm which will make the cams look bigger. the specs on the spec sheet on the zzp stg2 cams are different then what zzp is listing which zzp is using 1mm not @.050 here is the @.050 specs of the zzp stg2 cams
int lift is .423
int dur@.050 210
lobe sep 110
exh lift is 419
int dur@.050 212
lobe sep 113
Old Jun 6, 2012 | 10:22 AM
Staged07SS's Avatar
Administrator
Administrator
Yeah, just caught that while reading through the build book last night.
Meh, close enough for me.
My ultimate goal is to find a GMR exhaust ported head, add Comp cam/ZZP S2 cams, and Supertech 78lb valve springs and retainers.
That goal is on hold until I get a ring for the little lady
You know it man!
Yeah, I had her tested out 2 years ago.
The numbers were 274-275whp, 241-243wtq on 93 pump
& 282whp, 251wtq on 100 race gas (not bad for a straight GMR S3 tune, 76mm pulley, & bolt ons).
I havent tested since because my local dyno shop closed
Once I get the car to where I want, I will re-test even if I have to travel.
Hopefully, with cams and a ported head I will see closer to 300whp (although 300whp is not the main goal).
Old Jun 7, 2012 | 11:12 AM
firefighter404's Avatar
i had those cams they are sweet they where brand new still ther origanal tubes
Old Jun 7, 2012 | 11:45 AM
zrated89's Avatar
You know it man!
I will have zzp stage two cams, 82# valve springs, new valve seals, and a ported head that flows better than the gmr
Old Jun 7, 2012 | 11:57 AM
Staged07SS's Avatar
Administrator
Administrator
Let me know how you like the S2 cams.
I was thinking of asking ZZP if they could could have comp cams grind me a set of cams to meet the GMR specs.
Old Jun 7, 2012 | 12:03 PM
zrated89's Avatar
I tried that brother but comp says theyre in a contract with zzp so thats a no go. I dont care what anyone says zzp cams are based off the gmrs with stock base circles
Old Jun 7, 2012 | 12:24 PM
  #36
Staged07SS's Avatar
Administrator
Administrator
I like the sound of that
Well, like i said S2 cams are close enough to the genuine GMR's.
Old Jun 7, 2012 | 12:52 PM
  #37
RooTBeeR's Avatar
As appealing as cams sound I think I still might only look into cam gears...but I also want 8k revs and not have the power drop off real bad by then
Old Jun 7, 2012 | 12:56 PM
  #38
Staged07SS's Avatar
Administrator
Administrator
From my research, and talking to some peeps, the gmr cam gears are a pain in the ass to setup. Although, this is what the Time Attack ran, I think cams might be an easier option.
Old Jun 7, 2012 | 01:21 PM
  #39
RooTBeeR's Avatar
Yeah I heard that too witch is probably why ill just forever rev to 7500 on a stock long block
Old Jun 7, 2012 | 01:31 PM
  #40
Staged07SS's Avatar
Administrator
Administrator
I've reved out that high a few times, but dropped the limiter back down to 7250rpm where it's been for 3 years now. I'll wait until my valvetrain is upgraded before winding her out that far again.
Old Jun 7, 2012 | 02:27 PM
  #41
zrated89's Avatar
**** I reved to 7800 no issues and all cam gears do is move your powerband around are a pain to setup and a tuning headache. Cams will move it a little but make good power on top of it
Old Jun 7, 2012 | 09:06 PM
  #42
Joemaster70's Avatar
i reved to 7250 like 4 times before i broke my crankshaft and rod broke. What luck i have right?
Old Jun 7, 2012 | 09:47 PM
  #43
BLue NoTe's Avatar
You broke your crank? Definitely the first time ive heard that. Don't know anyone thats thrown a rod before either
Old Jun 7, 2012 | 09:59 PM
  #44
they arent that sweet if you dont run them
Old Jun 7, 2012 | 10:23 PM
  #45
zrated89's Avatar
u musta had a defect crank man thats never happened even on zzps builds
Old Jun 7, 2012 | 10:25 PM
  #46
zrated89's Avatar
only time someone does is if they did the build themselves and messed something up. Only thing the lsj is known for is busting ringlands, and at high enough power and stupidity sleeves
Old Jun 7, 2012 | 11:04 PM
  #47
yeah had my machine shop take my motor apart and see whats up. they said the block was all good except for my crank and 1 rod. i was on a GM Stage 3 with 3"exhaust and others. No dualpass but had H/E and that happend while racing on the highway. wont do that again
Sl0wbaltSS
Nov 21, 2018 11:11 PM
HEATON
Oct 16, 2015 07:21 PM
footballplaya3k
Sep 30, 2015 09:39 PM
nathan112i
Sep 30, 2015 07:12 PM
