boost guage quit working...help??
Old Jun 11, 2010 | 12:17 AM
corn-popSS's Avatar
06 ss/sc. boost guage is stuck on 5 psi but i can still hear the supercharger. the lights still work on it when it gets dark but the needle never moves.
what would cause this and how would i take it apart to look at it??
Old Jun 11, 2010 | 02:16 AM
Nighthawk243's Avatar
The gauges are junk. Just put a new one in. Not hard.
Old Jun 11, 2010 | 02:26 AM
cmatthewb101's Avatar
Replace it.... They eventually go out. Either take it to a dealer and have it replaced, or put one in yourself
Old Jun 11, 2010 | 09:57 AM
corn-popSS's Avatar
How do you take the stock on out?
Old Jun 11, 2010 | 10:12 AM
HyperMuffin's Avatar
You will have to remove the pillar. At the top there is a plastic circle piece. Pop it out and then unscrew the screw behind it and the pillar should then just pop off. The gauge probably is bracketed in behind it so just look at the back side of the pillar and remove whatever is necessary.
Old Jun 11, 2010 | 10:39 AM
corn-popSS's Avatar
alright, thanks. I'll see what damage I can do
Old Jun 11, 2010 | 10:45 AM
Also there might be metal clips holding it on, so when you unscrew the top slowly slide your fingers down the pillar to pry it up and don't just yank it. That way you wont break any clips.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
tomj77
Oct 4, 2015 11:39 AM
