Broke the boost bypass actuator nipple
Old Dec 22, 2008 | 12:23 AM
Steven Flit's Avatar
Aside from the given of ordering a new one. Is the car driveable so long as I dont take it into boost?
Old Dec 22, 2008 | 12:26 AM
JimzSS's Avatar
That's fixable.
Some good epoxy ...maybe from Fastenall?
Take your time.
If you can find one for cheap do that.
How does it run?
Old Dec 22, 2008 | 12:27 AM
Originally Posted by JimzSS
That's fixable.
Take your time.
How does it run?
question is, can it still run and be driveable... so long as I dont get on it, and just cruise.
crazy glue unfortunately couldnt hold it.
Old Dec 22, 2008 | 12:29 AM
FASTL61's Avatar
epoxy will hold it on or quicksteel
Old Dec 22, 2008 | 12:31 AM
ItalianJoe1's Avatar
The car will be attempting to boost all the time from what i'm thinking, so I'd advise against it, but try it and see. It can't really hurt anything, but the car might run poorly.
I have one if you need it, used and in perfect shape.
Old Dec 22, 2008 | 12:32 AM
JimzSS's Avatar
I would plug the hose with a golf tee or such and take it for a spin, using common sence of course.
I don't see what it would hurt.
I don't believe that hose has any boost on it.
I could be wrong but have a bud rev it up and you monitor the action under the hood.
big question here guys is can it still drive without blowing up or something...
i need to take it down to the body shop... damn old man hit my car the other day.
JimzSS's Avatar
Old Dec 22, 2008 | 01:15 AM
Thanks to EUTHANASIA
I'll be installing a new one within the hour; or as soon as he arrives with his extra.
Old Dec 22, 2008 | 01:27 AM
JimzSS's Avatar
Good to have buds that help out in the a.m.
Old Dec 22, 2008 | 05:23 AM
its still p.m. here
glad to have friends liek that
hes here
time to get to fixen!
fixed
/end
Last edited by Steven Flit; Dec 22, 2008 at 05:23 AM. Reason: Automerged Doublepost
Old Dec 22, 2008 | 12:28 PM
FASTL61's Avatar
from what it looks like is that line does have boost in it and closes the bypass as you start buildin boost..If so then you will need to plug that hose and drive it like a grandma..either that or get some epoxy for temp..epoxy WILL hold it on
Old Dec 22, 2008 | 05:25 PM
To be technical, it has vacuum in it, its pre-blower, no boost.
When the car is at idle, throttle closed, the vacuum on the top of the BBV pulls it open, so the s/c doesn't have to put any load on the motor. As you start to open the throttle, passing 10hg of vacuum, it starts to close. Once you reach atmospheric (0hg), it is fully closed, allowing no air bleed back from the blower. Once you take your foot off the gas, TB closes, vacuum again, opens the valve.
For refrence, the other line on it is usually an atmospheric reference line, but the car has a solenoid on that side to use manifold pressure to force it back open if needed, thats what gives the ability to limit boost.
Old Dec 23, 2008 | 12:53 AM
FASTL61's Avatar
ahh i had it backwards my bad sorry i dont own a ss/sc so i was takin a stab at it lol
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
agentirons
Oct 16, 2015 02:11 AM
Sep 27, 2015 08:53 PM
